#41 | Link |
Easiest, as in crop(36,36,-36,-36)
or Code:
x=36 y=36 w=-36 h=-36
#43 | Link |
I noticed that the global variables are one frame late to current frame:
ShowChannels(SetVar=True,show=true)
scriptclip("""subtitle(string(SC_Min_0))""")
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
#45 | Link | |
Thanks G.
#46 | Link |
Thanks Gavino! I'm making a soft limiter so I was thinking on feeding the (accumulated) loose minmax values, not sure how I can do it without HBD support, somehow I need to force the ShowChannels() call despite not using its output clip.
ColorYUV() has HBD support but didn't see how to extract values. I also want to add a per scene accumulated, a fast method is to reinitiate ShowChannels() after a scene change. EDIT: Strange, new ScriptClip can't grab ShowChannels globals. Code:
ShowChannels(SetVar=True,show=false)
ScriptClip( function [] () {
propSetArray("_YMin", function[]() { return [SC_Min_0,SC_Max_0] } )
}, after_frame=True )
propshow()
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 18th November 2021 at 22:45. |
#47 | Link |
EDIT: ShowChannels SC_LMn_0 and SC_LMx_0 are LOOSE min and max.
You can also use YPlaneMin(Threshold=0.0) and YPlaneMax(Threshold=0.0) for Ymin and Ymax. YPlaneMin(Threshold=whatever%) and YPlaneMax(Threshold=whatever%) for loose min/max, if not interested in other values. (and builtin HBD) EDIT: ShowChannels defo sets Globals [some of my plugs set locals because of some problem/request or other reported by user]. EDIT: I have no idea what your script snippet does, I have not yet figured out that scriptclip function stuff. But, does this work Code:
propSetArray("_YMin", function[]() { return [YPlaneMin(0.0),YPlaneMax(0.0)] } )
}, after_frame=True ) # Maybe After_Frame not needed : Presumably YPlaneMin/Max will be using implicit Last (or something ???)
propshow()
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 19th November 2021 at 02:34. |
#48 | Link |
Yes, maybe I will do that for not accumulated, although that uses 0.4 percentile (?)
I wanted some kind of temporal average for the values. I managed somewhat to pass the global vars to SoftLimiter, but with the old ScriptClip.
#49 | Link | ||
ColorYUV(analyse=true)
uses 0.4, actually total Y sample count / 256 for Y, and total Y sample count / 1024 for U and V (when YV12, so still 0.4). [old v2.58 ColorYUV which I have source for]. ShowChannels uses default 0.1%. Quote:
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 19th November 2021 at 03:29. |
| Tags |
| channels, info, max, min |
| Thread Tools | |
| Display Modes | |
