Old 8th January 2016, 22:34   #101  |  Link
ts1
It's a pretty lightweight shader. Something wrong with your GPU drivers/setup. I tried it on Linux and it works fine with proprietary nVidia drivers, but with nouveau it's also not usable, very slow.
There is parameter to control sharpening strength.
ts1 is offline   Reply With Quote
Old 9th January 2016, 10:23   #102  |  Link
BRM
I know, I get similar results with the 2-pass shader.
As for my setup, it's radeon-git, xorg.conf and xorg.conf.d/20-radeon.conf are as follows: http://pastebin.com/raw/aE3e21Bn
  Section "Device"
          Identifier "radeonVGA"
                      Driver "radeon"
                      Option "AccelMethod" "Glamor" # See compatibility on features page
                      Option "DRI3" "on" # Compatibility not very well documented, remove it if it fails
                      Option "EnablePageFlip" "On"
  EndSection
BRM is offline   Reply With Quote
Old 9th January 2016, 11:02   #103  |  Link
ts1
Can't help you with this, I never used Radeon and I use Linux (Sabayon, Gentoo based) from flash drive, it already includes proprietary drivers and mpv.
Old 13th January 2016, 23:01   #104  |  Link
XMonarchY
Posts: n/a
How would I go about integrating your latest version downloads into ReShade? ReShade uses either .fx files or .h files. I assume I can just rename TWO-PASS .hlsl file to .h or .fx file because the content is identical, isn't it? When I open the file with WordPad, it shows identical info. I assume ReShade uses the TWO-PASS file because ATM it uses a 12KB file, which is closer to TWO-PASS 11KB then to ONE-PASS 4KB file.
Old 14th January 2016, 01:42   #105  |  Link
aufkrawall
You have to port the HLSL shader to ReShade shading language.
bacondither or JPulowski will do it soon:
https://github.com/crosire/reshade-shaders/issues/8
Old 19th January 2016, 18:41   #106  |  Link
BRM
New 1 pass shader causes a segfault.
LLVM triggered Diagnostic Handler: SIInstrInfo::storeRegToStackSlot - Can't spill VGPR!
[1]    9181 segmentation fault  mpv https://www.youtube.com/watch\?v\=yqynPcFEL3U
Old 19th January 2016, 19:47   #107  |  Link
ts1
Are you sure this is shader's fault? Is there any errors from a shader compiler?
I will test it with mesa later.
Edit: works with mesa, slow but without errors.
Seems like it's a LLVM's bug https://bugs.freedesktop.org/show_bug.cgi?id=75276#c50. Do you use latest LLVM 3.7?
Old 27th January 2016, 01:18   #108  |  Link
BRM
Yes, that one is super slow but works, and you were right, it was caused by using LLVM 3.5.
Old 2nd February 2016, 15:40   #109  |  Link
ts1
nevermind
Old 16th February 2016, 14:27   #110  |  Link
ts1
bacondither
I removed my previous comment, but there is still a problem in minim_satloss, there are cases when c0_Y==0.
Ok, this is only in glsl so.
Old 16th February 2016, 23:10   #111  |  Link
foozoor
foozoor's Avatar
Thanks for the update ts1.
foozoor is offline   Reply With Quote
Old 9th March 2016, 04:02   #112  |  Link
XMonarchY
Posts: n/a
Could someone provide some images that compare LumaSharpen, AdaptiveSharpen, FineSharp, and or Crispen Edges using similar settings?
I usually apply a little bit of AdaptiveSharpen (0.1-0.15) and a little bit of LumaSharpen (0.50 - strength, 0.030 - clamp) in films and games, but I'd like to reduce ringing, noise, artifacts, overshoot, and other side-effects. What should I be using them - both AdaptiveSharpen and LumaSharpen OR just one of them? Which one?
Old 12th July 2016, 18:54   #113  |  Link
bacondither
New version released!
bacondither
That's strange, i have done a glsl port of my own for testing so i could poke around with it in mpv a bit.
bacondither is offline   Reply With Quote
Old 12th July 2016, 21:50   #114  |  Link
toniash
new one-pass version??
A guy (igv) ported and improved this shader for the mpv hook system:
https://gist.github.com/igv/8a77e4eb...bb94c1c50c317e
I don't really know what he improved but it looks amazingly on my sister's laptop with a weak intel hd3000 iGPU. The two-passes version is too intensive!
(From Madvr thread)
toniash is offline   Reply With Quote
Old 8th December 2016, 12:27   #115  |  Link
bob88
Hello,
I'm using latest version MPC-HC x64 1.7.10
I added the shaders in post-resize in the described order but I still get a green screen.
Could somebody please tell me how to fix it?
Thank you!
bob88 is offline   Reply With Quote
Old 8th December 2016, 14:08   #116  |  Link
bacondither
Thank you!
If you are using madVR as video renderer untick "lose BTB and WTW if it improves performance" and "run custom pixel shaders in video levels instead of PC levels".
The settings can be found in madVR settings, rendering->trade quality for performance.
Old 8th December 2016, 15:12   #117  |  Link
bob88
I am using the default 'enhanced video renderer (custom presenter)'
madVR is listed as unavailable, I guess it has to be installed additionally. Should I be using that? Is it better?
Old 8th December 2016, 15:30   #118  |  Link
bacondither
Ok you are using EVR.
Go to View-> Renderer Settings -> Presentation and enable "Full floating point point processing" or "Half floating point point processing", then restart MPC-HC.
Hmm i should probably add this to the installation instructions.
Old 8th December 2016, 18:48   #119  |  Link
BetA13
cosmic entity
BetA13's Avatar
ha, and i was wondering why it didnt work in my normal MPCHC test player but did work with madvr etc..
Thanks for the tip with the "Full floating point point processing"
Just wondering, what does this function do anyway?
"Full floating point point processing", "Half floating point point processing"
Have a nice evening bacondither and thanks for teh lesson haha..
BetA13 is offline   Reply With Quote
Old 8th December 2016, 19:28   #120  |  Link
bob88
Enabling full or half floating point processing just results in completely black screen regardless of shaders.
adaptive sharpen, shader, sharpening
