Old 28th September 2008, 04:01   #1  |  Link
MySchizoBuddy
x264 GTK gui on Mac OSX
trying to compile the x264 version 20080926 with gtk gui using the following configure script
./configure --prefix=/opt/local --enable-shared --enable-gtk --enable-pic --extra-cflags="-I/opt/local/install -I/usr/X11R6/include" --extra-ldflags="-L/opt/local/lib -L/usr/X11R6/lib"
i get this error
  T: fr.mo
..................... done.
msgmerge: `fr.po': No such file or directory
make[1]: *** [fr.mo] Error 1
the file is in gtk/fr.po so it does exist
Also how do i create a standalone binary for x264 and the gtk gui that i can post online.
MySchizoBuddy is offline   Reply With Quote
Old 28th September 2008, 04:04   #2  |  Link
MySchizoBuddy
can we also get build in mac support in the configure script
like this
  darwin*)
    SYS="MACOSX"
	# Support for Fink Packages
	if test -d /sw/bin ; then
	 prefix="/sw"
	 CFLAGS="-I/sw/include $CFLAGS"
	 LDFLAGS="-L/sw/lib $LDFLAGS"
	elif
	# Support for Macports
	 test -d /opt/local/bin ; then
	 prefix="/opt/local"
	 CFLAGS="-I/opt/local/include $CFLAGS"
	 LDFLAGS="-L/opt/local/lib $LDFLAGS"
	fi
    CFLAGS="$CFLAGS -falign-loops=16"
    LDFLAGS="$LDFLAGS -lm -lmx"
	# Mac OS X Leopard libGL.dylib linker interaction bug fix, see
	# http://developer.apple.com/qa/qa2007/qa1567.html
	MACOSX_VERSION=`uname -r | sed 's/^\(.\).*/\1/'`
	if test x"$MACOSX_VERSION" = "x9" ; then
		DYLIB_FILE="-dylib_file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib"
		LDFLAGS="$LDFLAGS $DYLIB_FILE"
	fi
Old 30th September 2008, 20:05   #3  |  Link
MySchizoBuddy
Am I allowed to submit patches for macs or no
Old 30th September 2008, 20:10   #4  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Yes, there's a mailing list for this purpose.
Old 30th September 2008, 22:32   #5  |  Link
ACoolie
building x264 w/o GTK support on Intel and PPC Macs works fine for me. Does this patch affect non-gtk builds?
ACoolie is offline   Reply With Quote
Old 1st October 2008, 12:30   #6  |  Link
buzzqw
HDConvertToX author
on linux (debian sid 64bit) the gtk works ok
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 2nd October 2008, 03:13   #7  |  Link
MySchizoBuddy
this patch is for gtk as well as mp4 support. without the correct cflags it cannot find gpac/isomedia.h used to build mp4 support. it assumes you are using fink or macports
avcourse you have to have compiled gpac first to enable mp4 support.
i have to comment out the .po .mo stuff from gtk/makefile. it now compiles with a nice gtk gui on macs.
gtk, mac, x264
