#23 | Link | |||
1st line of doc: Quote:
Written previously in thread: Quote:
No idea what CCW and CW are, best guess is Celebrity Championship Wrestling, or Carrying Concealed Weapon, although I did initially think Clockwise, Counter Clockwise. ![]() What I'm I wanting to do, well a number of things keep getting pushed back, including mods to both DGIndex and MeGUI Batchers, investigation field order, interlace/ivtc detection, and other infos useful in autonomous conversion script. RoboCrop auto crop and auto levels setting plug. Perhaps MediaInfo implemented as plug. Investigate implement Avisynth Script Editor from VDMod into latest version VD (perhaps beyond me, or too time consuming). + lots more. I'm always happier doing what I want, and is usually where my better ideas surface.
#24 | Link |
Hmm, the luma gamma of 2.2 already approxmiates the power curve of the eye response, so it's generally ok as is. I think what you're trying to get at is a perceptually uniform percentage measurement. This would be accomplished by measuring the L of L a* b*. It certainly can be converted internally, but it's gonna be a bit slow as it needs several floating point ops.
As for, do you really want to do this - yes, I think most filters want to operate on a perceptually uniform domain, but not all. Some exception include, gamma-aware resizing (and interpolation etc.), and perceptual masking. As for the luma distribution of natural objects, I believe they follow the Phong illumination model. Highlights are a raised cosine, diffuse is a cosine, and ambient is a constant, so I don't think the histogram follows a Gaussian Normal Distribution (aka "Bell Curve") as you propose. Interestingly, if you take the inverse Phong, you can deduce the angle a surface is based on how it's shaded, which leads to a way to create a 3d model from a single photo. There's far better ways to do this though, like projecting a pattern onto the object, using lidar, or using multiple views. Oh, a Bell jar is a shape to contain high pressure, like a vacuum jar, I think. It's a different shape; the Bell curve could refer to a Mr. Bell, but I think it's the shape of a bell that you ring, and that shape is designed to resonate and amplify sound. As I recall, sound is best amplified by a log shape.. the classic horn design. It's the most efficient speaker shape. Blah blah balh
#25 | Link |
Thanks for that jmac, and yep, I meant "Bell" rather than "BellJar".
I've done some tests on 320MB chunks of test vobs cut from somewhere in middle of a DVD vob, clip lengths vary from about 8 mins to 15 mins depending on eg bitrate and number of audio channels etc. Results are Accumulated values for the entire clips, just to show typical results that might be expected. EDIT: The clips were all auto cropped and auto leveled prior to ShowChannels(), hence 16 -> 235 Y range. Code:
NTSC_Top_FORCEFILM-ReturnOfTheKing.d2v
AVE_Y=71.12 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=127.22 MIN_U= 62 MAX_U=168 LMIN_U= 78 LMAX_U=158
AVE_V=126.63 MIN_V= 74 MAX_V=188 LMIN_V= 78 LMAX_V=174
PAL_I_Top_169_P-FellowshipOfTheRings_Extended.d2v
AVE_Y=70.31 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=119.82 MIN_U= 54 MAX_U=178 LMIN_U= 77 LMAX_U=166
AVE_V=132.89 MIN_V= 82 MAX_V=190 LMIN_V=103 LMAX_V=183
PAL_I_Top_169_P-TwoTowers_Extended.d2v
AVE_Y=72.33 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=129.66 MIN_U= 63 MAX_U=159 LMIN_U= 70 LMAX_U=153
AVE_V=124.38 MIN_V= 87 MAX_V=226 LMIN_V= 93 LMAX_V=201
PAL-P_169_P-ReturnOfTheKing_Extended.d2v
AVE_Y=98.68 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=122.03 MIN_U= 73 MAX_U=144 LMIN_U= 88 LMAX_U=137
AVE_V=131.77 MIN_V=102 MAX_V=183 LMIN_V=117 LMAX_V=164
PAL_I_Top_169_P-LordOfTheRings_Symphony.d2v
AVE_Y=56.30 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=130.30 MIN_U= 33 MAX_U=249 LMIN_U= 73 LMAX_U=220
AVE_V=129.64 MIN_V= 6 MAX_V=248 LMIN_V= 29 LMAX_V=204
PAL_I_Top_169_P-DieHard.d2v
AVE_Y=51.19 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=122.70 MIN_U= 55 MAX_U=220 LMIN_U= 77 LMAX_U=172
AVE_V=134.51 MIN_V= 32 MAX_V=248 LMIN_V= 60 LMAX_V=191
PAL_I_Top_169_P-DieHard_2.d2v
AVE_Y=55.67 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=126.27 MIN_U= 56 MAX_U=196 LMIN_U= 69 LMAX_U=172
AVE_V=129.37 MIN_V= 53 MAX_V=216 LMIN_V= 65 LMAX_V=183
PAL-I-Top_169_P-DieHard_3.d2v
AVE_Y=95.52 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=123.56 MIN_U= 62 MAX_U=173 LMIN_U= 81 LMAX_U=154
AVE_V=136.44 MIN_V= 75 MAX_V=237 LMIN_V= 93 LMAX_V=209
PAL_I_Top_43_Hybrid-StarTrekNG_1_TooShortASeason.d2v
AVE_Y=60.59 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=127.39 MIN_U= 1 MAX_U=209 LMIN_U=107 LMAX_U=180
AVE_V=136.72 MIN_V= 1 MAX_V=203 LMIN_V= 96 LMAX_V=191
PAL_I_Top_43_Hybrid-StarTrekNG_2_WhenTheBoughBreaks.d2v
AVE_Y=52.47 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=126.70 MIN_U= 52 MAX_U=210 LMIN_U= 59 LMAX_U=173
AVE_V=135.38 MIN_V= 45 MAX_V=195 LMIN_V=105 LMAX_V=189
PAL_I_Top_43_Hybrid-StarTrekNG_3_HomeSoil.d2v
AVE_Y=51.29 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=128.48 MIN_U= 61 MAX_U=207 LMIN_U= 88 LMAX_U=188
AVE_V=131.68 MIN_V= 0 MAX_V=255 LMIN_V=106 LMAX_V=178
PAL_I_Top_169_P-Godfather.d2v
AVE_Y=50.64 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=121.47 MIN_U= 46 MAX_U=188 LMIN_U= 68 LMAX_U=144
AVE_V=134.98 MIN_V= 71 MAX_V=214 LMIN_V=101 LMAX_V=190
PAL_I_Top_169_P-Godfather_2.d2v
AVE_Y=62.44 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=119.61 MIN_U= 72 MAX_U=180 LMIN_U= 80 LMAX_U=151
AVE_V=136.48 MIN_V= 78 MAX_V=179 LMIN_V=115 LMAX_V=169
PAL_I_Top_169_P-Godfather_3.d2v
AVE_Y=57.43 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=118.46 MIN_U= 47 MAX_U=188 LMIN_U= 82 LMAX_U=186
AVE_V=137.32 MIN_V= 76 MAX_V=206 LMIN_V= 91 LMAX_V=200
PAL_I_Bot_43-BustyCops.d2v
AVE_Y=122.60 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=118.15 MIN_U= 32 MAX_U=255 LMIN_U= 62 LMAX_U=167
AVE_V=139.79 MIN_V= 48 MAX_V=246 LMIN_V= 92 LMAX_V=221
PAL_I_Bot_169_P-FalseBadFieldOrder-FlightPlan.d2v
AVE_Y=58.96 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=128.46 MIN_U= 0 MAX_U=255 LMIN_U= 90 LMAX_U=167
AVE_V=125.02 MIN_V= 0 MAX_V=255 LMIN_V= 61 LMAX_V=182
PAL_I_Top_43_I-GirlIn3D.d2v
AVE_Y=60.73 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=124.27 MIN_U= 50 MAX_U=222 LMIN_U= 63 LMAX_U=213
AVE_V=129.07 MIN_V= 47 MAX_V=232 LMIN_V= 60 LMAX_V=205
PAL_I_Top_43_I-SocialClimber.d2v
AVE_Y=85.46 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=120.87 MIN_U= 30 MAX_U=212 LMIN_U= 56 LMAX_U=192
AVE_V=136.94 MIN_V= 89 MAX_V=212 LMIN_V= 97 LMAX_V=194
PAL_I_Top_43_I-UltimateLimit.d2v
AVE_Y=52.55 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=128.92 MIN_U= 31 MAX_U=189 LMIN_U= 51 LMAX_U=183
AVE_V=129.58 MIN_V= 82 MAX_V=212 LMIN_V= 92 LMAX_V=193
PAL_I_Top_43_P-ArtificialTelepathy.d2v
AVE_Y=89.88 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=128.38 MIN_U= 0 MAX_U=218 LMIN_U= 68 LMAX_U=207
AVE_V=126.38 MIN_V= 0 MAX_V=217 LMIN_V= 44 LMAX_V=200
PAL_I_Top_43_P-AssaultOnPrecinct13.d2v
AVE_Y=60.04 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=129.02 MIN_U= 0 MAX_U=173 LMIN_U= 85 LMAX_U=157
AVE_V=123.97 MIN_V= 0 MAX_V=215 LMIN_V= 74 LMAX_V=188
PAL_I_Top_43_P-Cabaret.d2v
AVE_Y=44.20 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=126.85 MIN_U= 1 MAX_U=254 LMIN_U= 73 LMAX_U=232
AVE_V=130.97 MIN_V= 30 MAX_V=253 LMIN_V= 81 LMAX_V=210
PAL_I_Top_43_P-FourPlay.d2v
AVE_Y=72.80 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=124.06 MIN_U= 69 MAX_U=190 LMIN_U= 90 LMAX_U=170
AVE_V=130.90 MIN_V= 65 MAX_V=205 LMIN_V= 75 LMAX_V=191
PAL_I_Top_43_P-GoingOverboard.d2v
AVE_Y=104.08 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=127.27 MIN_U= 53 MAX_U=188 LMIN_U= 76 LMAX_U=161
AVE_V=129.42 MIN_V= 42 MAX_V=221 LMIN_V= 82 LMAX_V=203
PAL_I_Top_43_P-GroundControl.d2v
AVE_Y=57.19 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=126.20 MIN_U= 0 MAX_U=255 LMIN_U= 84 LMAX_U=187
AVE_V=132.69 MIN_V= 19 MAX_V=211 LMIN_V= 36 LMAX_V=201
PAL_I_Top_43_P-Panic.d2v
AVE_Y=64.10 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=124.26 MIN_U= 37 MAX_U=179 LMIN_U= 87 LMAX_U=159
AVE_V=130.67 MIN_V= 67 MAX_V=203 LMIN_V=107 LMAX_V=189
PAL_I_Top_169_P-AllTheQueensMen.d2v
AVE_Y=75.95 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=126.43 MIN_U= 25 MAX_U=190 LMIN_U= 42 LMAX_U=183
AVE_V=126.32 MIN_V= 81 MAX_V=238 LMIN_V= 95 LMAX_V=227
PAL_I_Top_169_P-DuskTillDawn.d2v
AVE_Y=54.26 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=121.26 MIN_U= 56 MAX_U=191 LMIN_U= 61 LMAX_U=183
AVE_V=137.11 MIN_V= 82 MAX_V=219 LMIN_V= 95 LMAX_V=203
PAL_I_Top_169_P-EducatingRita.d2v
AVE_Y=74.65 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=125.96 MIN_U= 71 MAX_U=167 LMIN_U= 99 LMAX_U=156
AVE_V=127.71 MIN_V= 99 MAX_V=177 LMIN_V=108 LMAX_V=161
PAL_I_Top_169_P-HarryPotter-DeathlyHallows2.d2v
AVE_Y=56.44 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=123.50 MIN_U= 0 MAX_U=255 LMIN_U=102 LMAX_U=140
AVE_V=128.86 MIN_V= 82 MAX_V=165 LMIN_V=105 LMAX_V=151
PAL_I_Top_169_P-JurassicPark.d2v
AVE_Y= 91.04 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=125.36 MIN_U= 3 MAX_U=206 LMIN_U= 89 LMAX_U=169
AVE_V=134.81 MIN_V= 3 MAX_V=238 LMIN_V=101 LMAX_V=196
PAL_I_Top_169_P-LastSign.d2v
AVE_Y=60.97 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=125.24 MIN_U= 44 MAX_U=244 LMIN_U= 55 LMAX_U=219
AVE_V=128.43 MIN_V= 76 MAX_V=249 LMIN_V= 97 LMAX_V=174
PAL_I_Top_169_P-LegallyBlond.d2v
AVE_Y=69.96 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=123.08 MIN_U= 42 MAX_U=214 LMIN_U= 63 LMAX_U=197
AVE_V=136.82 MIN_V= 43 MAX_V=241 LMIN_V= 59 LMAX_V=222
PAL_I_Top_169_P-MillionDollarBaby.d2v
AVE_Y=74.50 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=124.28 MIN_U= 0 MAX_U=255 LMIN_U= 85 LMAX_U=152
AVE_V=124.73 MIN_V= 0 MAX_V=255 LMIN_V= 95 LMAX_V=157
PAL_I_Top_169_P-ResidentEvil_Apocalypse.d2v
AVE_Y=58.35 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=136.48 MIN_U= 20 MAX_U=191 LMIN_U= 63 LMAX_U=181
AVE_V=118.23 MIN_V= 23 MAX_V=215 LMIN_V= 40 LMAX_V=195
PAL_I_Top_169_P-ShawshankRedemption.d2v
AVE_Y=65.69 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=126.15 MIN_U= 35 MAX_U=251 LMIN_U=100 LMAX_U=159
AVE_V=129.75 MIN_V= 45 MAX_V=251 LMIN_V=100 LMAX_V=164
PAL_I_Top_169_P-Spiderman.d2v
AVE_Y=74.89 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=123.81 MIN_U= 1 MAX_U=216 LMIN_U= 83 LMAX_U=189
AVE_V=135.67 MIN_V= 1 MAX_V=231 LMIN_V= 48 LMAX_V=202
PAL_I_Top_169_P-SweetestThing.d2v
AVE_Y=64.76 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=120.72 MIN_U= 1 MAX_U=254 LMIN_U= 48 LMAX_U=201
AVE_V=136.83 MIN_V= 1 MAX_V=254 LMIN_V= 71 LMAX_V=221
PAL_I_Top_169_P-XXX-TheNextLevel.d2v
AVE_Y=77.01 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=128.31 MIN_U= 37 MAX_U=192 LMIN_U= 55 LMAX_U=181
AVE_V=125.04 MIN_V= 36 MAX_V=219 LMIN_V= 63 LMAX_V=205
PAL_I_Top_169_I-LoveOnTheSide(Weird mix I and P).d2v
AVE_Y=73.29 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=122.95 MIN_U= 68 MAX_U=203 LMIN_U= 78 LMAX_U=193
AVE_V=136.01 MIN_V= 60 MAX_V=225 LMIN_V= 76 LMAX_V=220
PAL-I-Top_169_P-MissionImpossible_2.d2v
AVE_Y=76.59 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=125.45 MIN_U= 3 MAX_U=199 LMIN_U= 56 LMAX_U=187
AVE_V=132.29 MIN_V= 34 MAX_V=232 LMIN_V= 47 LMAX_V=198
PAL-I-Top_169_P-ResevoirDogs.d2v
AVE_Y=70.37 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=124.45 MIN_U= 42 MAX_U=191 LMIN_U= 69 LMAX_U=181
AVE_V=131.47 MIN_V= 32 MAX_V=234 LMIN_V= 88 LMAX_V=206
PAL-I-Top_169_P-Unbreakable.d2v
AVE_Y=47.84 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=128.94 MIN_U= 59 MAX_U=207 LMIN_U= 88 LMAX_U=182
AVE_V=126.05 MIN_V= 41 MAX_V=207 LMIN_V= 82 LMAX_V=165
PAL-P_169_P-AeonFlux.d2v
AVE_Y=64.54 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=123.49 MIN_U= 36 MAX_U=164 LMIN_U= 59 LMAX_U=158
AVE_V=131.04 MIN_V= 67 MAX_V=199 LMIN_V= 80 LMAX_V=187
PAL-P_169_P-Alexander.d2v
AVE_Y=93.62 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=121.21 MIN_U= 35 MAX_U=186 LMIN_U= 60 LMAX_U=168
AVE_V=134.59 MIN_V= 63 MAX_V=218 LMIN_V= 95 LMAX_V=186
PAL-P_169_P-BodyGuard.d2v
AVE_Y=59.37 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=130.49 MIN_U= 58 MAX_U=226 LMIN_U= 68 LMAX_U=207
AVE_V=129.52 MIN_V= 60 MAX_V=212 LMIN_V= 84 LMAX_V=207
PAL-P_169_P-DownWithLove.d2v
AVE_Y=72.96 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=122.13 MIN_U= 6 MAX_U=200 LMIN_U= 14 LMAX_U=188
AVE_V=132.64 MIN_V= 70 MAX_V=209 LMIN_V= 80 LMAX_V=183
PAL-P_169_P-Gladiator.d2v
AVE_Y=69.03 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=123.12 MIN_U= 50 MAX_U=168 LMIN_U= 64 LMAX_U=162
AVE_V=134.22 MIN_V= 90 MAX_V=225 LMIN_V= 99 LMAX_V=211
PAL-P_169_P-Hannibal.d2v
AVE_Y=61.85 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=132.80 MIN_U= 90 MAX_U=202 LMIN_U=106 LMAX_U=179
AVE_V=124.39 MIN_V= 84 MAX_V=220 LMIN_V= 92 LMAX_V=189
PAL-P_169_P-HitchhikersGuideToTheGalaxy_Movie.d2v
AVE_Y=113.73 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=121.45 MIN_U= 40 MAX_U=198 LMIN_U= 55 LMAX_U=181
AVE_V=134.68 MIN_V= 27 MAX_V=228 LMIN_V= 47 LMAX_V=213
PAL-P_169_P-HuntForRedOctober.d2v
AVE_Y=49.98 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=127.82 MIN_U= 71 MAX_U=224 LMIN_U= 86 LMAX_U=210
AVE_V=131.32 MIN_V= 70 MAX_V=234 LMIN_V= 81 LMAX_V=223
PAL-P_169_P-ItalianJob_2.d2v
AVE_Y=71.63 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=128.50 MIN_U= 5 MAX_U=251 LMIN_U= 71 LMAX_U=169
AVE_V=127.32 MIN_V= 5 MAX_V=251 LMIN_V= 65 LMAX_V=225
PAL-P_169_P-SinCity.d2v
AVE_Y=55.55 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=127.57 MIN_U=102 MAX_U=176 LMIN_U=113 LMAX_U=161
AVE_V=128.48 MIN_V= 48 MAX_V=176 LMIN_V= 58 LMAX_V=145
PAL-P_169_P-TombRaider.d2v
AVE_Y=55.56 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=126.50 MIN_U= 70 MAX_U=219 LMIN_U= 91 LMAX_U=194
AVE_V=130.88 MIN_V= 73 MAX_V=234 LMIN_V= 84 LMAX_V=207
PAL-P_169_P-TombRaider_CradleOfLife.d2v
AVE_Y=49.62 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=124.05 MIN_U= 32 MAX_U=191 LMIN_U= 82 LMAX_U=186
AVE_V=134.29 MIN_V= 68 MAX_V=239 LMIN_V=104 LMAX_V=224
PAL-P_169_P-UnderworldEvolution.d2v
AVE_Y=39.20 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=129.71 MIN_U= 37 MAX_U=164 LMIN_U= 69 LMAX_U=158
AVE_V=125.12 MIN_V= 58 MAX_V=190 LMIN_V= 70 LMAX_V=172
PAL-P_169_P-VanHelsing.d2v
AVE_Y=75.26 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=137.14 MIN_U= 58 MAX_U=170 LMIN_U=103 LMAX_U=161
AVE_V=123.96 MIN_V= 97 MAX_V=201 LMIN_V=107 LMAX_V=173
PAL-P_169_P-WarOfTheWorlds.d2v
AVE_Y=80.80 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=122.47 MIN_U= 58 MAX_U=191 LMIN_U= 75 LMAX_U=186
AVE_V=130.60 MIN_V= 64 MAX_V=205 LMIN_V= 71 LMAX_V=185
PAL-P_169_P-XMen_2.d2v
AVE_Y=50.75 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=129.09 MIN_U= 0 MAX_U=255 LMIN_U= 73 LMAX_U=189
AVE_V=121.72 MIN_V= 0 MAX_V=255 LMIN_V= 44 LMAX_V=192
PAL-P_169_P-TimeMachine.d2v
AVE_Y=59.64 MIN_Y= 16 MAX_Y=235 LMIN_Y= 16 LMAX_Y=235
AVE_U=117.64 MIN_U= 56 MAX_U=193 LMIN_U= 83 LMAX_U=145
AVE_V=141.43 MIN_V= 97 MAX_V=214 LMIN_V=125 LMAX_V=182
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 25th October 2012 at 21:52. |
#26 | Link |
DGIndex Template Script to produce ShowChannels data as in previous post (Is slow, as plays entire clip to end).
Writes "Accumulated.txt" file on last frame (appended to any already existing file). Code:
# Requires GScript, Grunt, RT_Stats, ShowChannels, DGIndex
#Import ("D:\avs\BANK\QueryBorderCrop.avsi") # Required by RoboLevels unless in plugs dir
#Import ("D:\avs\BANK\QueryLumaMinMAx.Avsi")
VIDOEOFILE="__vid__" # DGIndex inserts clip name here
MPEG2Source(VIDOEOFILE)
NAME=VIDOEOFILE
# RoboLevels() # Uncomment if Global (clipwise) Auto Levels required first
ShowChannels(SetVar=true,show=false) # set Show=true, if required but may be a tiny bit slower
AssumeFPS(250.0) # Do it a bit quicker
EOL=Chr(10)
S="""NAME + EOL + \
" AVE_Y="+String(SC_AAve_0,"%3.2f")+" MIN_Y="+String(SC_AMIN_0,"%3.0f")+" MAX_Y="+String(SC_AMAX_0,"%3.0f")+ \
" LMIN_Y="+String(SC_ALMN_0,"%3.0f")+" LMAX_Y="+String(SC_ALMX_0,"%3.0f") + EOL + \
" AVE_U="+String(SC_AAve_1,"%3.2f")+" MIN_U="+String(SC_AMIN_1,"%3.0f")+" MAX_U="+String(SC_AMAX_1,"%3.0f")+ \
" LMIN_U="+String(SC_ALMN_1,"%3.0f")+" LMAX_U="+String(SC_ALMX_1,"%3.0f") + EOL + \
" AVE_V="+String(SC_AAve_2,"%3.2f")+" MIN_V="+String(SC_AMIN_2,"%3.0f")+" MAX_V="+String(SC_AMAX_2,"%3.0f")+ \
" LMIN_V="+String(SC_ALMN_2,"%3.0f")+" LMAX_V="+String(SC_ALMX_2,"%3.0f") + EOL"""
WriteFileIf("Accumulated.txt","current_frame==FrameCount()-1",S,append=true)Return Last
return last
# Below optional
Function RoboLevels(clip c,float "Strength",int "Samples",float "Ignore",Bool "QBC",Float "QBC_Thresh",int "X",int "Y",int "W",int "H", \
int "Matrix",bool "PC",bool "DEBUG") {
c
Frames=FrameCount
Strength=Float(Default(Strength,1.0))
Samples=(!Defined(Samples)) ? 24 : (Samples > Frames) ? Frames : (Samples < 1) ? 1 : Samples
Ignore=Float(Default(Ignore,0.2))
QBC=Default(QBC,True)
QBC_Thresh=Float(Default(QBC_Thresh,-32.0))
QBCropXP = Default(X,0)
QBCropYP = Default(Y,0)
QBCropWP = Default(W,0)
QBCropHP = Default(H,0)
Matrix = Default(Matrix,(width <= 720) ? 2 : 3)
PC=Default(PC,False)
DEBUG=Default(DEBUG,True)
Assert(Strength>0.0 && Strength <=1.0, "RoboLevels: 0.0 < Strength <= 1.0")
GScript("""
if(QBC) {
QBCS=QueryBorderCrop(samples=Samples,thresh=QBC_Thresh,debug=DEBUG,ignore=Ignore,matrix=Matrix)
(DEBUG)? RT_Debug(QBCS): NOP
Eval(QBCS)
tclip=c.Crop(QBCropXP,QBCropYP,QBCropWP,QBCropHP)
QLMMS=QueryLumaMinMax(tclip,samples=Samples,ignore=Ignore,debug=DEBUG,matrix=Matrix)
(DEBUG)?RT_Debug(QLMMS):NOP
Eval(QLMMS)
if(IsRGB() || PC) {
CSMin = 0
CSMax = 255
} else {
CSMin = 16
CSMax = 235
ALMin = Int(CSMin - ((CSMin - QLMMMin) * Strength) + 0.5) # Round Up
ALMax = Int(CSMax - ((CSMax - QLMMMax) * Strength)) # Round down
(QBC) ? Crop(QBCropXM,QBCropYM,QBCropWM,QBCropHM): NOP
(DEBUG)? RT_Debug("Levels("+String(ALMin)+",1.0,"+String(AlMax)+","+String(CSMin)+","+String(CSMax)+",Coring=False)"):NOP
Levels(ALMin,1.0,ALMax,CSMin,CSMax,Coring=False) # DO NOT use Coring
return Last
EDIT: Was unsuccessful in trying to get it to WriteFile on close without using ScriptClip, anybody clever out there ? EDIT: Clarify, WriteFileEnd wants to write the "S" string as it was on WriteFileEnd contructor call ie at the beginning, we want to write final results, not what it was before starting. EDIT:, OK, think I've twigged a way, new plugin to inquire value of string variable in destructor and then write it, other suggestions ? EDIT: Perhaps WriteFileEnd should have the option to evaluate on writing ie at destructor rather than when constructed, would seem the obvious way anyhow.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 31st October 2012 at 14:16. |
#27 | Link | |
Avisynth language lover
See this post. (EDIT) PS To show a final value in a run-time script, an alternative to your WriteFileIf(...,"current_frame==FrameCount()-1",...) is to use (still within ScriptClip) WriteFile("Accumulated.txt","S",append=false) See here for an explanation. The advantage of this is it shows the value for the last frame rendered, which no longer needs to be the final frame of the clip. EDIT2: (Following your custom of repeated edits. )Your original way can be done without ScriptClip by setting S to be the expression to be evaluated rather than the value itself: Code:
EOL=Chr(10)
S="""NAME + EOL + \
#28 | Link |
Thank you for the edit, I think I tried similar but could not get it to work, perhaps problem with my double quotes or something,
Ill try again. Have never seen either of your links, were both posted a couple of months before I joined D9. Again, thanks. PS, Modesty would have prevented me answering such a request, I see you suffer from no such impediment.
#30 | Link |
ShowChannels v0.5, new version, see 1st post.
#31 | Link |
@Jmac698,
I see you there on-line, thought that you may have missed the ShowChannels update to 0.5, implemented x,y,w,h coords (any coords even for eg YV12) as requested. Dont think that you saw it as only 1 download and think that was a moderator.
#32 | Link |
ShowChannels() v0.6 - 05 Dec 2012, Plugin for Avisynth 2.5+
Planar, YUY2 and RGB. v0.5, 31 Oct 2012, Added x,y,w,h coords, not colorspace restricted (real pain in the bum to implement). Can use odd coords for eg YV12, and even sample a single pixel. v0.6, 05 Dec 2012. Added Interlaced arg for Planar only. Now gets correct chroma for planar interlaced , even down to single pixel. (an even bigger pain in the bum to implement, modest speed improvement) See 1st post. EDIT: Other colorspaces dont require the interlaced arg. (You owe me big-time Jmac ).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 6th December 2012 at 02:07. |
#33 | Link |
ShowChannels() v0.7 - 20 Apr 2013
Updated for Avisynth v2.60. v2.58 & v2.60 dll's. See 1st post.
#34 | Link |
Script to create log file containing info on each frame
Avisource("D:\avs\test.avi").Trim(0,9)
ShowChannels(SetVar=True,Accfile="SC_WholeClip.Log")
S="""String(current_frame)+"]" + \
"YAve="+String(SC_Ave_0,"%6.2f")+"," + \
"YMin="+String(SC_Min_0,"%3.f")+"," + \
"YMax="+String(SC_Max_0,"%3.f")+"," + \
"YLmn="+String(SC_LMn_0,"%3.f")+"," + \
"YLmx="+String(SC_LMx_0,"%3.f")+"," + \
"UAve="+String(SC_Ave_1,"%6.2f")+"," + \
"UMin="+String(SC_Min_1,"%3.f")+"," + \
"UMax="+String(SC_Max_1,"%3.f")+"," + \
"ULmn="+String(SC_LMn_1,"%3.f")+"," + \
"ULmx="+String(SC_LMx_1,"%3.f")+"," + \
"VAve="+String(SC_Ave_2,"%6.2f")+"," + \
"VMin="+String(SC_Min_2,"%3.f")+"," + \
"VMax="+String(SC_Max_2,"%3.f")+"," + \
"VLmn="+String(SC_LMn_2,"%3.f")+"," + \
"VLmx="+String(SC_LMx_2,"%3.f")
WriteFile("Frame.log", S, flush=true)
Frame log, 1st 10 frames only Code:
0]YAve= 75.13,YMin= 26,YMax=212,YLmn= 28,YLmx=197,UAve=119.51,UMin=100,UMax=132,ULmn=102,ULmx=132,VAve=140.11,VMin=127,VMax=198,VLmn=127,VLmx=188 1]YAve= 75.91,YMin= 26,YMax=212,YLmn= 28,YLmx=198,UAve=119.39,UMin=100,UMax=132,ULmn=102,ULmx=132,VAve=140.31,VMin=127,VMax=197,VLmn=127,VLmx=188 2]YAve= 77.11,YMin= 25,YMax=213,YLmn= 28,YLmx=201,UAve=119.24,UMin=100,UMax=132,ULmn=102,ULmx=132,VAve=140.51,VMin=127,VMax=197,VLmn=127,VLmx=188 3]YAve= 77.56,YMin= 24,YMax=212,YLmn= 28,YLmx=202,UAve=119.18,UMin=100,UMax=132,ULmn=102,ULmx=132,VAve=140.61,VMin=127,VMax=199,VLmn=127,VLmx=188 4]YAve= 77.85,YMin= 24,YMax=206,YLmn= 28,YLmx=200,UAve=119.11,UMin=101,UMax=132,ULmn=102,ULmx=132,VAve=140.66,VMin=127,VMax=199,VLmn=127,VLmx=188 5]YAve= 78.01,YMin= 24,YMax=208,YLmn= 28,YLmx=199,UAve=119.10,UMin=101,UMax=132,ULmn=102,ULmx=132,VAve=140.67,VMin=126,VMax=199,VLmn=127,VLmx=189 6]YAve= 77.79,YMin= 22,YMax=203,YLmn= 28,YLmx=198,UAve=119.13,UMin=101,UMax=132,ULmn=101,ULmx=132,VAve=140.55,VMin=127,VMax=197,VLmn=127,VLmx=189 7]YAve= 76.34,YMin= 21,YMax=200,YLmn= 28,YLmx=197,UAve=119.42,UMin=101,UMax=132,ULmn=101,ULmx=132,VAve=140.20,VMin=127,VMax=197,VLmn=127,VLmx=188 8]YAve= 74.68,YMin= 22,YMax=199,YLmn= 28,YLmx=195,UAve=119.75,UMin=101,UMax=132,ULmn=101,ULmx=132,VAve=139.80,VMin=127,VMax=198,VLmn=127,VLmx=188 9]YAve= 73.02,YMin= 22,YMax=200,YLmn= 28,YLmx=194,UAve=120.06,UMin=101,UMax=132,ULmn=101,ULmx=132,VAve=139.44,VMin=127,VMax=199,VLmn=127,VLmx=188 Code:
SC_AAve_0=76.339836 SC_AMin_0=21 SC_AMax_0=213 SC_ALMn_0=28 SC_ALMx_0=202 SC_AAve_1=119.388771 SC_AMin_1=100 SC_AMax_1=132 SC_ALMn_1=101 SC_ALMx_1=132 SC_AAve_2=140.285110 SC_AMin_2=126 SC_AMax_2=199 SC_ALMn_2=127 SC_ALMx_2=189 SC_Visited=10
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 21st May 2013 at 12:25. |
#35 | Link |
ShowChannels v0.8, See 1st post.
v0.8, 30 Mar 2015, v2.6 dll compiled with Avisynth Version 6 Header.
#37 | Link |
Hello,
Thanks for writing this plugin. I find it very useful. Currently making use of this, this time for analyzing camera sensor noise in RAW frames. Basically want to answer the question, how many frames must I average for a given ISO to produce a noiseless picture, also to compute myself bias frames etc. (which are slight offsets as not every pixel is perfectly the same). The addition of area parameters is really useful, because on the sensor a certain area is covered up by metal so that it's always completely dark, that is used for a calibration. With the accumulated average, I can simply step through images, averaging them, until the MinMax reads 1 (or std dev reads some low value etc.). Read off the frame number, and that's the number of shots I need. |
#38 | Link |
Showchannels() v0.09, new version see 1st post.
v0.9, 15 Jan 2019, Moved to VS2008, Added version resource + x64.
#40 | Link | |
If I have a 720 x 480 AR, and want to select the area that would exclude 5% (36 pixels) along each edge, essentially analyzing the center 648 x 408 area, would I phrase the x,y,w,h coordinates as follows: ShowChannels(36, 36, 648, 408) |
| Tags |
| channels, info, max, min |
| Thread Tools | |
| Display Modes | |
