Old 29th December 2019, 20:37   #29101  |  Link
jdobbs
Originally Posted by Michi View Post
The log-file of the DV disc Cold Pursuit
Have you tried v0.61.02 yet?
jdobbs.softworks@gmail.com
Old 29th December 2019, 21:51   #29102  |  Link
Michi
Yes, I tried 61.02 and it produces the same error as 60.29.
[12.28.19] BD Rebuilder v0.61.02
[22:50:56] Source:  COLD_PURSUIT
  - Input BD size: 78,62 GB
  - Approximate total content: [02:04:46.291]
  - Target BD size: 46,26 GB
  - Windows Version: 6.2 [9200]
  - Quality: Good (Fastest, BD-25+), ABR
  - Decoding/Frame serving: FFMPEG
  - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448
[22:50:56] PHASE ONE, Encoding
 - [22:50:56] Processing: VID_00000 (1 of 14)
 - [22:50:56] Extracting A/V streams [VID_00000]
 - [22:51:01] Reencoding video [VID_00000]
   - Source Video: HEVC, 3840x2160
   - Rate/Length: 24,000fps, 1.046 frames
   - Bitrate: 24.020 Kbs
 - [22:51:01] Reencoding: VID_00000, Pass 1 of 1
 - [22:52:23] Video Encode complete
 - [22:52:23] Processing audio tracks
   - Track 4356 (deu): Keeping original audio
 - [22:52:23] Multiplexing M2TS
 - [22:52:30] Processing: VID_00001 (2 of 14)
 - [22:52:30] Extracting A/V streams [VID_00001]
 - [22:52:34] Reencoding video [VID_00001]
   - Rate/Length: 24,000fps, 631 frames
   - Bitrate: 9.355 Kbs
 - [22:52:34] Reencoding: VID_00001, Pass 1 of 1
 - [22:53:18] Video Encode complete
 - [22:53:18] Processing audio tracks
 - [22:53:18] Multiplexing M2TS
 - [22:53:22] Processing: VID_00002 (3 of 14)
 - [22:53:22] Extracting A/V streams [VID_00002]
 - [22:53:45] Reencoding video [VID_00002]
   - Rate/Length: 24,000fps, 8.582 frames
   - Bitrate: 35.000 Kbs
 - [22:53:46] Reencoding: VID_00002, Pass 1 of 1
 - [23:03:43] Video Encode complete
 - [23:03:43] Processing audio tracks
 - [23:03:43] Multiplexing M2TS
 - [23:04:39] Processing: VID_00003 (4 of 14)
 - [23:04:39] Extracting A/V streams [VID_00003]
 - [23:04:43] Reencoding video [VID_00003]
   - Rate/Length: 24,000fps, 211 frames
 - [23:04:43] Reencoding: VID_00003, Pass 1 of 1
 - [23:04:58] Video Encode complete
 - [23:04:58] Processing audio tracks
 - [23:04:58] Multiplexing M2TS
 - [23:05:03] Processing: VID_00008 (5 of 14)
 - [23:05:03] Extracting A/V streams [VID_00008]
   - Extracting video streams [VID_00008]
   - Extracting secondary video [VID_00008]
   - Extracting audio/subtitle streams [VID_00008]
 - [23:23:57] Reencoding video [VID_00008]
   - Rate/Length: 24,000fps, 160.215 frames
 - [23:23:57] Reencoding: VID_00008, Pass 1 of 1
 - [02:17:03] Video Encode complete
 - [02:17:03] Processing audio tracks
 - [02:17:03] Multiplexing M2TS
 - [02:33:31] Processing: VID_00020 (6 of 14)
 - [02:33:31] Extracting A/V streams [VID_00020]
 - [02:33:34] Reencoding video [VID_00020]
   - Rate/Length: 24,000fps, 240 frames
   - Bitrate: 1.489 Kbs
 - [02:33:34] Reencoding: VID_00020, Pass 1 of 1
 - [02:33:49] Video Encode complete
 - [02:33:49] Processing audio tracks
 - [02:33:49] Multiplexing M2TS
 - [02:33:52] Processing: VID_00021 (7 of 14)
 - [02:33:52] Extracting A/V streams [VID_00021]
 - [02:33:56] Reencoding video [VID_00021]
   - Rate/Length: 24,000fps, 167 frames
   - Bitrate: 1.244 Kbs
 - [02:33:56] Reencoding: VID_00021, Pass 1 of 1
 - [02:34:06] Video Encode complete
 - [02:34:06] Processing audio tracks
 - [02:34:06] Multiplexing M2TS
 - [02:34:11] Processing: VID_00022 (8 of 14)
 - [02:34:11] Extracting A/V streams [VID_00022]
 - [02:34:14] Reencoding video [VID_00022]
   - Rate/Length: 24,000fps, 168 frames
   - Bitrate: 1.339 Kbs
 - [02:34:14] Reencoding: VID_00022, Pass 1 of 1
 - [02:34:24] Video Encode complete
 - [02:34:24] Processing audio tracks
 - [02:34:24] Multiplexing M2TS
 - [02:34:29] Processing: VID_00025 (9 of 14)
 - [02:34:29] Extracting A/V streams [VID_00025]
 - [02:34:33] Reencoding video [VID_00025]
   - Rate/Length: 24,000fps, 120 frames
   - Bitrate: 791 Kbs
 - [02:34:33] Reencoding: VID_00025, Pass 1 of 1
 - [02:34:40] Video Encode complete
 - [02:34:40] Processing audio tracks
 - [02:34:40] Multiplexing M2TS
 - [02:34:48] UHD_Correct_M2TS() 00005  8102
[04:57:11]PHASE ONE aborted by user request
Michi is offline   Reply With Quote
Old 30th December 2019, 00:39   #29103  |  Link
Priapismic
Definitely not. The versions greater than v2.6.12 (the one included with BD-RB for download) are not stable. I am now also including a version called tsmuxer4k.exe -- which is a newer version that I have tested before including and only gets executed for UHD muxing.
If you follow the directions (exactly) as they are outlined in the first post, you should be ok. Any changes to those instructions are done at your own risk and can result in self-inflicted problems. That includes changing versions for any of the helper apps.
I just wish the post stated that the download includes tsmuxer.
Priapismic is offline   Reply With Quote
Old 30th December 2019, 01:46   #29104  |  Link
Ch3vr0n
If he were to do that and be consistent he'd have to state that it also includes a version of DGIndex, HCEncoder, FRIM, mkvextract, mkvmerge and every other x264/265 version. Can't leave those out can we?
Ch3vr0n is offline   Reply With Quote
Old 30th December 2019, 02:28   #29105  |  Link
MrVideo
MrVideo's Avatar
Originally Posted by Ch3vr0n View Post
Though perhaps my 'otherwise' could have been a bit more precise and mention the exact 'subtools' such as mp4box etc. I'll not talking about the lav filters...
Yes, it is the "otherwise" that tripped my posting.
Old 30th December 2019, 21:55   #29106  |  Link
Michi
Deumuxing error on RED2:
[19:19:34] Source:  RED_2
  - Input BD size: 59,23 GB
  - Approximate total content: [03:02:05.879]
[19:19:34] PHASE ONE, Encoding
 - [19:19:34] Processing: VID_00000 (1 of 8)
 - [19:19:34] Extracting A/V streams [VID_00000]
 - [19:27:02] Reencoding video [VID_00000]
 - [19:27:02] Keeping original video (no reencode)
 - [19:27:02] Processing audio tracks
   - Track 4352 (deu): Keeping original audio
 - [19:27:02] Multiplexing M2TS
 - [19:27:59] Processing: VID_00001 (2 of 8)
 - [19:27:59] Extracting A/V streams [VID_00001]
   - Extracting video streams [VID_00001]
   - Extracting audio/subtitle streams [VID_00001]
 - Network Optix tsMuxeR.  Version 2.6.12. www.networkoptix.com
   - Extracting audio streams [VID_00001]
 - Error in attempt to extract audio.
[19:30:37] - Failed to retrieve audio, aborted
Old 31st December 2019, 10:48   #29107  |  Link
zamengo
Multiplexing error on Joker.
[12/29/19] BD Rebuilder v0.61.01
[17:56:19] Source:  JOKER
  - Input BD size: 53.28 GB
  - Approximate total content: [02:13:01.807]
  - Target BD size: 22.95 GB
  - Auto Quality: Very Good (Very Fast), ABR
  - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=448
[17:56:19] PHASE ONE, Encoding
 - [17:56:19] Processing: VID_00004 (1 of 2)
 - [17:56:19] Extracting A/V streams [VID_00004]
 - [17:56:34] Reencoding video [VID_00004]
   - Rate/Length: 23.976fps, 8,160 frames
   - Bitrate: 5,652 Kbs
 - [17:56:34] Reencoding: VID_00004, Pass 1 of 1
 - [18:18:44] Video Encode complete
 - [18:18:44] Processing audio tracks
 - [18:18:44] Multiplexing M2TS
 - [18:18:49] Processing: VID_00014 (2 of 2)
 - [18:18:49] Extracting A/V streams [VID_00014]
   - Extracting video streams [VID_00014]
   - Extracting secondary video [VID_00014]
   - Extracting audio/subtitle streams [VID_00014]
 - [18:47:27] Reencoding video [VID_00014]
   - Rate/Length: 23.976fps, 175,243 frames
   - Bitrate: 20,541 Kbs
 - [18:47:27] Reencoding: VID_00014, Pass 1 of 1
 - [00:33:14] Video Encode complete
 - [00:33:14] Processing audio tracks
   - Track 4352 (eng): Reencoding audio to AC3...
   - Track 4353 (eng): Keeping original audio
   - Track 4354 (eng): Keeping original audio
   - Track 4355 (fra): Keeping original audio
   - Track 4356 (spa): Keeping original audio
 - [00:34:40] Multiplexing M2TS
    - Bitstream exception. Adjusting...
 - Error in attempt to multiplex: MUX_00014.meta
 - Bitstream exception Unknown exception. It does not have to be! Please contact application support team for more information.
[00:44:07] - Failed to build structure, aborted
EDIT: I found the problem.
The problem is the Dolby Vision track, i try to remux with last tsmuxer "w64-nightly-2019-12-30--01-10-40" and give the same error.
When remove the Dolby Vision track, the remux runs fine.
I don't have a Dolby Vision TV, can I keep this without Dolby Vision track? Any way to add a option to avoid Dolby Vision in BDRebuilder?
EDIT2: I found a solution, I replace the dolby vision track in the work folder with the original from full disc and everything works fine.
@Jobbs, you make any change in dolby vision track? I don't understand why the original one work fine.
Last edited by zamengo; 31st December 2019 at 22:18. Reason: Edit to add a solution.
zamengo is offline   Reply With Quote
Old 31st December 2019, 11:46   #29108  |  Link
cartman0208
I can confirm the multiplexing error on ALITA_BATTLE_ANGEL
Strangely the encoding of the same disc was working fine with v0.60.29
cartman0208 is offline   Reply With Quote
Old 31st December 2019, 11:55   #29109  |  Link
zamengo
Alita works for me too on v0.60.29.
I think this is a bug in new tsmuxer, I try to make a remux with the cli version from 10 days ago and can't recognize the sequence of m2ts files.
I don't know what the version Jdobbs include on last bdrb version, but with the tsmuxer from 2019-12-28 I can make a remux from Alite without issues.
Already have a new tsmuxer version "w64-nightly-2019-12-30".
Old 31st December 2019, 12:02   #29110  |  Link
cartman0208
I just tried with v0.61.02 and the option UHD_TSMUXER=0 ...
that resolved the error
I wouldn't change any of the included versions ... as said many times: that creates more problems as it solves...
Old 31st December 2019, 17:35   #29111  |  Link
ripem2011
where is that option UHD TSMUXER i dont see it in the config file with v0.6.02
ripem2011 is offline   Reply With Quote
Old 31st December 2019, 20:40   #29112  |  Link
zamengo
This is a hidden option, add line in your .ini
Old 3rd January 2020, 06:59   #29113  |  Link
Lathe
Lathe's Avatar
Originally Posted by MrVideo View Post
It is saying pass 1 of 1. Looks like it is going to take over a week.
Well, you know what they say...
7 days without BDRB makes one weak...
Lathe is offline   Reply With Quote
Old 3rd January 2020, 07:08   #29114  |  Link
MrVideo
MrVideo's Avatar
@jdobbs
Is there a GUI version of the tsmuxer you are using? And if so, where can one get it?
Old 3rd January 2020, 07:10   #29115  |  Link
MrVideo
MrVideo's Avatar
By default it will do two pass at high quality.
Only one pass was done.
Old 3rd January 2020, 12:43   #29116  |  Link
zamengo
@jdobbs
In github, send a pm to you.
Old 3rd January 2020, 13:28   #29117  |  Link
Dofin
Hello, I've been using BD Rebuilder for years but recently it has started to completely freeze my PC. At first, I had thought about a heat issue but it is not as "Core temp" indicated. I've checked used software and everything looked working properly. Any suggestions ? Running Windows 10 PRO on eight core AMD processor. Many thanks.
Note: can not get a log as once PC's frozen, I do not have access to my mouse, programs or whatever was running, including Tasks Management. Only a hard reboot, depressing reset button on PC, works.
R M
Dofin is offline   Reply With Quote
Old 3rd January 2020, 13:57   #29118  |  Link
Michi
@jdobbs
The latest nightly build with gui:
https://www.videohelp.com/software/tsMuxeR
Old 3rd January 2020, 14:09   #29119  |  Link
MrVideo
MrVideo's Avatar
Thanks, I already have it. You gotta be quicker on the draw.
Old 3rd January 2020, 15:04   #29120  |  Link
MrVideo
MrVideo's Avatar
The rebuild of a UHD blu-ray to BD-50 has completed w/o any errors. Nothing to test it on though. It will be a while before I do.
