Old 7th April 2010, 19:00   #1  |  Link
ajitsdeshpande@gmail.com
FFMPEG based Theora Video Decoder performance??
I am in process of porting and optimization of the theora video decoder in the ffmpeg-0.5 package to ARM-Cortex-A8 -Neon processor @ 667 MHz.
I am looking for some target estimate for frames per second the decoder library alone should achieve after full optimization (C level and Neon assembly / Intrinsics) for 720x480 Progressive content for a 2Mbps stream.
I have a Real Video 9 decoder on cortex-A8 which gives around 40 fps for the same stream above.(720x480, 2Mbps)
How can i extrapolate this data based on relative complexities of RV9 and Theora and get a fps estimate for theora decoder Cortex-A8?
I am aware the performance depends upon the cache configuration of the h/w, etc...,but any
Any pointers will help.
Thanks,
-AD
ajitsdeshpande@gmail.com is offline   Reply With Quote
Old 7th April 2010, 19:08   #2  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Porting? Optimization? Huh?
The ffmpeg Theora decoder already supports ARM (there's no "porting" necessary) and has a great deal of assembly on ARM (there's not much "optimization" to be done either).
Old 23rd April 2010, 20:40   #3  |  Link
hellfred
FFmpeg fan
Originally Posted by ajitsdeshpande@gmail.com View Post
The theora decoder underwent many performance improvements (algorithmic improvements!) since the 0.5 release. Do use the current code from FFmpeg subversion repository. For a list of changes see e. g. the verion history of vp3.c.
hellfred is offline   Reply With Quote
Old 23rd April 2010, 20:43   #4  |  Link
hellfred
FFmpeg fan
Do you know this news?
Old 23rd April 2010, 20:44   #5  |  Link
Dark Shikari
x264 developer
Yes. ffmpeg is still faster by a significant margin.
Old 23rd April 2010, 20:47   #6  |  Link
hellfred
FFmpeg fan
That link was meant for ajitsdeshpande to point him to another theora ARM decoder codebase.
theora
