18th June 2018, 09:20 | #5441 | Link |
Δ
This video has no sound if using the default splitter but no problem with LAV splitter source:
https://drive.google.com/open?id=1TF...hgZSwuAHNLhfG7 |
18th June 2018, 09:21 | #5442 | Link | |
P.S. Fixed.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 18th June 2018 at 11:39. |
18th June 2018, 16:31 | #5445 | Link |
I have a problem, I installed mpc-be + lavfilter + madvr and up to here everything ok, but I have a problem with subtitles, I installed xysubfilter but as per procedure (run as administrator) but later in the mpc properties I can not find xysubfilter and so I do not see the subtitles, what am I wrong?
18th June 2018, 18:03 | #5446 | Link |
updated german translation based on r3750
18th June 2018, 19:14 | #5447 | Link |
@Klaus1189
Thank you. But I'm not sure of the correctness of the term "Advanced", it could be more correctly called "Extra". In this sub-menu commands are collected to not clutter the list of subtitles.
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
18th June 2018, 19:31 | #5448 | Link |
OK, the translation of "Advanced" matches but I think I need to correct the three new entries called
Audio Code:
Untertitel Code:
Videospur I personally would change the order to: Code:
Videospur Code:
Audiospur Code:
Untertitelspur |
18th June 2018, 19:51 | #5449 | Link |
Found it, I think, three times in txt file
updated german translation I'm not sure anymore about the order. Mostly the file has one videostream, so first Audio and second Subtitle is quite fine. |
19th June 2018, 04:31 | #5450 | Link |
The track of the video almost never changes, and many people change audio tracks and subtitles through the context menu (yes there are people who do not use the AUD and SUB buttons). Therefore, the video track is selected after audio and subtitles (in the player menu, not the splitter), otherwise it will only interfere. This is done in MPC-HC and I think it's logical.
There are two lines for the translation of the video track: IDS_MENU_VIDEO_STREAM and IDS_MENU_VIDEO_ANGLE. German translation updated in r3753.
20th June 2018, 04:41 | #5453 | Link |
updated german translation based on r3760 - Device buffer
20th June 2018, 20:29 | #5454 | Link | |
20th June 2018, 22:05 | #5455 | Link |
Looks like only happen when I tried to play HEVC 10bit with DXVA2 Native as selected H/W decoder. I think player doesn't notice that it was fallback to S/W decoding. Tried with other decoder, D3D11, it showed correctly fallback to S/W decoding.
21st June 2018, 19:13 | #5458 | Link |
@beter
Thanks. Updated in r3769.
25th June 2018, 11:50 | #5459 | Link | |
I've also been having this problem with drops during bitstreaming (exactly the same as tyrindor), do the latest builds resolve this issue? |
25th June 2018, 12:09 | #5460 | Link |
Latest SVN build fixed drop with bitstreaming.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
