Old 8th August 2010, 19:49   #9081  |  Link
Ch3vr0n
Check changes.txt in the BDRB folder for all the changes. If you want it to run with 1 pass again go to settings > encoder settings > and at the bottom select One Pass (CRF) Encoding or One Pass (VBR) Encoding
Ch3vr0n is offline   Reply With Quote
Old 8th August 2010, 21:14   #9082  |  Link
KarstenS
Originally Posted by Capsbackup View Post
This is definately an issue with TMT3! Does your backup also have PiP?
If you have PowerDVD, and could use IMGBurn to create an image of your backup, then load that image with Virtual clone or Daemon and play it with PowerDVD you will find there is no problem.
Better yet, if you could burn it to disc and play it on a standalone, you will also find no audio issues.
Hmm. Checked again. There is a secondary video and a secondary audio. The secondary audio I can't uncheck. Didn't saw this one because of the long list of audio tracks (a resizable window would be really nice).
Some point is interesting: After reading the orininal disc, the secondary audio gets identified by BDRB as:
AC3 Plus, Stereo, English
When I read the new iso into BDRB, it gets identified as:
DTS-Express, Stereo, English
Look at my settings. I used all options to get completely untouched sound. So there shouldn't be a change this way.
In PowerDVD it really runs without that crackling, but the original disk rund in TMT without that issue. So I think there is something that has to be done in BDRB (I hope). TMT3 is the first choise for playing movies on my driveless HTPC with W7 MediaCenter and original moviedatabase since PowerDVD don't plays folders anymore.
Originally Posted by HWK View Post
Your FFDSHOW is not a correct version. That might cause problem for Bd-Rebuilder.
As I did set up BDRB to leave sound as it is, only video stuff should get in touch with ffdshow. So I think the possibility is very low, that the issue is caused by this more actual version.
KarstenS is offline   Reply With Quote
Old 8th August 2010, 22:36   #9083  |  Link
Capsbackup
I have experienced these same audio playback issues when testing full backups to BD25 that have PiP when using TMT3. PowerDVD works fine though!
I always get perfect playback when using my standalone Sony S360.
I can't disagree that the originals do play correctly with TMT3, where BD-RB backups experience this audio track mixing/distortion.
But PowerDVD does play both correctly!
Software players are not the best test for this. This may not be in your best interest, especially if you only use PC based playback. And yes, PowerDVD does not play back from folders, where TMT3 does.
But there can be no denying that when the BD-RB backup is burned to BD-R/RE media and played back on a standalone player, it works just as the original one does.
Capsbackup is offline   Reply With Quote
Old 9th August 2010, 00:03   #9084  |  Link
Kakashi Sensei
None of the encodes I have done play back alright in TMT3. Everyone has artifacting but on my standalone it works perfect. So I can say i dont trust TMT3 or any software players to see if a backup works properly or not. Just my findings
Kakashi Sensei is offline   Reply With Quote
Old 9th August 2010, 00:58   #9085  |  Link
bole25
I processed the film I Robot, and gave me an error of failure. You can review the data to see if they find something. Maybe is for FFDSHOW VC-1 set incorrectly: [0]
Thanks
[21:26:00] BD Rebuilder v0.34.06 (beta)
  - Source:  IROBOT_US
  - Input BD size: 38,39 GB
  - Approximate total content: [04:24:14.613]
  - Target BD size: 22,66 GB
  - Windows Version: 6.0 [6001]
  - Auto Quality: Good (Very Fast), Two Pass
[21:26:00] PHASE ONE, Encoding
 - [21:26:00] Extracting A/V streams [VID_00015]
 - [21:26:01] Reencoding: VID_00015 (1 of 26)
 - [21:26:01] Collecting video information
   - Source Video: MPEG-4 (AVC), 720x480
   - Rate/Length: 29,970fps, 30 frames
 - [21:26:01] Reencoding: VID_00015, Pass 1 of 1
 - [21:26:02] Video Encode complete
 - [21:26:02] Reencoding audio tracks (if req'd)
 - [21:26:02] Multiplexing M2TS
 - [21:26:03] Extracting A/V streams [VID_00027]
 - [21:26:04] Reencoding: VID_00027 (2 of 26)
 - [21:26:04] Collecting video information
 - [21:26:04] Reencoding: VID_00027, Pass 1 of 1
 - [21:26:04] Video Encode complete
 - [21:26:04] Reencoding audio tracks (if req'd)
 - [21:26:04] Multiplexing M2TS
 - [21:26:05] Extracting A/V streams [VID_00002]
 - [21:26:06] Reencoding: VID_00002 (3 of 26)
 - [21:26:06] Collecting video information
   - Rate/Length: 23,976fps, 24 frames
   - Bitrate: 500 Kbs
 - [21:26:06] Reencoding: VID_00002, Pass 1 of 1
 - [21:26:07] Video Encode complete
 - [21:26:07] Reencoding audio tracks (if req'd)
 - [21:26:07] Multiplexing M2TS
 - [21:26:08] Extracting A/V streams [VID_00023]
 - [21:26:09] Reencoding: VID_00023 (4 of 26)
 - [21:26:09] Collecting video information
   - Rate/Length: 29,970fps, 1.135 frames
 - [21:26:09] Reencoding: VID_00023, Pass 1 of 1
 - [21:26:17] Video Encode complete
 - [21:26:17] Reencoding audio tracks (if req'd)
 - [21:26:17] Multiplexing M2TS
 - [21:26:18] Extracting A/V streams [VID_00005]
 - [21:26:20] Reencoding: VID_00005 (5 of 26)
 - [21:26:20] Collecting video information
   - Rate/Length: 29,970fps, 1.554 frames
 - [21:26:20] Reencoding: VID_00005, Pass 1 of 1
 - [21:26:35] Video Encode complete
 - [21:26:35] Reencoding audio tracks (if req'd)
 - [21:26:35] Multiplexing M2TS
 - [21:26:37] Extracting A/V streams [VID_00021]
 - [21:26:39] Reencoding: VID_00021 (6 of 26)
 - [21:26:39] Collecting video information
   - Rate/Length: 29,970fps, 1.650 frames
 - [21:26:39] Reencoding: VID_00021, Pass 1 of 1
 - [21:26:55] Video Encode complete
 - [21:26:55] Reencoding audio tracks (if req'd)
 - [21:26:55] Multiplexing M2TS
 - [21:26:56] Extracting A/V streams [VID_00016]
 - [21:26:59] Reencoding: VID_00016 (7 of 26)
 - [21:26:59] Collecting video information
   - Rate/Length: 29,970fps, 1.950 frames
 - [21:26:59] Reencoding: VID_00016, Pass 1 of 1
 - [21:27:17] Video Encode complete
 - [21:27:17] Reencoding audio tracks (if req'd)
 - [21:27:17] Multiplexing M2TS
 - [21:27:19] Extracting A/V streams [VID_00024]
 - [21:27:22] Reencoding: VID_00024 (8 of 26)
 - [21:27:22] Collecting video information
   - Rate/Length: 29,970fps, 3.205 frames
 - [21:27:22] Reencoding: VID_00024, Pass 1 of 1
 - [21:27:49] Video Encode complete
 - [21:27:49] Reencoding audio tracks (if req'd)
 - [21:27:49] Multiplexing M2TS
 - [21:27:50] Extracting A/V streams [VID_00026]
 - [21:27:56] Reencoding: VID_00026 (9 of 26)
 - [21:27:56] Collecting video information
   - Rate/Length: 29,970fps, 5.116 frames
 - [21:27:56] Reencoding: VID_00026, Pass 1 of 1
 - [21:28:39] Video Encode complete
 - [21:28:39] Reencoding audio tracks (if req'd)
 - [21:28:39] Multiplexing M2TS
 - [21:28:42] Extracting A/V streams [VID_00019]
 - [21:28:48] Reencoding: VID_00019 (10 of 26)
 - [21:28:48] Collecting video information
   - Rate/Length: 29,970fps, 5.550 frames
 - [21:28:48] Reencoding: VID_00019, Pass 1 of 1
 - [21:29:41] Video Encode complete
 - [21:29:41] Reencoding audio tracks (if req'd)
 - [21:29:41] Multiplexing M2TS
 - [21:29:46] Extracting A/V streams [VID_00010]
 - [21:29:51] Reencoding: VID_00010 (11 of 26)
 - [21:29:51] Collecting video information
   - Rate/Length: 29,970fps, 6.323 frames
 - [21:29:51] Reencoding: VID_00010, Pass 1 of 1
 - [21:30:49] Video Encode complete
 - [21:30:49] Reencoding audio tracks (if req'd)
 - [21:30:49] Multiplexing M2TS
 - [21:30:53] Extracting A/V streams [VID_00025]
 - [21:30:59] Reencoding: VID_00025 (12 of 26)
 - [21:30:59] Collecting video information
   - Rate/Length: 29,970fps, 7.340 frames
 - [21:30:59] Reencoding: VID_00025, Pass 1 of 1
 - [21:31:58] Video Encode complete
 - [21:31:58] Reencoding audio tracks (if req'd)
 - [21:31:58] Multiplexing M2TS
 - [21:32:01] Extracting A/V streams [VID_00014]
 - [21:32:08] Reencoding: VID_00014 (13 of 26)
 - [21:32:08] Collecting video information
   - Rate/Length: 29,970fps, 8.372 frames
 - [21:32:08] Reencoding: VID_00014, Pass 1 of 1
 - [21:33:27] Video Encode complete
 - [21:33:27] Reencoding audio tracks (if req'd)
 - [21:33:27] Multiplexing M2TS
 - [21:33:35] Extracting A/V streams [VID_00008]
 - [21:33:43] Reencoding: VID_00008 (14 of 26)
 - [21:33:43] Collecting video information
   - Rate/Length: 29,970fps, 9.880 frames
 - [21:33:43] Reencoding: VID_00008, Pass 1 of 1
 - [21:35:16] Video Encode complete
 - [21:35:16] Reencoding audio tracks (if req'd)
 - [21:35:16] Multiplexing M2TS
 - [21:35:25] Extracting A/V streams [VID_00018]
 - [21:35:34] Reencoding: VID_00018 (15 of 26)
 - [21:35:34] Collecting video information
   - Rate/Length: 29,970fps, 11.000 frames
 - [21:35:34] Reencoding: VID_00018, Pass 1 of 1
 - [21:37:09] Video Encode complete
 - [21:37:09] Reencoding audio tracks (if req'd)
 - [21:37:09] Multiplexing M2TS
 - [21:37:13] Extracting A/V streams [VID_00017]
 - [21:37:23] Reencoding: VID_00017 (16 of 26)
 - [21:37:23] Collecting video information
   - Rate/Length: 29,970fps, 9.655 frames
 - [21:37:23] Reencoding: VID_00017, Pass 1 of 1
 - [21:38:55] Video Encode complete
 - [21:38:55] Reencoding audio tracks (if req'd)
 - [21:38:55] Multiplexing M2TS
 - [21:39:02] Extracting A/V streams [VID_00020]
 - [21:39:11] Reencoding: VID_00020 (17 of 26)
 - [21:39:11] Collecting video information
   - Rate/Length: 29,970fps, 10.465 frames
 - [21:39:11] Reencoding: VID_00020, Pass 1 of 1
 - [21:40:47] Video Encode complete
 - [21:40:47] Reencoding audio tracks (if req'd)
 - [21:40:47] Multiplexing M2TS
 - [21:40:53] Extracting A/V streams [VID_00009]
 - [21:41:04] Reencoding: VID_00009 (18 of 26)
 - [21:41:04] Collecting video information
   - Rate/Length: 29,970fps, 12.136 frames
 - [21:41:04] Reencoding: VID_00009, Pass 1 of 1
 - [21:42:52] Video Encode complete
 - [21:42:52] Reencoding audio tracks (if req'd)
 - [21:42:52] Multiplexing M2TS
 - [21:43:02] Extracting A/V streams [VID_00011]
 - [21:43:13] Reencoding: VID_00011 (19 of 26)
 - [21:43:13] Collecting video information
   - Rate/Length: 29,970fps, 12.880 frames
 - [21:43:13] Reencoding: VID_00011, Pass 1 of 1
 - [21:45:13] Video Encode complete
 - [21:45:13] Reencoding audio tracks (if req'd)
 - [21:45:13] Multiplexing M2TS
 - [21:45:18] Extracting A/V streams [VID_00028]
 - [21:45:29] Reencoding: VID_00028 (20 of 26)
 - [21:45:29] Collecting video information
   - Rate/Length: 29,970fps, 12.204 frames
 - [21:45:29] Reencoding: VID_00028, Pass 1 of 1
 - [21:47:08] Video Encode complete
 - [21:47:08] Reencoding audio tracks (if req'd)
 - [21:47:08] Multiplexing M2TS
 - [21:47:12] Extracting A/V streams [VID_00006]
 - [21:47:26] Reencoding: VID_00006 (21 of 26)
 - [21:47:26] Collecting video information
   - Rate/Length: 29,970fps, 16.588 frames
 - [21:47:26] Reencoding: VID_00006, Pass 1 of 1
 - [21:50:04] Video Encode complete
 - [21:50:04] Reencoding audio tracks (if req'd)
 - [21:50:04] Multiplexing M2TS
 - [21:50:18] Extracting A/V streams [VID_00013]
 - [21:50:35] Reencoding: VID_00013 (22 of 26)
 - [21:50:35] Collecting video information
   - Rate/Length: 29,970fps, 19.240 frames
 - [21:50:35] Reencoding: VID_00013, Pass 1 of 1
 - [21:53:27] Video Encode complete
 - [21:53:27] Reencoding audio tracks (if req'd)
 - [21:53:27] Multiplexing M2TS
 - [21:53:41] Extracting A/V streams [VID_00012]
 - [21:54:00] Reencoding: VID_00012 (23 of 26)
 - [21:54:00] Collecting video information
   - Rate/Length: 29,970fps, 23.710 frames
 - [21:54:00] Reencoding: VID_00012, Pass 1 of 1
 - [21:57:42] Video Encode complete
 - [21:57:42] Reencoding audio tracks (if req'd)
 - [21:57:42] Multiplexing M2TS
 - [21:58:02] Extracting A/V streams [VID_00007]
 - [21:58:23] Reencoding: VID_00007 (24 of 26)
 - [21:58:23] Collecting video information
   - Rate/Length: 29,970fps, 26.964 frames
 - [21:58:23] Reencoding: VID_00007, Pass 1 of 1
 - [22:02:28] Video Encode complete
 - [22:02:28] Reencoding audio tracks (if req'd)
 - [22:02:28] Multiplexing M2TS
 - [22:02:49] Extracting A/V streams [VID_00022]
 - [22:03:34] Reencoding: VID_00022 (25 of 26)
 - [22:03:34] Collecting video information
   - Rate/Length: 29,970fps, 61.865 frames
 - [22:03:34] Reencoding: VID_00022, Pass 1 of 1
 - [22:12:30] Video Encode complete
 - [22:12:30] Reencoding audio tracks (if req'd)
 - [22:12:30] Multiplexing M2TS
 - [22:12:55] Extracting A/V streams [VID_00001]
 - [22:21:41] Reencoding: VID_00001 (26 of 26)
 - [22:21:41] Collecting video information
   - Rate/Length: 23,976fps, 165.033 frames
   - Bitrate: 14.334 Kbs
 - [22:21:41] Reencoding: VID_00001, Pass 1 of 1
  - Encode failed.  Retrying.
  - Reached retry limit.  Aborting.
  - BD-Rebuilder v0.34.06 (beta)
  - AVISYNTH Version: 2.5.7.0, Ok
  - HAALI Splitter:  Ok
  - FFDSHOW: 3133, Ok
  - FFDSHOW VC-1 set incorrectly: [0]
  - FFDSHOW MPEG2 set to "libavcodec":  Ok
  - FFDSHOW AVC set to "libavcodec":  Ok
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
[22:24:44] - Failed video encode, aborted
bole25 is offline   Reply With Quote
Old 9th August 2010, 01:57   #9086  |  Link
jdobbs
Thanks
  - Source:  IROBOT_US
   - Bitrate: 500 Kbs
  - FFDSHOW: 3133, Ok
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
That means something is very definitely misconfigured. Reinstall following the instructions in the first post.
jdobbs.softworks@gmail.com
Old 9th August 2010, 02:36   #9087  |  Link
wooper
Hi, i am having this error try to rebuild a movie, i checked everything with the inspector and it says that averything is ok, so what can i do??
[20:10:22] BD Rebuilder v0.34.06 (beta)
- Source: 3MEN
- Input BD size: 20.80 GB
- Approximate total content: [01:44:05.238]
- Target BD size: 7.84 GB
- Windows Version: 6.1 [7600]
- MOVIE-ONLY mode enabled
- Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640
[20:10:22] PHASE ONE, Encoding
- [20:10:22] Extracting A/V streams [VID_00074]
- [20:21:18] Reencoding: VID_00074 (1 of 1)
- [20:21:18] Collecting video information
- Rate/Length: 23.976fps, 149,736 frames
- Bitrate: 7,311 Kbs
- [20:21:18] Reencoding: VID_00074, Pass 1 of 2
- AVISYNTH Version: 2.5.8.0, Ok
- HAALI Splitter: Isn't recommended version
- FFDSHOW: 3326, Ok
- WIN7 preferred AVC CODEC: Ok
- WIN7 preferred VC-1 CODEC: Ok
- WIN7 preferred MPEG2 CODEC: Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libmpeg2": Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[20:24:23] - Failed video encode, aborted
wooper is offline   Reply With Quote
Old 9th August 2010, 02:47   #9088  |  Link
setarip_old
setarip_old's Avatar
@wooper
Hi!
Source: 3MEN_WWW.SVERDOS.COM
The apparent nature of your source material makes for nothing but guessing as to what the problem might be...
setarip_old is offline   Reply With Quote
Old 9th August 2010, 03:08   #9089  |  Link
wooper
I have another problem, i tried to rebuild wall e and it sends me this error, an ideas?
[20:39:43] BD Rebuilder v0.34.06 (beta)
- Source: QUACK_D1_CAN
- Input BD size: 22.84 GB
- Approximate total content: [01:38:11.927]
[20:39:43] PHASE ONE, Encoding
- [20:39:43] Extracting A/V streams [VID_00000]
- Extracting A/V to M2TS [VID_00000]
- Extracting A/V from M2TS [VID_00000]
- Error in attempt to extract audio/subs.
- Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: G:\PELICULAS BD\WALL E RECODIFICADO\WORKFILES\00000.M2TS
[20:46:19] - Failed to retrieve audio, aborted
Old 9th August 2010, 03:13   #9090  |  Link
wooper
Originally Posted by setarip_old View Post
@wooper
Hi! The apparent nature of your source material makes for nothing but guessing as to what the problem might be...
mmm didnt get that, are you saying that changing the title of the folder might work?? well i dont think thats the problem because i have rebuilded more movies from that page and eveything was perfect, just this one i have problems
Old 9th August 2010, 05:55   #9091  |  Link
ebjones
..Anyone?
Originally Posted by ebjones View Post
I've ran into a problem backing up "The Warlords". My PS3 recognizes my BD-R and it appears to start, but then the screen goes blank/black and I'm unable to do anything except quit the movie. I have used the same settings for all my jobs and have backed up other titles since "The Warlords". I ripped the contents to the harddrive w/ AnyDVD 6.6.8.0.
[04:09:07] BD Rebuilder v0.34.04 (beta)
  - Source:  THE_WARLORDS
  - Input BD size: 40.03 GB
  - Approximate total content: [04:39:47.445]
  - Target BD size: 23.24 GB
  - Audio Settings: AC3=1 DTS=0 HD=1 Kbs=640
[04:09:07] PHASE ONE, Encoding
 - [04:09:07] Extracting A/V streams [VID_00021]
 - [04:09:11] Reencoding: VID_00021 (1 of 38)
 - [04:09:11] Collecting video information
   - Rate/Length: 23.976fps, 417 frames
 - [04:09:11] Reencoding: VID_00021, Pass 1 of 1
 - [04:09:24] Video Encode complete
 - [04:09:24] Reencoding audio tracks (if req'd)
 - [04:09:24] Multiplexing M2TS
 - [04:09:31] Extracting A/V streams [VID_00031]
 - [04:09:33] Reencoding: VID_00031 (2 of 38)
 - [04:09:33] Collecting video information
   - Rate/Length: 23.976fps, 562 frames
 - [04:09:33] Reencoding: VID_00031, Pass 1 of 1
 - [04:09:50] Video Encode complete
 - [04:09:50] Reencoding audio tracks (if req'd)
 - [04:09:50] Multiplexing M2TS
 - [04:09:51] Extracting A/V streams [VID_00011]
 - [04:09:53] Reencoding: VID_00011 (3 of 38)
 - [04:09:53] Collecting video information
   - Source Video: MPEG-2, 720x480
   - Rate/Length: 29.970fps, 2,529 frames
 - [04:09:53] Reencoding: VID_00011, Pass 1 of 1
 - [04:09:59] Video Encode complete
 - [04:09:59] Reencoding audio tracks (if req'd)
 - [04:09:59] Multiplexing M2TS
 - [04:10:00] Extracting A/V streams [VID_00009]
 - [04:10:03] Reencoding: VID_00009 (4 of 38)
 - [04:10:03] Collecting video information
   - Rate/Length: 29.970fps, 2,559 frames
 - [04:10:03] Reencoding: VID_00009, Pass 1 of 1
 - [04:10:08] Video Encode complete
 - [04:10:08] Reencoding audio tracks (if req'd)
 - [04:10:08] Multiplexing M2TS
 - [04:10:09] Extracting A/V streams [VID_00010]
 - [04:10:14] Reencoding: VID_00010 (5 of 38)
 - [04:10:14] Collecting video information
   - Rate/Length: 29.970fps, 2,970 frames
 - [04:10:14] Reencoding: VID_00010, Pass 1 of 1
 - [04:10:19] Video Encode complete
 - [04:10:19] Reencoding audio tracks (if req'd)
 - [04:10:19] Multiplexing M2TS
 - [04:10:20] Extracting A/V streams [VID_00006]
 - [04:10:23] Reencoding: VID_00006 (6 of 38)
 - [04:10:23] Collecting video information
   - Rate/Length: 29.970fps, 3,040 frames
 - [04:10:23] Reencoding: VID_00006, Pass 1 of 1
 - [04:10:29] Video Encode complete
 - [04:10:29] Reencoding audio tracks (if req'd)
 - [04:10:29] Multiplexing M2TS
 - [04:10:31] Extracting A/V streams [VID_00013]
 - [04:10:34] Reencoding: VID_00013 (7 of 38)
 - [04:10:34] Collecting video information
   - Rate/Length: 29.970fps, 3,127 frames
 - [04:10:34] Reencoding: VID_00013, Pass 1 of 1
 - [04:10:40] Video Encode complete
 - [04:10:40] Reencoding audio tracks (if req'd)
 - [04:10:40] Multiplexing M2TS
 - [04:10:41] Extracting A/V streams [VID_00007]
 - [04:10:46] Reencoding: VID_00007 (8 of 38)
 - [04:10:46] Collecting video information
   - Rate/Length: 29.970fps, 3,257 frames
 - [04:10:46] Reencoding: VID_00007, Pass 1 of 1
 - [04:10:52] Video Encode complete
 - [04:10:52] Reencoding audio tracks (if req'd)
 - [04:10:52] Multiplexing M2TS
 - [04:10:54] Extracting A/V streams [VID_00012]
 - [04:10:59] Reencoding: VID_00012 (9 of 38)
 - [04:10:59] Collecting video information
   - Rate/Length: 29.970fps, 3,355 frames
 - [04:10:59] Reencoding: VID_00012, Pass 1 of 1
 - [04:11:05] Video Encode complete
 - [04:11:05] Reencoding audio tracks (if req'd)
 - [04:11:05] Multiplexing M2TS
 - [04:11:07] Extracting A/V streams [VID_00008]
 - [04:11:12] Reencoding: VID_00008 (10 of 38)
 - [04:11:12] Collecting video information
   - Rate/Length: 29.970fps, 3,450 frames
 - [04:11:12] Reencoding: VID_00008, Pass 1 of 1
 - [04:11:18] Video Encode complete
 - [04:11:18] Reencoding audio tracks (if req'd)
 - [04:11:18] Multiplexing M2TS
 - [04:11:20] Extracting A/V streams [VID_00030]
 - [04:11:24] Reencoding: VID_00030 (11 of 38)
 - [04:11:24] Collecting video information
   - Rate/Length: 23.976fps, 930 frames
 - [04:11:24] Reencoding: VID_00030, Pass 1 of 1
 - [04:11:52] Video Encode complete
 - [04:11:52] Reencoding audio tracks (if req'd)
 - [04:11:52] Multiplexing M2TS
 - [04:11:53] Extracting A/V streams [VID_00016]
 - [04:11:58] Reencoding: VID_00016 (12 of 38)
 - [04:11:58] Collecting video information
   - Rate/Length: 29.970fps, 4,341 frames
 - [04:11:58] Reencoding: VID_00016, Pass 1 of 1
 - [04:12:05] Video Encode complete
 - [04:12:05] Reencoding audio tracks (if req'd)
 - [04:12:05] Multiplexing M2TS
 - [04:12:07] Extracting A/V streams [VID_00005]
 - [04:12:10] Reencoding: VID_00005 (13 of 38)
 - [04:12:10] Collecting video information
   - Rate/Length: 29.970fps, 6,605 frames
 - [04:12:10] Reencoding: VID_00005, Pass 1 of 1
 - [04:12:22] Video Encode complete
 - [04:12:22] Reencoding audio tracks (if req'd)
 - [04:12:22] Multiplexing M2TS
 - [04:12:25] Extracting A/V streams [VID_00018]
 - [04:12:30] Reencoding: VID_00018 (14 of 38)
 - [04:12:30] Collecting video information
   - Rate/Length: 29.970fps, 4,560 frames
 - [04:12:30] Reencoding: VID_00018, Pass 1 of 1
 - [04:12:37] Video Encode complete
 - [04:12:37] Reencoding audio tracks (if req'd)
 - [04:12:37] Multiplexing M2TS
 - [04:12:39] Extracting A/V streams [VID_00015]
 - [04:12:44] Reencoding: VID_00015 (15 of 38)
 - [04:12:44] Collecting video information
   - Rate/Length: 29.970fps, 4,590 frames
 - [04:12:44] Reencoding: VID_00015, Pass 1 of 1
 - [04:12:53] Video Encode complete
 - [04:12:53] Reencoding audio tracks (if req'd)
 - [04:12:53] Multiplexing M2TS
 - [04:12:55] Extracting A/V streams [VID_00023]
 - [04:13:00] Reencoding: VID_00023 (16 of 38)
 - [04:13:00] Collecting video information
   - Rate/Length: 23.976fps, 1,246 frames
 - [04:13:00] Reencoding: VID_00023, Pass 1 of 1
 - [04:13:37] Video Encode complete
 - [04:13:37] Reencoding audio tracks (if req'd)
 - [04:13:37] Multiplexing M2TS
 - [04:13:39] Extracting A/V streams [VID_00029]
 - [04:13:45] Reencoding: VID_00029 (17 of 38)
 - [04:13:45] Collecting video information
   - Rate/Length: 23.976fps, 1,402 frames
 - [04:13:45] Reencoding: VID_00029, Pass 1 of 1
 - [04:14:26] Video Encode complete
 - [04:14:26] Reencoding audio tracks (if req'd)
 - [04:14:26] Multiplexing M2TS
 - [04:14:27] Extracting A/V streams [VID_00017]
 - [04:14:34] Reencoding: VID_00017 (18 of 38)
 - [04:14:34] Collecting video information
   - Rate/Length: 29.970fps, 5,510 frames
 - [04:14:34] Reencoding: VID_00017, Pass 1 of 1
 - [04:14:43] Video Encode complete
 - [04:14:43] Reencoding audio tracks (if req'd)
 - [04:14:43] Multiplexing M2TS
 - [04:14:45] Extracting A/V streams [VID_00027]
 - [04:14:52] Reencoding: VID_00027 (19 of 38)
 - [04:14:52] Collecting video information
   - Rate/Length: 23.976fps, 1,508 frames
 - [04:14:52] Reencoding: VID_00027, Pass 1 of 1
 - [04:15:37] Video Encode complete
 - [04:15:37] Reencoding audio tracks (if req'd)
 - [04:15:37] Multiplexing M2TS
 - [04:15:38] Extracting A/V streams [VID_00508]
 - [04:15:45] Reencoding: VID_00508 (20 of 38)
 - [04:15:45] Collecting video information
   - Rate/Length: 29.970fps, 1,859 frames
 - [04:15:45] Reencoding: VID_00508, Pass 1 of 1
 - [04:16:39] Video Encode complete
 - [04:16:39] Reencoding audio tracks (if req'd)
 - [04:16:39] Multiplexing M2TS
 - [04:16:41] Extracting A/V streams [VID_00014]
 - [04:16:49] Reencoding: VID_00014 (21 of 38)
 - [04:16:49] Collecting video information
   - Rate/Length: 29.970fps, 6,705 frames
 - [04:16:49] Reencoding: VID_00014, Pass 1 of 1
 - [04:17:02] Video Encode complete
 - [04:17:02] Reencoding audio tracks (if req'd)
 - [04:17:02] Multiplexing M2TS
 - [04:17:04] Extracting A/V streams [VID_00020]
 - [04:17:14] Reencoding: VID_00020 (22 of 38)
 - [04:17:14] Collecting video information
   - Rate/Length: 29.970fps, 9,272 frames
 - [04:17:14] Reencoding: VID_00020, Pass 1 of 1
 - [04:17:31] Video Encode complete
 - [04:17:31] Reencoding audio tracks (if req'd)
 - [04:17:31] Multiplexing M2TS
 - [04:17:34] Extracting A/V streams [VID_00032]
 - [04:17:44] Reencoding: VID_00032 (23 of 38)
 - [04:17:44] Collecting video information
   - Rate/Length: 23.976fps, 2,538 frames
 - [04:17:44] Reencoding: VID_00032, Pass 1 of 1
 - [04:18:54] Video Encode complete
 - [04:18:54] Reencoding audio tracks (if req'd)
 - [04:18:54] Multiplexing M2TS
 - [04:18:56] Extracting A/V streams [VID_00019]
 - [04:19:06] Reencoding: VID_00019 (24 of 38)
 - [04:19:06] Collecting video information
   - Rate/Length: 29.970fps, 10,470 frames
 - [04:19:06] Reencoding: VID_00019, Pass 1 of 1
 - [04:19:25] Video Encode complete
 - [04:19:25] Reencoding audio tracks (if req'd)
 - [04:19:25] Multiplexing M2TS
 - [04:19:29] Extracting A/V streams [VID_00024]
 - [04:19:42] Reencoding: VID_00024 (25 of 38)
 - [04:19:42] Collecting video information
   - Rate/Length: 23.976fps, 2,863 frames
 - [04:19:42] Reencoding: VID_00024, Pass 1 of 1
 - [04:21:09] Video Encode complete
 - [04:21:09] Reencoding audio tracks (if req'd)
 - [04:21:09] Multiplexing M2TS
 - [04:21:13] Extracting A/V streams [VID_00521]
 - [04:21:26] Reencoding: VID_00521 (26 of 38)
 - [04:21:26] Collecting video information
   - Rate/Length: 23.976fps, 2,939 frames
 - [04:21:26] Reencoding: VID_00521, Pass 1 of 1
 - [04:22:31] Video Encode complete
 - [04:22:31] Reencoding audio tracks (if req'd)
 - [04:22:31] Multiplexing M2TS
 - [04:22:35] Extracting A/V streams [VID_00522]
 - [04:22:50] Reencoding: VID_00522 (27 of 38)
 - [04:22:50] Collecting video information
   - Rate/Length: 23.976fps, 3,117 frames
 - [04:22:50] Reencoding: VID_00522, Pass 1 of 1
 - [04:24:08] Video Encode complete
 - [04:24:08] Reencoding audio tracks (if req'd)
 - [04:24:08] Multiplexing M2TS
 - [04:24:11] Extracting A/V streams [VID_00028]
 - [04:24:26] Reencoding: VID_00028 (28 of 38)
 - [04:24:26] Collecting video information
   - Rate/Length: 23.976fps, 3,601 frames
 - [04:24:26] Reencoding: VID_00028, Pass 1 of 1
 - [04:26:11] Video Encode complete
 - [04:26:11] Reencoding audio tracks (if req'd)
 - [04:26:11] Multiplexing M2TS
 - [04:26:14] Extracting A/V streams [VID_00523]
 - [04:26:30] Reencoding: VID_00523 (29 of 38)
 - [04:26:30] Collecting video information
   - Rate/Length: 23.976fps, 3,105 frames
 - [04:26:30] Reencoding: VID_00523, Pass 1 of 1
 - [04:27:54] Video Encode complete
 - [04:27:54] Reencoding audio tracks (if req'd)
 - [04:27:54] Multiplexing M2TS
 - [04:27:59] Extracting A/V streams [VID_00520]
 - [04:28:14] Reencoding: VID_00520 (30 of 38)
 - [04:28:14] Collecting video information
   - Rate/Length: 23.976fps, 3,020 frames
 - [04:28:14] Reencoding: VID_00520, Pass 1 of 1
 - [04:29:31] Video Encode complete
 - [04:29:31] Reencoding audio tracks (if req'd)
 - [04:29:31] Multiplexing M2TS
 - [04:29:35] Extracting A/V streams [VID_00026]
 - [04:29:56] Reencoding: VID_00026 (31 of 38)
 - [04:29:56] Collecting video information
   - Rate/Length: 23.976fps, 3,703 frames
 - [04:29:56] Reencoding: VID_00026, Pass 1 of 1
 - [04:31:54] Video Encode complete
 - [04:31:55] Reencoding audio tracks (if req'd)
 - [04:31:55] Multiplexing M2TS
 - [04:31:58] Extracting A/V streams [VID_00003]
 - [04:32:22] Reencoding: VID_00003 (32 of 38)
 - [04:32:22] Collecting video information
   - Rate/Length: 29.970fps, 31,963 frames
 - [04:32:22] Reencoding: VID_00003, Pass 1 of 1
 - [04:33:21] Video Encode complete
 - [04:33:21] Reencoding audio tracks (if req'd)
 - [04:33:21] Multiplexing M2TS
 - [04:33:29] Extracting A/V streams [VID_00004]
 - [04:34:01] Reencoding: VID_00004 (33 of 38)
 - [04:34:02] Collecting video information
   - Rate/Length: 29.970fps, 8,346 frames
 - [04:34:02] Reencoding: VID_00004, Pass 1 of 1
 - [04:38:06] Video Encode complete
 - [04:38:06] Reencoding audio tracks (if req'd)
 - [04:38:06] Multiplexing M2TS
 - [04:38:16] Extracting A/V streams [VID_00001]
 - [04:38:58] Reencoding: VID_00001 (34 of 38)
 - [04:38:58] Collecting video information
   - Rate/Length: 29.970fps, 49,040 frames
 - [04:38:58] Reencoding: VID_00001, Pass 1 of 1
 - [04:40:19] Video Encode complete
 - [04:40:19] Reencoding audio tracks (if req'd)
 - [04:40:19] Multiplexing M2TS
 - [04:40:31] Extracting A/V streams [VID_00025]
 - [04:41:17] Reencoding: VID_00025 (35 of 38)
 - [04:41:17] Collecting video information
   - Rate/Length: 23.976fps, 7,962 frames
 - [04:41:17] Reencoding: VID_00025, Pass 1 of 1
 - [04:45:20] Video Encode complete
 - [04:45:20] Reencoding audio tracks (if req'd)
 - [04:45:21] Multiplexing M2TS
 - [04:45:30] Extracting A/V streams [VID_00002]
 - [04:46:30] Reencoding: VID_00002 (36 of 38)
 - [04:46:31] Collecting video information
   - Rate/Length: 29.970fps, 63,636 frames
 - [04:46:31] Reencoding: VID_00002, Pass 1 of 1
 - [04:48:26] Video Encode complete
 - [04:48:26] Reencoding audio tracks (if req'd)
 - [04:48:26] Multiplexing M2TS
 - [04:48:40] Extracting A/V streams [VID_00022]
 - [04:50:02] Reencoding: VID_00022 (37 of 38)
 - [04:50:02] Collecting video information
   - Rate/Length: 23.976fps, 15,628 frames
 - [04:50:03] Reencoding: VID_00022, Pass 1 of 1
 - [04:58:00] Video Encode complete
 - [04:58:00] Reencoding audio tracks (if req'd)
 - [04:58:00] Multiplexing M2TS
 - [04:58:37] Extracting A/V streams [VID_00000]
 - [05:13:11] Reencoding: VID_00000 (38 of 38)
 - [05:13:11] Collecting video information
   - Rate/Length: 23.976fps, 163,008 frames
   - Bitrate: 16,370 Kbs
 - [05:13:11] Reencoding: VID_00000, Pass 1 of 2
 - [05:13:11] Reencoding: VID_00000, Pass 2 of 2
 - [06:34:41] Video Encode complete
 - [06:34:41] Reencoding audio tracks (if req'd)
 - [06:34:41] Multiplexing M2TS
[06:42:55]PHASE ONE complete
[06:42:55]PHASE TWO - Rebuild Started
 - [06:42:55] Rebuilding BD file Structure
[06:43:14] - Encode and Rebuild complete
 - WORKFILES folder removed.
[06:43:16]JOB: THE_WARLORDS finished.
ebjones is offline   Reply With Quote
Old 9th August 2010, 07:37   #9092  |  Link
KarstenS
This is the first backup not running right with TMT3 for me.
Me not.
Old 9th August 2010, 10:13   #9093  |  Link
By-Tor
- Source: 3MEN_WWW.SVERDOS.COM
- HAALI Splitter: Isn't recommended version......
- FFDSHOW: 3326, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
you're using the incorrect HAALI Splitter !!!!!!!!!!!
By-Tor is offline   Reply With Quote
Old 9th August 2010, 13:35   #9094  |  Link
jdobbs
- FFDSHOW: 3326, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
C'mon. It's telling you what your problem is.
Old 9th August 2010, 15:29   #9095  |  Link
wooper
ok, its de haali version, but i am confuse when does bd rebuilder sometimes uses and sometimes not, because I recoded another movie after i sent you this error and everything was perfect, so is there a problem with some movies? isnt all encoded with same codec?
thanks
Old 9th August 2010, 15:40   #9096  |  Link
jdobbs
thanks
If you use the right software it works all the time. If you use the wrong software, there's no telling what could or could not happen or when it might or might not happen.
No. They don't all use the same codec. There are numerous codecs in use for video and audio -- and they all have to be decoded from their original state (frameserving) in order to be reencoded. HAALI is part of the splitting/decoding process.
The solution is simple. Don't try to outsmart the system, use the right software, and it will work every time. My biggest support headache is folks who decide they know better than everybody else and "upgrade". If you look back through this thread you'll see at least 500 posts where the "bug" an incorrect software version.
Old 9th August 2010, 16:01   #9097  |  Link
wooper
ooo ok, i will check constantly if i have the lastest versions of the software need, thanks for everything.
something else, i have an error related with the container streams are not syncronized, mmm i dont know much about this, is it saying that the parts of those m2ts are not in correct order? or something with the frames?, can i use another tool to make again the m2ts and the try to use br rebuilder again?
Old 9th August 2010, 16:59   #9098  |  Link
wooper
ok I downloaded the latest version of matroska splitter, installed and still, i am getting in the inspect control, that haali isnt the recommended version, I downloaded the archive that is in the first post of the forum but how can i use those files, it says realesed and inside is a matrokaspliter.ax, do i have to copy it and paste in the haali folder? because i checked that folder and i didnt find any other files called matroskaspliter.ax just spliter.ax
Old 9th August 2010, 17:55   #9099  |  Link
Capsbackup
Uninstall your current version of haali. Then go the the Programs folder and delete the folder Haali. Reboot.
Now install the recommended version from the first post of this thread.
Old 9th August 2010, 18:44   #9100  |  Link
videoadvocate
I'm sorry if this is posted somewhere but I don't see it. Where can I get a copy of this older version of BDRB ??
Originally Posted by MB2 View Post
jdobbs, the star trek season 3 disc 2 finished ok on 31.06
videoadvocate is offline   Reply With Quote
