27th June 2022, 13:51 | #1 | Link |
ffmpeg - remove last frame before every scene change
I have a ProRes 422 HQ file taken from a 2 perf film negative. It has visible negative cuts, bottom frame, at the end of every scene change.
Is there a way of removing these distracting frames with ffmpeg? It would take ages to edit them all out manually. Thanks, |
27th June 2022, 18:06 | #2 | Link | ||||
I've no idea how to do what you want in ffmpeg, nor whether is possible.
Maybe instead of "removing these distracting frames", "replace these distracting frames with the frame prior to them {ie a dupe}". No change in frame count, no blips in audio where frame and audio chopped out {otherwise audio de-sync}. Automatic edit detection with FFmpeg and import into Premiere via EDL Offsite link:- http://danielbachler.de/2013/02/23/a...e-via-edl.html Linked by on-site post here:- https://forum.doom9.org/showthread.p...44#post1690644 Dont know if can be used as your post requires. [maybe someone else can comment]. If Avisynth and re-encode is OK, then could maybe use something like this to create a EOS frames list [End-Of-Scene]. Then replace those EOS frames with a dupe of the frame prior to them. https://forum.doom9.org/showthread.php?t=182392 Quote:
With a frames list, can (using FrameSel) pull out ONLY EOS frames for perusal (see if detects all look good, ie "destracting frame"). and also easily replace those EOS frames with the ones prior to them [Using FrameSel::FrameRep]. If Avisynth is an option for you, please say and I will assist further if needed. FrameSel:- https://forum.doom9.org/showthread.php?t=167971 FrameSel Docs:- https://forum.doom9.org/showthread.p...43#post1839843 Quote:
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 27th June 2022 at 18:44. |
ffmpeg |
