Old 14th May 2021, 13:15   #641  |  Link
hubblec4
Matroska find' ich toll
Originally Posted by darksen View Post
Hey, yes, I use the dark theme in Windows and in all the apps I can. I think that these two parts (and in reality all the white parts) should be darker:
https://i.imgur.com/FPadhU2.png
Wow, so different in different OS's. Like I said all this section are grey here.
I don't know if I can fix this easily. It seems to me I have to add ever a Panel first, which can change the color independent from the OS.
But this would be make a lot of work. I have also started to read about Dark-mode in the Lazarus apps.
I will try to do something but I can't promise it.
EDIT: Also, could you please expand a little on this:
When a box is in grey? I'm asking because there are two states when I check the box, the first is that it's checked with a square and the other is a check but in none of them the box is in grey.
Thank you.
A checkbox has normally 2 states: checked and unchecked. But there is a third state, called gray-state.
The gray-state is like undetermined -> not checked and not unchecked.
The word "gray" has nothing to do with the color of the checkbox.
On my Win7 looks the gray-state of the checkbox indeed grey. On Linux it is also a bit grey, but looks totally different to Windows 7 and also Windows 10.
That is/was also the reason why I have insert my own checkbox icons at some places, to simulate a checkbox which looks ever the same on the OS's.
chapterEditor || Matroska-Playback || hSplit || DiscShare
hubblec4 is offline   Reply With Quote
Old 19th May 2021, 11:38   #642  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by hubblec4 View Post
Yes. The OGM specs says the chapter number starts with 0.
I did not know, thank you!
Another question: is it possible to join 2 chapter files? Zack Snyder's Justice league comes as 2 BDs but I want to join the encode in a single file. No problem for video and audio but how can I join the 2 separate chapter files?
@turment on Telegram
Old 19th May 2021, 11:59   #643  |  Link
hubblec4
Hi tormento
You can load the first chapter file and append the second one. Then select the first chapter of the second chapter file and adjust the timestamps with the Time-Edit-Tool.
Choose for the Action Range "All chapters from the selected ...." and as time shift set the play duration of the first video.
Old 19th May 2021, 12:19   #644  |  Link
tormento
Acid fr0g
tormento's Avatar
Thanks, will try!
Old 28th May 2021, 10:12   #645  |  Link
hubblec4
@darksen
I have tested the Dark-Mode in my Win7, and cE is using the dark colors from the OS.
It seems it should work when you change colors in the OS for your Theme.
But I have no idea how and where this settings are in the OS.
Old 4th June 2021, 13:22   #646  |  Link
hubblec4
update rev 1.29
chapterEditor(cE) rev1.29 is available.
Windows
Linux
An important bug fix for parsing Matroska files and Matroska chapter XML files.
Change chapterEditor
added    &
fixed    *
improved #
changed  %
rev1.29 2021-06-04
// chapterEditor
* Matroska Parser + Matroska Chapter-XML Parser
  The default value for the "ChapLanguage Element" is now "eng" and no longer "und"
// Time adjustments
& Frames as input (move and cut)
  - add an "f" to the end of the frame number
  - the source FPS from the FPS section is used
  - Source and Target FPS should be the same (but do not have to be)
  - the FPS must be set before entering the frame number,
    otherwise the entries in the edit fields must be renewed
// DVD2mkv
& added opening/editing of external subtitles
Old 16th July 2021, 12:39   #647  |  Link
an3k
an3k's Avatar
chapterEditor]chapterEditor(cE) rev1.29 is available.
Thank you so much for your tool. I have some MPLS that combine multiple episodes (individual m2ts files) and I wanted chapters for these individual episodes but needed something that allows me to remove preceding and following chapter entries but with automatic timecode adjusting.
I may only need it for this one project but do you have a donation thing?
an3k is offline   Reply With Quote
Old 16th July 2021, 19:16   #648  |  Link
hubblec4
Hi an3k
Originally Posted by an3k View Post
...something that allows me to remove preceding and following chapter entries but with automatic timecode adjusting.
Such a feature exists, called "Split Chapters".
In the GUI you will find it in the Feature-Bar or you can use the CLI of cE.
https://forum.doom9.org/showthread.p...12#post1902412
...do you have a donation thing?
No, not at the moment.
bluray backup, chapter editor, dvd2mkv, matroska menu, metadata, multi-edition-mkv, xml tag
