#29121 | Link |
Noticed that, too ...
If set to "Automatic Quality Settings", there's only one pass You might want to uncheck that and then go to encoder settings again and uncheck any "one pass...", then you get two passes ... which will take even longer ![]() @jdobbs: is there a reason for the strange sorting in the encoder quality menu? (Good is below Highest, but it seems to belong to the top?) |
#29123 | Link | |||
#29124 | Link | |
#29125 | Link |
![]() Join Date: Oct 2001
The last couple of encode options got added after the fact... so they are out of sequence. I just didn't feel like having to go back through the code and change the numbering for every reference. Normally "Good" doesn't even show as an option (until you use it by manually setting it in the INI). There's also an "Ultra-High (Extremely Slow)" setting that you can use by manually setting your INI value to 4.
jdobbs.softworks@gmail.com Last edited by jdobbs; 4th January 2020 at 17:40. |
#29126 | Link |
Here's a piece of information I discovered that I think is interesting. The HEVC codec, according to UHD-BD spec is meant to be used only with 2160p and 1080p sources and those two resolutions are all that is supposed to be supported. But... the settings in the MPLS and CLPI files include other formats. So I did some experimenting... and low and behold, I can create a disc that uses the HEVC codec on 480/576 and 720p sources -- and my Sony UHD-BD Player accepts it and plays it back just as if it were meant to do so.
That's a big deal if you are trying to backup some old DVDs (like series discs) onto BD, as HEVC is much more efficient (especially at low bitrates) and you can fit a LOT of old episodes on a 50GB disc when using it. Just thought I'd mention it. If someone else would like to try it... I'd be interested to know if other players accept it as well. You can do it with the new TSMUXER using the --blu-ray-v3 setting. The only thing I noticed that is a little odd is that it seems to always assume a 16:9 aspect ratio (which can be fixed with a little patching). If it appears to be universal among players, I may add it as an option in BD-RB (with a warning that it isn't actually within spec).
jdobbs.softworks@gmail.com |
#29127 | Link |
Big Bit Savings Now !
Good find ! I shall try this on a UDP-205.
As soon as you have a BD-RB test version ready, please let me know. Edit: Now I see, I shall try using tsMuxeR 2.6.15 first so that you can implement it in BD-RB if sucess can be reported.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 8th January 2020 at 11:32. |
#29128 | Link |
BD Rebuilder v0.61.03
I have updated the first post of this thread with a link to the most recent version of BD-RB (v0.61.03). Changes for this release:
- Updated the included TSMUXER4K version to the most current release that supports UHD. This should fix dolbyvision problems experienced in 61.01. If you added UHD_TSMUXER=0 to your your INI -- it should be removed in order to enable the new TSMUXER version. - Corrected an issue in which performing a build with UHD_TSMUXER=0 could result in a "Error in attempt to create UHD CLPI" error - Fixed a rare issue associated with importing an MPEG-2 source with telecined video. - Modified alternate build routine so that SRT files that are kept are limited to those selected in the SETUP dialog. - Other minor corrections and cosmetic fixes.
#29129 | Link |
Nothing has changed with the new version. My Sony X800M2 plays DV Rebuilds only in HDR , when DV is off. When I turn DV on the Sony on, the main film is black.
DV remuxes of the main film with the last tsmuxer plays my Sony without problems. Code:
[01.11.20] BD Rebuilder v0.61.03 [15:17:05] Source: COLD_PURSUIT - Input BD size: 78,62 GB - Approximate total content: [02:04:46.291] - Target BD size: 46,26 GB - Windows Version: 6.2 [9200] - Quality: Good (Fastest, BD-25+), ABR - Decoding/Frame serving: FFMPEG - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 [15:17:07] PHASE ONE, Encoding - [15:17:07] Processing: VID_00000 (1 of 14) - [15:17:07] Extracting A/V streams [VID_00000] - [15:17:11] Reencoding video [VID_00000] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 1.046 frames - Bitrate: 24.020 Kbs - [15:17:11] Reencoding: VID_00000, Pass 1 of 1 - [15:19:04] Video Encode complete - [15:19:04] Processing audio tracks - Track 4356 (deu): Keeping original audio - [15:19:04] Multiplexing M2TS - [15:19:08] Processing: VID_00001 (2 of 14) - [15:19:08] Extracting A/V streams [VID_00001] - [15:19:12] Reencoding video [VID_00001] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 631 frames - Bitrate: 9.355 Kbs - [15:19:12] Reencoding: VID_00001, Pass 1 of 1 - [15:20:04] Video Encode complete - [15:20:04] Processing audio tracks - Track 4356 (deu): Keeping original audio - [15:20:04] Multiplexing M2TS - [15:20:08] Processing: VID_00002 (3 of 14) - [15:20:08] Extracting A/V streams [VID_00002] - [15:20:31] Reencoding video [VID_00002] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 8.582 frames - Bitrate: 35.000 Kbs - [15:20:31] Reencoding: VID_00002, Pass 1 of 1 - [15:34:37] Video Encode complete - [15:34:37] Processing audio tracks - Track 4356 (deu): Keeping original audio - [15:34:37] Multiplexing M2TS - [15:34:45] Processing: VID_00003 (4 of 14) - [15:34:45] Extracting A/V streams [VID_00003] - [15:34:49] Reencoding video [VID_00003] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 211 frames - Bitrate: 35.000 Kbs - [15:34:49] Reencoding: VID_00003, Pass 1 of 1 - [15:35:16] Video Encode complete - [15:35:16] Processing audio tracks - Track 4356 (deu): Keeping original audio - [15:35:16] Multiplexing M2TS - [15:35:20] Processing: VID_00008 (5 of 14) - [15:35:20] Extracting A/V streams [VID_00008] - Extracting video streams [VID_00008] - Extracting secondary video [VID_00008] - Extracting audio/subtitle streams [VID_00008] - [15:54:17] Reencoding video [VID_00008] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 160.215 frames - Bitrate: 35.000 Kbs - [15:54:17] Reencoding: VID_00008, Pass 1 of 1 - [18:57:39] Video Encode complete - [18:57:39] Processing audio tracks - Track 4356 (deu): Keeping original audio - [18:57:39] Multiplexing M2TS [18:57:44]PHASE ONE aborted by user request ---------------------- [01.11.20] BD Rebuilder v0.61.03 [19:01:31] Source: COLD_PURSUIT - Input BD size: 78,62 GB - Approximate total content: [02:04:46.291] - Target BD size: 46,26 GB - Windows Version: 6.2 [9200] - Quality: Good (Fastest, BD-25+), ABR - Decoding/Frame serving: FFMPEG - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 - Resuming from previously started job. [19:01:32] PHASE ONE, Encoding - [19:01:32] Processing: VID_00008 (5 of 14) - [19:02:01] Multiplexing M2TS - [19:03:17] Processing: VID_00020 (6 of 14) - [19:03:17] Extracting A/V streams [VID_00020] - [19:03:21] Reencoding video [VID_00020] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 240 frames - Bitrate: 1.489 Kbs - [19:03:21] Reencoding: VID_00020, Pass 1 of 1 - [19:03:35] Video Encode complete - [19:03:36] Processing audio tracks - [19:03:36] Multiplexing M2TS - [19:03:39] Processing: VID_00021 (7 of 14) - [19:03:39] Extracting A/V streams [VID_00021] - [19:03:42] Reencoding video [VID_00021] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 167 frames - Bitrate: 1.244 Kbs - [19:03:43] Reencoding: VID_00021, Pass 1 of 1 - [19:03:53] Video Encode complete - [19:03:53] Processing audio tracks - [19:03:53] Multiplexing M2TS - [19:03:56] Processing: VID_00022 (8 of 14) - [19:03:56] Extracting A/V streams [VID_00022] - [19:04:00] Reencoding video [VID_00022] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 168 frames - Bitrate: 1.339 Kbs - [19:04:00] Reencoding: VID_00022, Pass 1 of 1 - [19:04:10] Video Encode complete - [19:04:10] Processing audio tracks - [19:04:10] Multiplexing M2TS - [19:04:13] Processing: VID_00025 (9 of 14) - [19:04:13] Extracting A/V streams [VID_00025] - [19:04:17] Reencoding video [VID_00025] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 120 frames - Bitrate: 791 Kbs - [19:04:17] Reencoding: VID_00025, Pass 1 of 1 - [19:04:25] Video Encode complete - [19:04:25] Processing audio tracks - [19:04:25] Multiplexing M2TS - [19:04:30] Processing: VID_00026 (10 of 14) - [19:04:30] Extracting A/V streams [VID_00026] - [19:04:33] Reencoding video [VID_00026] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 192 frames - Bitrate: 2.790 Kbs - [19:04:33] Reencoding: VID_00026, Pass 1 of 1 - [19:04:45] Video Encode complete - [19:04:45] Processing audio tracks - [19:04:45] Multiplexing M2TS - [19:04:48] Processing: VID_00027 (11 of 14) - [19:04:48] Extracting A/V streams [VID_00027] - [19:04:52] Reencoding video [VID_00027] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 192 frames - Bitrate: 1.400 Kbs - [19:04:52] Reencoding: VID_00027, Pass 1 of 1 - [19:05:03] Video Encode complete - [19:05:03] Processing audio tracks - [19:05:03] Multiplexing M2TS - [19:05:07] Processing: VID_00028 (12 of 14) - [19:05:07] Extracting A/V streams [VID_00028] - [19:05:10] Reencoding video [VID_00028] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 120 frames - Bitrate: 500 Kbs - [19:05:10] Reencoding: VID_00028, Pass 1 of 1 - [19:05:18] Video Encode complete - [19:05:18] Processing audio tracks - [19:05:18] Multiplexing M2TS - [19:05:21] Processing: VID_00029 (13 of 14) - [19:05:21] Extracting A/V streams [VID_00029] - [19:05:26] Reencoding video [VID_00029] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 480 frames - Bitrate: 29.360 Kbs - [19:05:26] Reencoding: VID_00029, Pass 1 of 1 - [19:06:12] Video Encode complete - [19:06:12] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:06:12] Multiplexing M2TS - [19:06:16] Processing: VID_00031 (14 of 14) - [19:06:16] Extracting A/V streams [VID_00031] - [19:06:20] Reencoding video [VID_00031] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 168 frames - Bitrate: 16.925 Kbs - [19:06:20] Reencoding: VID_00031, Pass 1 of 1 - [19:06:32] Video Encode complete - [19:06:32] Processing audio tracks - [19:06:32] Multiplexing M2TS [19:06:35]PHASE ONE complete [19:06:35]PHASE TWO - Rebuild Started - [19:06:35] Rebuilding BD file Structure [19:06:44] - Encode and Rebuild complete [19:06:44] Writing BD structure to ISO file - ImgBurn completed successfully - COLD_PURSUIT folder removed. - WORKFILES folder removed. [19:07:36] JOB: COLD_PURSUIT finished. Last edited by Michi; 11th January 2020 at 21:06. |
#29130 | Link |
BD-Rebuilder is using the last TSMUXER... (current as of yesterday), so that isn't the problem. Too bad you deleted the work folder, I'd like to see a couple of the files to see what is up. Can you post your settings so I can look at those?
jdobbs.softworks@gmail.com Last edited by jdobbs; 12th January 2020 at 13:27. |
#29131 | Link |
My bdrebuilder.ini:
[Options] VERSION=0.61.0.3 MODE=0 ENCODER_MENU=1 ENCODE_QUALITY=5 ONEPASS_ENCODING=2 AUTO_QUALITY=0 AUDIO_TO_KEEP=deu;gem;ger; SUBS_TO_KEEP=deu;gem;ger;gmh;goh;gsw; SD_CONVERT=0 OPEN_GOP=1 RESIZE_1080=0 DEINTERLACE=0 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=0 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=0 REMOVE_WORKFILES=1 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=1 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=1 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 UNMASK_CHAPTER=0 COMPLETION_BEEP=0 DGDECNV=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=66000 TARGET_SIZE=47366 AUTO_BURN=2 MOVIEONLY_TYPE=40 ALTCRF=18 ARCHIVE_265=1 ARCHIVE_AUDIO=100 ARCHIVE_CRF=16 ARCHIVE_ENABLE=1 ARCHIVE_LIMIT=1 ALT_TARGET=7800 ALTMETHOD=0 ALTAUTOCROP=0 QUICK_EXTRAS=0 OUTPUT_3D=0 RESIZE_1440=0 RESIZE_720=0 NEROAAC=0 SUPTITLE=0 IGNORE_3D=0 OUTPUT_SBS=0 ENCODER_MENU=1 HC_PROFILE=BEST IMPORT_HEVC_INTACT=1 MIN_M2TS_SIZE=20 NEW_CRF_PREDICTION=1 MULTIPROCESS=0 THREADS=auto BD5_SIZE=4520 BD9_SIZE=8200 BD25_SIZE=23200 QUALITY_ULTRA=1 FRIMSOURCE=0 ENCODER=0 DGDECIM=1 FRIM_SW_DECODE=1 FRIM_SW_ENCODE=1 PRIORITY_CLASS=1 MENU_BACKGROUND=C:\BD_Rebuilder\misc\menuback.jpg IMPORT_THRESHOLD=15 QUICK_PLAY_THRESHOLD=10 MENU_AUTO_BACKGROUND=1 MENU_PLAY_SEQUENTIAL=0 MENU_START_WITH_MENU=1 DECODER=0 AUDIO_DRC=0 MENU_AUTO_DVDAUDIO=1 IMPORT_LIMIT_LANG=0 IMPORT_KEEP_PLAYALL=0 ALT_CRF_TARGET=4000 PGSTOSRT=0 UHD_MAXRATE=60000 UHD_VBV_BUFFER=60000 TWEAK_X265=--no-open-gop --no-sao --no-slow-firstpass --no-rskip --subme 4 --weightb [Paths] SOURCE_PATH=Y:\ WORKING_PATH=Q:\4K\ |
#29133 | Link |
BD-RB should correct it on it's own when it reencodes.
#29134 | Link |
Elit Amans
@jdobbs: Have you recently tried importing mkv's?
I just encountered an error just after the "Scanning for Variable Framerate" step. Something about missing number or filename. I went back to 0.60.29 and it worked again. I'll get you a log ASAP ![]() //LD EDIT: Well There wasn't much in the log... Code:
---------------------- [01:49:08] Importing MKV: PURE_(2019)_S01E01_-_EPISODE_1 - Preparing MKV for processing... Code:
General
Unique ID : 183007012736287462016813617846879401966 (0x89ADDE5BA9BE000BA56959A4B42A37EE)
Complete name : W:\WORK\TEMPIMPORT\Pure (2019) S01E01 - Episode 1.MKV
Format : Matroska
Format version : Version 2
File size : 2.06 GiB
Duration : 33 min 16 s
Overall bit rate : 8 846 kb/s
Encoded date : UTC 2020-01-13 00:49:08
Writing application : mkvmerge v9.7.1 ('Pandemonium') 32bit
Writing library : libebml v1.3.4 + libmatroska v1.4.5
Video
Format : AVC
Format profile : Main@L4
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 8 458 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 50.000 FPS
Original frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan type, store method : Separated fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.082
Stream size : 1.97 GiB (96%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 384 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 91.4 MiB (4%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
INI: Code:
[Options] VERSION=0.61.0.3 ENCODER=0 MODE=0 ENCODE_QUALITY=3 ONEPASS_ENCODING=0 AUTO_QUALITY=0 AUDIO_TO_KEEP=deu;eng;ger;swe; SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=1 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AUDIO_DRC=0 DECODER=3 AVCHD=1 REMOVE_WORKFILES=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 IVTC_PULLDOWN=1 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 PGSTOSRT=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=8250 AUTO_BIAS=3 B_PYRAMID=1 DGDECIM_SW_DECODE=0 ENCODER_MENU=1 FRIM_SW_DECODE=0 FRIM_SW_ENCODE=0 HC_PROFILE=BEST IMPORT_HEVC_INTACT=1 KEEP_MBTREE=1 PASS_TWO_STATS_UPDATE=1 SHOW_ENCODER=1 DTSX_ENABLE=1 ENABLE_TEST=1 ENABLE_BLANKING=1 DEFAULT_LANG=eng TARGET_SIZE=8250 MIN_M2TS_SIZE=1 Code:
[01-13-20] Checking System Settings - BD-Rebuilder v0.61.03 - Windows Version: 6.2 [9200] - Working Path Free Space: 64,45GB - AVISYNTH Version: 2.6.0.5, Ok - LAVFILTERS: Ok - X264: Ok - X265: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [01-13-20] Systems Settings Check complete //LD Last edited by LowDead; 13th January 2020 at 02:03. Reason: adding info |
#29136 | Link |
Please post the contents of AVS file from the working folder and the PINFO.INF file from the PSEUDO folder (in the imported folder). That way I can see how BD-RB attempted to correct the sizing of the file.
jdobbs.softworks@gmail.com Last edited by jdobbs; 13th January 2020 at 15:42. |
#29137 | Link |
@LowDead
Yes, I import all the time. But, obviously, there is something wrong with the variable framerate scan (it doesn't get hit that often). I'll look at it and see what I find. I'll look at what changes I made between v0.60.29 and v0.61.03 to see where I screwed the pooch. Can you look and see if there is a files called "timecodes.txt" in the working folder?
jdobbs.softworks@gmail.com Last edited by jdobbs; 13th January 2020 at 15:46. |
#29138 | Link | |
I think tsmuxer from justdan96 don't work with DV. Jcdr428 tell about DV and her tsmuxer, he talk something like "DV only work in my tsmuxer". I cant't find the post, but I remember this... https://github.com/jcdr428/tsMuxer I think this don't have in tsmuxer from justdan: https://github.com/jcdr428/tsMuxer/pull/23 Last edited by zamengo; 13th January 2020 at 15:48. |
#29139 | Link | |
@Michi Try replacing the TSMUXER4K.EXE file located in the tools folder of v0.61.03 with this version and see if it has an impact on the result. You may also want to try turning off the switch to automatically delete the working folder. That way all you'd have to do is rebuild rather than run the entire process to test this.
jdobbs.softworks@gmail.com Last edited by jdobbs; 13th January 2020 at 15:57. |
#29140 | Link |
#Created by BD Rebuilder - v0.61.01
DirectshowSource("V:\Video\HP5_PHOENIX\HP5_PHOENIX.Title0.mkv", framecount=198866, ConvertFPS=true, audio=false) LoadPlugin("C:\Users\Sebastien\Desktop\Videos\BD_Rebuilder\tools\autocrop.dll") Autocrop(mode=0, hMultOf=4) ConvertToYV12().AssumeFPS(24000,1001) SelectRangeEvery(4800,48,4000) |
| Display Modes | |
