2nd February 2018, 16:42 | #41 | Link |
ok, on default setting it gives no errors, but I think the output is wrong:
http://manoa.flnet.org/logs/original.png http://manoa.flnet.org/logs/post.png or mybe because default setting quality is low ? image size error happens when nsize=3 + nns>1 or when nsize=2 + nns>2 or when nsize=6 + nns>2 ok on higher setting (nsize=2, nns=2, qual=2, pscrn=1) the big artifact are removed, but some artifact still present and in addition there is many blur http://manoa.flnet.org/logs/high.png Last edited by monohouse; 2nd February 2018 at 16:55. |
3rd February 2018, 11:18 | #42 | Link | |
3rd February 2018, 11:31 | #43 | Link |
core's threads to 1 ?
http://manoa.flnet.org/logs/info.png waith I think I have problem with the hardware, ati tool artifact scaner show errors :x sorry, I will fix it first and then try again that strange....he gived error after 1 minutes but now I run him for more than 5 minutes and there is no errors :x I running now VMT to see if there is problem, he passed 15 tests and there is 0 errors :x to be sure I slowed him down to less than original speed and run the encoder again, there were still artifacts :x I am sure it is not the card that the problem Last edited by monohouse; 3rd February 2018 at 12:15. |
3rd February 2018, 17:41 | #44 | Link | |
Your card's 1D Image Max Buffer Size is 65536, though adheres to the OpenCL spec's minimum value, but is too small for some combination of nsize+nns. That's the reason why you got Invalid Image Size error. BTW that value of my old GTX 660 is 134217728 (2^27). The cause of the artifacts you got is still uncertain. Try http://www.mediafire.com/file/dns5dt...CL-r7_test4.7z one more time. If the issue still exists then I can't help you. Just use znedi3 instead since it has good AVX/AVX2 optimizations. |
7th February 2018, 16:53 | #49 | Link |
I was thinking that because you mentioned you have a nvidea card, so I blieved that you develop the plugin mostly on that card so I was thinking that the plugin mybe more compatible for nvidea card :x
it sutch a shame fermi old :x he is so fast card EVGA classified and only 1.1 :x. I should probable buy new AMD card then, it will have all the requirements. about znedi, he is not bad but very very slow because my processor don't have AVX, it AMD phenom 2 :x but I found eedi3 he is pretty good both clean output and fast (1.4 fps on this crap AMD video card), he use 50% of the card so I can run 2 at the same time to use maximum card speed your was still faster (2 fps from 75% card used) it no problem because 1.5 fps still gives me 30 times more speed compared to nnedi3 on CPU using AVS+, even if used with AVX who could blieve it sutch a littel video card can do so mutch more fast than a haswell CPU you know what I think ? if nvidea whant to do a good openCL, they can, they are more strong than AMD, they have bigger software department and more money than AMD, larger research. but they don't do it because they don't whant openCL - they whant the CUDA, they whant everyone to go to CUDA so that everyone depend on CUDA and in the end depend on nvidea because CUDA only work on nvidea. Last edited by monohouse; 7th February 2018 at 20:55. |
20th April 2018, 00:37 | #50 | Link | |
What version of boost is required for make? Ubuntu 16.04 provides 1.58:
17th February 2019, 02:13 | #52 | Link |
On Windows 10 and a Geforce GTX 1070 Ti with the latest 419.81 drivers I get:
NNEDI3CL: device index out of range anyone else having issues with these drivers or is this probably something totally different? (not totally sure it's the drivers and not something else,.. ) Cu Selur |
17th February 2019, 02:46 | #53 | Link | |
17th February 2019, 09:42 | #54 | Link | ||
# Imports import os import sys import ctypes # Loading Support Files Dllref = ctypes.windll.LoadLibrary("I:/Hybrid/64bit/vsfilters/Support/OpenCL.dll") import vapoursynth as vs core = vs.get_core() # Import scripts folder scriptPath = 'I:/Hybrid/64bit/vsscripts' sys.path.append(os.path.abspath(scriptPath)) # Loading Plugins core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/ResizeFilter/nnedi3/NNEDI3CL.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/SourceFilter/FFMS2/ffms2k.dll") # Import scripts import edi_rpow2 # Loading F:\TestClips&Co\files\test.avi using FFMS2K clip = core.ffms2.Source(source="F:/TESTCL~1/files/test.avi",cachefile="E:/Temp/avi_078c37f69bb356e7b5fa040c71584c40_853323747.ffindex",format=vs.YUV420P8,alpha=False) # using NNEDI3CL clip = core.nnedi3cl.NNEDI3CL(clip, field=1, list_device=True, info=True) # Output clip.set_output() |
17th February 2019, 09:58 | #56 | Link |
using:
# Imports import os import sys import ctypes # Loading Support Files Dllref = ctypes.windll.LoadLibrary("I:/Hybrid/64bit/vsfilters/Support/OpenCL.dll") import vapoursynth as vs core = vs.get_core() # Import scripts folder scriptPath = 'I:/Hybrid/64bit/vsscripts' sys.path.append(os.path.abspath(scriptPath)) # Loading Plugins core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/ResizeFilter/nnedi3/NNEDI3CL.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/SourceFilter/FFMS2/ffms2k.dll") # Import scripts import edi_rpow2 # Loading F:\TestClips&Co\files\test.avi using FFMS2K clip = core.ffms2.Source(source="F:/TESTCL~1/files/test.avi",cachefile="E:/Temp/avi_078c37f69bb356e7b5fa040c71584c40_853323747.ffindex",format=vs.YUV420P8,alpha=False) # using NNEDI3CL clip = core.nnedi3cl.NNEDI3CL(clip, field=1, info=True) # Output clip.set_output() Code:
NNEDI3CL: No OpenCL device found |
17th February 2019, 10:05 | #57 | Link |
Argh,.. got it. It's a problem with the OpenCL.dll I loaded.
removing the Code:
Dllref = ctypes.windll.LoadLibrary("I:/Hybrid/64bit/vsfilters/Support/OpenCL.dll") Thanks for bearing with me. |
29th September 2019, 03:33 | #58 | Link |
I'm using QTGMC with opencl=True and sometimes (like 1 out of 20 times) get this crash at the start:
> ucrtbase.dll!abort() Unknown ucrtbase.dll!terminate() Unknown vcruntime140.dll!FindHandler<__FrameHandler3>(EHExceptionRecord * pExcept, unsigned __int64 * pRN, _CONTEXT * pContext, _xDISPATCHER_CONTEXT * pDC, const _s_FuncInfo * pFuncInfo, unsigned char recursive, int CatchDepth, unsigned __int64 * pMarkerRN) Line 538 C++ vcruntime140.dll!__InternalCxxFrameHandler<__FrameHandler3>(EHExceptionRecord * pExcept, unsigned __int64 * pRN, _CONTEXT * pContext, _xDISPATCHER_CONTEXT * pDC, const _s_FuncInfo * pFuncInfo, int CatchDepth, unsigned __int64 * pMarkerRN, unsigned char recursive) Line 387 C++ vcruntime140.dll!__CxxFrameHandler3(EHExceptionRecord * pExcept, unsigned __int64 RN, _CONTEXT * pContext, _xDISPATCHER_CONTEXT * pDC) Line 264 C++ ntdll.dll!RtlpExecuteHandlerForException() Unknown ntdll.dll!RtlDispatchException() Unknown ntdll.dll!RtlRaiseException() Unknown [External Code] msvcp140.dll!std::_Xout_of_range(const char * _Message) Line 24 C++ NNEDI3CL.dll!00007ffa7e122c26() Unknown NNEDI3CL.dll!00007ffa7e1181e3() Unknown vapoursynth.dll!VSNode::getFrameInternal(int n, int activationReason, VSFrameContext & frameCtx) Line 854 C++ vapoursynth.dll!VSThreadPool::runTasks(VSThreadPool * owner, std::atomic<bool> & stop) Line 214 C++ [External Code] |
30th September 2019, 09:09 | #59 | Link | |
30th September 2019, 15:00 | #60 | Link | |
test1 crashes differently and much less frequently: Code:
> OpenCL.dll!00007ffa82ba17a9() Unknown NNEDI3CL.dll!00007ffa82b3d012() Unknown NNEDI3CL.dll!00007ffa82b3763c() Unknown NNEDI3CL.dll!00007ffa82b374d2() Unknown [Inline Frame] vapoursynth.dll!VSCore::destroyFilterInstance(VSNode *) Line 1223 C++ [Inline Frame] vapoursynth.dll!VSNode::{dtor}() Line 820 C++ vapoursynth.dll!VSNode::`scalar deleting destructor'(unsigned int) C++ [Inline Frame] vapoursynth.dll!std::_Ref_count_base::_Decref() Line 770 C++ [Inline Frame] vapoursynth.dll!std::_Ptr_base<VSNode>::_Decref() Line 988 C++ [Inline Frame] vapoursynth.dll!std::shared_ptr<VSNode>::{dtor}() Line 1233 C++ vapoursynth.dll!freeNode(VSNodeRef * clip) Line 148 C++ [External Code] test2 did never crash. |
