2nd August 2019, 11:27 | #22 | Link |
Seems to be the best version so far.
12th November 2019, 16:55 | #23 | Link |
When I try to update the package_file, I get the following error :
d:\programs\AVSRepo>avsrepo update Traceback (most recent call last): File "vsrepo.py", line 500, in <module> File "vsrepo.py", line 419, in update_package_definition File "urllib\request.py", line 222, in urlopen File "urllib\request.py", line 531, in open File "urllib\request.py", line 641, in http_response File "urllib\request.py", line 569, in error File "urllib\request.py", line 503, in _call_chain File "urllib\request.py", line 649, in http_error_default urllib.error.HTTPError: HTTP Error 403: Forbidden [8928] Failed to execute script vsrepo I tried avsrepo with and without admin-rights. Any idea why I'm getting this "HTTP Error 403: Forbidden" ? |
12th November 2019, 17:20 | #24 | Link |
Hmm I get the same error. I don't know why (yet). For now you can download the packages.json manually here http://vsdb.top/avspackages.zip
Extract the zip and replace your old avspackages.json
12th November 2019, 21:30 | #25 | Link |
I found the problem. I use cloudflare to manage my domains and I activated the proxy some days/weeks ago. It seems that it causes some problems with python / urllib.request ... or rather cloudflare is blocking the python agent :-/
https://github.com/IATI/IATI-Standar...ite/issues/230 It should work again.
21st November 2019, 10:31 | #27 | Link |
When was it ever included in avs+?
Groucho2004 has compiled a 64bit version http://www.iol.ie/~schubert/gas/gas.html
21st November 2019, 10:48 | #28 | Link | |
28th June 2020, 12:57 | #29 | Link |
New release with some bug fixes https://github.com/theChaosCoder/AVSRepoGUI/releases
You need the latest avsrepo binary https://github.com/theChaosCoder/avsrepo/releases
24th November 2020, 00:35 | #30 | Link |
New release: Fixed a bug where it chrashed if no package file is present. Added some checks and helper messages.
2nd January 2021, 21:56 | #31 | Link |
Doom9ing since 2001
Thanks for writing this app, Chaos, this is super helpful!
If I may make a feature request: it'd be great to be able to update both x86 and x64 plugin versions at the same time with one click. In cases where certain plugins contain multiple versions made with multiple compilers (e.g. MSVC, GCC, Clang, etc) or compied with different optimization sets (e.g. SSE, AVX, AVX2, etc) - how does AVSRepo select the most appropriate one? |
2nd January 2021, 22:05 | #32 | Link | ||
avsrepo.exe -t win32 -b D:\AvisynthRepository\AVSPLUS_x86\plugins -s D:\AvisynthRepository\SCRIPTS upgrade-all avsrepo.exe -t win64 -b D:\AvisynthRepository\AVSPLUS_x64\plugins -s D:\AvisynthRepository\SCRIPTS upgrade-all pause Quote:
I may add support for it in the future but I would rather have the plugin author properly bench it and release one version of it.
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 2nd January 2021 at 22:11. |
4th January 2022, 04:35 | #33 | Link |
The link of "Plugin repo" ( https://github.com/theChaosCoder/avs...e/master/local ) from the opening post gives error.
4th January 2022, 04:46 | #34 | Link | |
https://github.com/theChaosCoder/avsrepo |
4th January 2022, 10:55 | #35 | Link |
Thx, the folder was renamed to packages https://github.com/theChaosCoder/avs...aster/packages
17th February 2022, 22:34 | #37 | Link |
Thx, should be fixed now.
19th July 2023, 22:31 | #39 | Link |
I simply forgot to update it (I haven't used avisynth in a while)
Try to update it now.
