16th September 2016, 15:55 | #201 | Link | ||
Playback worked nice so far. Took me a while to find that I had to press on 'Show timeline panel'-button to find the 'play'-button. |
20th September 2016, 17:24 | #204 | Link |
Beyond Kawaii
Another treat for you, Windows users.
A much more stable build with implemented benchmarking and somewhat working CLI encoding. Encoding is just a draft. Expect bugs on a slightest mistake in arguments or frame format. Release version will have encoding profiles management. The build comes with predefined settings for ProRes 422 encoding via ffmpeg. Video must be in YUV422P10 for it to work.
...desu! |
22nd September 2016, 03:04 | #206 | Link |
I like the new benchmark.
Small feature request: could you add a button that lets us compare the original frame to the processed one in the preview window? Press button: original frame is show. Press button again: processed frame is shown. Example of that in action: http://www.screenshotcomparison.com/comparison/185123 This would be immensely helpful for tuning VS filters. I do it manually now, but it's rather clunky. Some AS editors have a more complicated version of that, but honestly I like the simplicity of a comparison button. Last edited by brucethemoose; 22nd September 2016 at 03:08. |
22nd September 2016, 03:16 | #207 | Link | |
Beyond Kawaii
...desu! |
22nd September 2016, 03:29 | #208 | Link | |
I guess you could compare the same frames in 2 seperate scripts, but that's complicated to implement (as VS Editor would have to handle another script). Thanks for the helper script. |
22nd September 2016, 12:04 | #209 | Link |
It is quite funny to compare things in my latest VD build (hope this adds to subject)
How it works: 1) open script 2) add filter (fflayer) with source video 3) close filter config and open filter blending withing filter blending you have preview, color picker and blending options: Apply opacity curve by coincidence acts as on/off toggle (because default state for curve is all off) Another option is to move left/top etc. margin, this behaves as "onion skinning"
VirtualDub2 |
22nd September 2016, 16:36 | #210 | Link |
Beyond Kawaii
GUI filter sounds nice. Though requires a lot of preprocessor magic to code in cross-platform way.
Upd: It happens that VapourSynth supports multiple outputs. I could use it to implement different comparison techniques.
...desu! Last edited by Mystery Keeper; 22nd September 2016 at 17:45. |
23rd September 2016, 11:48 | #211 | Link |
Beyond Kawaii
New Windows build with supposedly completely handled encoding. Please test extensively while I'm implementing profiles. It also has a bug in playback fixed.
...desu! |
23rd September 2016, 20:02 | #212 | Link |
On both l33tmeatwad OSX's installer and manually compiling the latest version, I'm getting the following issue:
I cannot get an image preview unless the preview size is set to x0.75 or 0.25 Bilinear (edit: actually it's currently working at 0.5). Fit to Frame works well as long as (I think) the image is under x1.0 Anything else returns either a black image or a corrupt rendered image: |
23rd September 2016, 20:44 | #213 | Link | |
Beyond Kawaii
...desu! |
23rd September 2016, 22:32 | #216 | Link |
The preview looks corrupt.
It appears that only 0.25, 0.50 and 0.75 work (bilinear, not nearest). My graphics card is by no means impressive (ATI Radeon HD 5770) but I am able to successfully render using vspipe and ffmpeg. I wonder if it is a graphics card limitation... (Hoping to get a new one relatively soon) |
24th September 2016, 03:03 | #217 | Link | |
Maybe try a fresh graphics driver install, just to rule it out? Uninstall normally, run DDU, install your driver. |
25th September 2016, 03:56 | #220 | Link |
Beyond Kawaii
VapourSynth Editor r⑨ is here with new awesome features:
-Asynchronous frames processing. More responsive GUI. -Preview video playback. -Script processing benchmarking. -Encoding video with CLI tools. Links are in the first post. It is called r⑨ for a reason. Barely tested. Colour picking is broken in play mode. It will be fixed in next release along with more internal changes. To moderators: may this thread be made sticky please?
...desu! |
