9th June 2023, 14:04 | #20221 | Link | |
Formally known as .......
That suggestion is of course totally up to Atak to implement, but I need a command for tsmuxer to remux to .m2ts, which I need for my LG TV. Using FFmepg to create a .m2ts from the .mkv, removes the DV format...tsmuxer retains it, so atm I have to actually run it thru tsmuxer after RipBot has done the encode. Last edited by TDS; 9th June 2023 at 14:29. |
12th June 2023, 12:07 | #20222 | Link |
Auto Add Subtitles
Hi Atak,
I like the new features of auto adding covers and subtitles from files and such. The new UI changes took a bit to get used to buy now I'm liking them. When auto adding subtitles, it would be nice for it to filter by language and just add those. For example I just added a source disc and it added all the subtitles from all the languages on the disc, other wise I could only just select one subtitles instead of the two English subtitles that were there. In the settings there is preferred language. Perhaps that setting could be used to filter the subtitles. One other small UI improvement, when in the covers selection, it would be nice that if a cover is already there, that a thumbnail show that the picture is. Does MKV support attaching notes of some kind? It would be nice to be able to be able to manually add a description of the encoding settings that I used for that job that I could see using mediainfo. |
13th June 2023, 23:16 | #20223 | Link |
Lost GUI
Can anyone help in tracking down why Ripbot264 will not start. Earlier today I updated the AMD chipset drivers and the Realtek audio drivers and now in Task Manager I can see Ripbot264 (32 bit) under Background processes, but not under Apps and there is no GUI.
I have another windows installation on the same PC (Windows 11 canary) with the same drivers and Ripbot264 is fine. I am running Windows 11 on an ASRock X670E PG Lightning, Ryzen 9 7950x, 32 GB RAM. Update - I have re-downloaded 1.26 into a new folder and so far it seems okay, however although update ran and the changelog shows 1.27. the GUI still shows as 1.26.0 and the GUI is the 1.26, not 1.27 version. Further update: on checking the update - nothing was actually updated. I then rebooted into my test setup and the update completed successfully (and Ripbot works). Rebooting back to my main setup the new install no longer works. So the issue would seem to be specific to 1.27. Last edited by archiel; 14th June 2023 at 13:27. |
14th June 2023, 13:33 | #20224 | Link |
Corrupt updates
When starting Ripbot it seems that there are some corrupt files being pulled. From update_log.txt
2023-06-14 12:49:47 : [ERROR] H:\Ripbot3\updates\bdsup2sub.zip is corrupted. CRC32 mismatch. Expected value was D61F6ADA but got DA198FBF 2023-06-14 12:49:47 : File H:\Ripbot3\updates\bdsup2sub.zip has been deleted. 2023-06-14 12:49:47 : [ERROR] H:\Ripbot3\updates\ffmpeg.zip is corrupted. CRC32 mismatch. Expected value was 8ACC97BC but got DA4E6C91 2023-06-14 12:49:47 : File H:\Ripbot3\updates\ffmpeg.zip has been deleted. 2023-06-14 12:49:48 : [ERROR] H:\Ripbot3\updates\mkvtoolnix.zip is corrupted. CRC32 mismatch. Expected value was 7F6D769A but got 5476BC3D 2023-06-14 12:49:48 : File H:\Ripbot3\updates\mkvtoolnix.zip has been deleted. 2023-06-14 12:49:51 : [ERROR] H:\Ripbot3\updates\ffms.zip is corrupted. CRC32 mismatch. Expected value was EB9EA06 but got 3B64044D 2023-06-14 12:49:51 : File H:\Ripbot3\updates\ffms.zip has been deleted. 2023-06-14 12:49:52 : [ERROR] H:\Ripbot3\updates\nnedi3.zip is corrupted. CRC32 mismatch. Expected value was A1C29B2A but got 217A4098 2023-06-14 12:49:52 : File H:\Ripbot3\updates\nnedi3.zip has been deleted. 2023-06-14 12:49:52 : [ERROR] H:\Ripbot3\updates\avisynth.zip is corrupted. CRC32 mismatch. Expected value was CCA2600B but got 7800F1DE 2023-06-14 12:49:52 : File H:\Ripbot3\updates\avisynth.zip has been deleted. 2023-06-14 12:49:52 : [ERROR] H:\Ripbot3\updates\lsmash.zip is corrupted. CRC32 mismatch. Expected value was 4A317368 but got D532A79F 2023-06-14 12:49:52 : File H:\Ripbot3\updates\lsmash.zip has been deleted. |
14th June 2023, 14:30 | #20225 | Link | |
2023-06-14 15:23:02 : =========================[UPDATER ACTIVATED]========================= 2023-06-14 15:23:02 : Looking for correct UUID link in http://forum.doom9.org/showthread.php?t=127611 2023-06-14 15:23:03 : [SUCCESS] http://forum.doom9.org/showthread.php?t=127611 has correct UUID link 6c966b28-e0dd-48f6-b1c7-a56e8a275ec0 2023-06-14 15:23:03 : Downloading update file http://atak-snajpera.5v.pl/ripbot264update/update.zip 2023-06-14 15:23:03 : [SUCCESS] C:\Temp\RipBot264v1.26.0\Updates\update.zip saved! 2023-06-14 15:23:03 : Update for [core] detected 2023-06-14 15:23:03 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/core.zip to C:\Temp\RipBot264v1.26.0\updates\core.zip 2023-06-14 15:23:05 : [SUCCESS] File C:\Temp\RipBot264v1.26.0\updates\core.zip saved! 2023-06-14 15:23:05 : CRC32 value has not changed for [aften]. Update is not required. 2023-06-14 15:23:05 : CRC32 value has not changed for [avs2pipemod]. Update is not required. 2023-06-14 15:23:05 : CRC32 value has not changed for [avs2yuv]. Update is not required. 2023-06-14 15:23:05 : CRC32 value has not changed for [avsmeter]. Update is not required. 2023-06-14 15:23:05 : CRC32 value has not changed for [bdsup2sub]. Update is not required. 2023-06-14 15:23:05 : CRC32 value has not changed for [chapterxtractor]. Update is not required. 2023-06-14 15:23:05 : CRC32 value has not changed for [dgindex]. Update is not required. 2023-06-14 15:23:05 : Update for [downloadposter] detected 2023-06-14 15:23:05 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/downloadposter.zip to C:\Temp\RipBot264v1.26.0\updates\downloadposter.zip 2023-06-14 15:23:06 : [SUCCESS] File C:\Temp\RipBot264v1.26.0\updates\downloadposter.zip saved! 2023-06-14 15:23:06 : CRC32 value has not changed for [eac3to]. Update is not required. 2023-06-14 15:23:06 : Update for [ffmpeg] detected 2023-06-14 15:23:06 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/ffmpeg.zip to C:\Temp\RipBot264v1.26.0\updates\ffmpeg.zip 2023-06-14 15:23:47 : [SUCCESS] File C:\Temp\RipBot264v1.26.0\updates\ffmpeg.zip saved! 2023-06-14 15:23:47 : CRC32 value has not changed for [fhgaacenc]. Update is not required. 2023-06-14 15:23:47 : Update for [mediainfo] detected 2023-06-14 15:23:47 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/mediainfo.zip to C:\Temp\RipBot264v1.26.0\updates\mediainfo.zip 2023-06-14 15:23:48 : [SUCCESS] File C:\Temp\RipBot264v1.26.0\updates\mediainfo.zip saved! 2023-06-14 15:23:48 : Update for [mkvtoolnix] detected 2023-06-14 15:23:48 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/mkvtoolnix.zip to C:\Temp\RipBot264v1.26.0\updates\mkvtoolnix.zip 2023-06-14 15:24:22 : [SUCCESS] File C:\Temp\RipBot264v1.26.0\updates\mkvtoolnix.zip saved! 2023-06-14 15:24:22 : CRC32 value has not changed for [modifychapters]. Update is not required. 2023-06-14 15:24:22 : CRC32 value has not changed for [mp4box]. Update is not required. 2023-06-14 15:24:22 : Update for [mpc] detected 2023-06-14 15:24:22 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/mpc.zip to C:\Temp\RipBot264v1.26.0\updates\mpc.zip 2023-06-14 15:24:36 : [SUCCESS] File C:\Temp\RipBot264v1.26.0\updates\mpc.zip saved! 2023-06-14 15:24:36 : CRC32 value has not changed for [opus-tools]. Update is not required. 2023-06-14 15:24:36 : CRC32 value has not changed for [pgcdemux]. Update is not required. 2023-06-14 15:24:36 : CRC32 value has not changed for [remuxtool]. Update is not required. 2023-06-14 15:24:36 : CRC32 value has not changed for [setacl]. Update is not required. 2023-06-14 15:24:36 : CRC32 value has not changed for [ssatosrt]. Update is not required. 2023-06-14 15:24:36 : CRC32 value has not changed for [tsmuxer]. Update is not required. 2023-06-14 15:24:36 : CRC32 value has not changed for [vjoin]. Update is not required. 2023-06-14 15:24:36 : CRC32 value has not changed for [vsrip]. Update is not required. 2023-06-14 15:24:36 : CRC32 value has not changed for [wolcmd]. Update is not required. 2023-06-14 15:24:36 : Update for [x264] detected 2023-06-14 15:24:36 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/x264.zip to C:\Temp\RipBot264v1.26.0\updates\x264.zip 2023-06-14 15:24:39 : [SUCCESS] File C:\Temp\RipBot264v1.26.0\updates\x264.zip saved! 2023-06-14 15:24:39 : Update for [x265] detected 2023-06-14 15:24:39 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/x265.zip to C:\Temp\RipBot264v1.26.0\updates\x265.zip 2023-06-14 15:24:41 : [SUCCESS] File C:\Temp\RipBot264v1.26.0\updates\x265.zip saved! 2023-06-14 15:24:41 : CRC32 value has not changed for [autocrop]. Update is not required. 2023-06-14 15:24:41 : CRC32 value has not changed for [ffms]. Update is not required. 2023-06-14 15:24:41 : CRC32 value has not changed for [flash3kyuu_deband]. Update is not required. 2023-06-14 15:24:41 : CRC32 value has not changed for [hqdn3d]. Update is not required. 2023-06-14 15:24:41 : Update for [scripts] detected 2023-06-14 15:24:41 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/scripts.zip to C:\Temp\RipBot264v1.26.0\updates\scripts.zip 2023-06-14 15:24:41 : [SUCCESS] File C:\Temp\RipBot264v1.26.0\updates\scripts.zip saved! 2023-06-14 15:24:41 : CRC32 value has not changed for [tivtc]. Update is not required. 2023-06-14 15:24:41 : CRC32 value has not changed for [vsfilter]. Update is not required. 2023-06-14 15:24:41 : CRC32 value has not changed for [yadif]. Update is not required. 2023-06-14 15:24:41 : Update for [knlmeanscl] detected 2023-06-14 15:24:41 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/knlmeanscl.zip to C:\Temp\RipBot264v1.26.0\updates\knlmeanscl.zip 2023-06-14 15:24:41 : [SUCCESS] File C:\Temp\RipBot264v1.26.0\updates\knlmeanscl.zip saved! 2023-06-14 15:24:41 : CRC32 value has not changed for [openclinfo]. Update is not required. 2023-06-14 15:24:41 : Update for [masktools] detected 2023-06-14 15:24:41 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/masktools.zip to C:\Temp\RipBot264v1.26.0\updates\masktools.zip 2023-06-14 15:24:42 : [SUCCESS] File C:\Temp\RipBot264v1.26.0\updates\masktools.zip saved! 2023-06-14 15:24:42 : Update for [mvtools] detected 2023-06-14 15:24:42 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/mvtools.zip to C:\Temp\RipBot264v1.26.0\updates\mvtools.zip 2023-06-14 15:24:42 : [SUCCESS] File C:\Temp\RipBot264v1.26.0\updates\mvtools.zip saved! 2023-06-14 15:24:42 : CRC32 value has not changed for [nnedi3]. Update is not required. 2023-06-14 15:24:42 : CRC32 value has not changed for [detectborders]. Update is not required. 2023-06-14 15:24:42 : Update for [avisynth] detected 2023-06-14 15:24:42 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/avisynth.zip to C:\Temp\RipBot264v1.26.0\updates\avisynth.zip 2023-06-14 15:25:00 : [SUCCESS] File C:\Temp\RipBot264v1.26.0\updates\avisynth.zip saved! 2023-06-14 15:25:00 : CRC32 value has not changed for [rawsourceplus]. Update is not required. 2023-06-14 15:25:00 : CRC32 value has not changed for [rgtools]. Update is not required. 2023-06-14 15:25:00 : CRC32 value has not changed for [nicaudio]. Update is not required. 2023-06-14 15:25:00 : Update for [plugins_jpsdr] detected 2023-06-14 15:25:00 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/plugins_jpsdr.zip to C:\Temp\RipBot264v1.26.0\updates\plugins_jpsdr.zip 2023-06-14 15:25:07 : [SUCCESS] File C:\Temp\RipBot264v1.26.0\updates\plugins_jpsdr.zip saved! 2023-06-14 15:25:07 : CRC32 value has not changed for [waitforprocess]. Update is not required. 2023-06-14 15:25:07 : CRC32 value has not changed for [avsresize]. Update is not required. 2023-06-14 15:25:07 : CRC32 value has not changed for [dgtonemap]. Update is not required. 2023-06-14 15:25:07 : CRC32 value has not changed for [lsmash]. Update is not required. 2023-06-14 15:25:07 : CRC32 value has not changed for [7z]. Update is not required. 2023-06-14 15:25:07 : CRC32 value has not changed for [srttossa]. Update is not required. 2023-06-14 15:25:07 : Update for [hdrtools] detected 2023-06-14 15:25:07 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/hdrtools.zip to C:\Temp\RipBot264v1.26.0\Updates\hdrtools.zip 2023-06-14 15:25:07 : [SUCCESS] File C:\Temp\RipBot264v1.26.0\Updates\hdrtools.zip saved! 2023-06-14 15:25:07 : CRC32 value has not changed for [matroskasplitter]. Update is not required. 2023-06-14 15:25:07 : CRC32 value has not changed for [cas]. Update is not required. 2023-06-14 15:25:07 : New section [avscube] detected 2023-06-14 15:25:07 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/avscube.zip to C:\Temp\RipBot264v1.26.0\Updates\avscube.zip 2023-06-14 15:25:07 : [SUCCESS] File C:\Temp\RipBot264v1.26.0\Updates\avscube.zip saved! 2023-06-14 15:25:07 : New section [colormatrix] detected 2023-06-14 15:25:07 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/colormatrix.zip to C:\Temp\RipBot264v1.26.0\Updates\colormatrix.zip 2023-06-14 15:25:07 : [SUCCESS] File C:\Temp\RipBot264v1.26.0\Updates\colormatrix.zip saved! 2023-06-14 15:25:07 : New section [cutsub] detected 2023-06-14 15:25:07 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/cutsub.zip to C:\Temp\RipBot264v1.26.0\Updates\cutsub.zip 2023-06-14 15:25:07 : [SUCCESS] File C:\Temp\RipBot264v1.26.0\Updates\cutsub.zip saved! 2023-06-14 15:25:07 : New section [fonts] detected 2023-06-14 15:25:07 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/fonts.zip to C:\Temp\RipBot264v1.26.0\Updates\fonts.zip 2023-06-14 15:25:07 : [SUCCESS] File C:\Temp\RipBot264v1.26.0\Updates\fonts.zip saved! 2023-06-14 15:25:07 : Downloading finished. 2023-06-14 15:28:33 : =========================[UPDATER ACTIVATED]========================= 2023-06-14 15:28:33 : Installing updates... 2023-06-14 15:28:34 : [SUCCES] C:\Temp\RipBot264v1.26.0\updates\core.zip has been correctly extracted! 2023-06-14 15:28:34 : [SUCCES] C:\Temp\RipBot264v1.26.0\updates\downloadposter.zip has been correctly extracted! 2023-06-14 15:28:41 : [SUCCES] C:\Temp\RipBot264v1.26.0\updates\ffmpeg.zip has been correctly extracted! 2023-06-14 15:28:41 : [SUCCES] C:\Temp\RipBot264v1.26.0\updates\mediainfo.zip has been correctly extracted! 2023-06-14 15:28:49 : [SUCCES] C:\Temp\RipBot264v1.26.0\updates\mkvtoolnix.zip has been correctly extracted! 2023-06-14 15:28:53 : [SUCCES] C:\Temp\RipBot264v1.26.0\updates\mpc.zip has been correctly extracted! 2023-06-14 15:28:54 : [SUCCES] C:\Temp\RipBot264v1.26.0\updates\x264.zip has been correctly extracted! 2023-06-14 15:28:54 : [SUCCES] C:\Temp\RipBot264v1.26.0\updates\x265.zip has been correctly extracted! 2023-06-14 15:28:54 : [SUCCES] C:\Temp\RipBot264v1.26.0\updates\scripts.zip has been correctly extracted! 2023-06-14 15:28:54 : [SUCCES] C:\Temp\RipBot264v1.26.0\updates\knlmeanscl.zip has been correctly extracted! 2023-06-14 15:28:54 : [SUCCES] C:\Temp\RipBot264v1.26.0\updates\masktools.zip has been correctly extracted! 2023-06-14 15:28:54 : [SUCCES] C:\Temp\RipBot264v1.26.0\updates\mvtools.zip has been correctly extracted! 2023-06-14 15:28:57 : [SUCCES] C:\Temp\RipBot264v1.26.0\updates\avisynth.zip has been correctly extracted! 2023-06-14 15:28:58 : [SUCCES] C:\Temp\RipBot264v1.26.0\updates\plugins_jpsdr.zip has been correctly extracted! 2023-06-14 15:28:58 : [SUCCES] C:\Temp\RipBot264v1.26.0\Updates\hdrtools.zip has been correctly extracted! 2023-06-14 15:28:58 : [SUCCES] C:\Temp\RipBot264v1.26.0\Updates\avscube.zip has been correctly extracted! 2023-06-14 15:28:58 : [SUCCES] C:\Temp\RipBot264v1.26.0\Updates\colormatrix.zip has been correctly extracted! 2023-06-14 15:28:58 : [SUCCES] C:\Temp\RipBot264v1.26.0\Updates\cutsub.zip has been correctly extracted! 2023-06-14 15:28:58 : [SUCCES] C:\Temp\RipBot264v1.26.0\Updates\fonts.zip has been correctly extracted! 2023-06-14 15:28:58 : Installation complete. 2023-06-14 15:28:59 : Next check after 2023-06-15 15:23:02
14th June 2023, 15:33 | #20226 | Link | |
2023-06-14 15:24:18 : Installing updates... 2023-06-14 15:24:18 : [SUCCES] W:\RipBot\updates\core.zip has been correctly extracted! 2023-06-14 15:24:18 : [SUCCES] W:\RipBot\updates\downloadposter.zip has been correctly extracted! 2023-06-14 15:24:19 : [ERROR] W:\RipBot\updates\ffmpeg.zip is corrupted. CRC32 mismatch. Expected value was 8ACC97BC but got 69E0F3CB 2023-06-14 15:24:19 : File W:\RipBot\updates\ffmpeg.zip has been deleted. 2023-06-14 15:24:19 : [SUCCES] W:\RipBot\updates\mediainfo.zip has been correctly extracted! 2023-06-14 15:24:19 : [ERROR] W:\RipBot\updates\mkvtoolnix.zip is corrupted. CRC32 mismatch. Expected value was 7F6D769A but got FB2A8BE0 2023-06-14 15:24:19 : File W:\RipBot\updates\mkvtoolnix.zip has been deleted. 2023-06-14 15:24:21 : [SUCCES] W:\RipBot\updates\mpc.zip has been correctly extracted! 2023-06-14 15:24:21 : [SUCCES] W:\RipBot\updates\x264.zip has been correctly extracted! 2023-06-14 15:24:22 : [SUCCES] W:\RipBot\updates\x265.zip has been correctly extracted! 2023-06-14 15:24:22 : [SUCCES] W:\RipBot\Updates\cutsub.zip has been correctly extracted! 2023-06-14 15:24:22 : [SUCCES] W:\RipBot\Updates\fonts.zip has been correctly extracted! 2023-06-14 15:24:22 : Installation complete. 2023-06-14 15:24:28 : Next check after 2023-06-15 15:23:38 |
15th June 2023, 03:41 | #20227 | Link | |
If you want to know more, send me a PM. Problems aside, I just can't understand why Atak has not updated the available build, on page 1, it's been nearly 2½ years since the release of 1.26.0, and there has been quite a few updates in that time, but no change...how hard can it be, why just to prove a point to archiel, he updated from 1.26.0 to 1.27.0, so why not post it !!!! |
16th June 2023, 20:00 | #20228 | Link |
is anyone also getting a Microsoft Defender alert flagging Ripbot264 for Trojan.Script/Sabsik.FL.B!ml warning?
this never happened before, but this morning Defender flagged ripbot and quarantine it for me. Tried downloading a fresh copy from here and the fresh copy also got flagged and quarantined. Atak are you trying to take over our machines? Last edited by howzz; 16th June 2023 at 20:25. |
16th June 2023, 21:03 | #20229 | Link |
so I'm getting the same thing as activoice with sub titles doubling up. I am getting it on just doing individual jobs, I haven't done any batch encoding. The subtitle is part of the mkv, not a separate .srt file. I am doing things exactly the same way as MANY times before , in avisynth, change render subtitles to on, click the .srt file and hit Ok. Always worked before. Don't know if this means anything, but if i go in and edit a job already in the que, and turn subtitles off, hit ok, then go back in and turn render subtitles back on, there are now a .srt and a .ssa in the job folder that wants me to choose from.
Update: so if i mux out the subtitle in mkvtoolnix as a .mks, then also save a new mkv without the embedded subtitle. then rename both the mkv and srt the same. Load up the mkv in ripbot and when I choose render subtitles it just goes to on and never prompts me for the srt which is exactly the way it worked in the past since the names are the same. Once I encode it this way, no more doubled up subtitles. So it is only when you choose a subtitle that is already part of the mkv. Update 2: So I figured out what is going on, when you render subs that are already embedded inside the mkv, ripbot is now rendering the subs as before in the final output (when you choose render subtitles), but it is ALSO adding the embedded sub title back into the mkv which is causing the doubling up of the subtitles when playing back. You are getting the embedded sub and the rendered sub at the same time. I can turn the embedded sub off in vlc player and it looks fine again. Looks like after you close avisynth and get back to the encoding settings screen, click the subtitles on the bottom right, change default and forced subtitles to none, then when you encode you will only get the rendered subs. Is there a way to globally disable adding the embedded subs if I only want to render them?? Last edited by rlev11; 16th June 2023 at 21:54. |
16th June 2023, 21:10 | #20230 | Link | |
same here |
16th June 2023, 22:39 | #20231 | Link | |
16th June 2023, 22:45 | #20232 | Link |
Yes I can do that, Just adds an additional step now to remember to do. It would be nice if there was somewhere in the settings to check to disable auto subtitle detection, or better yet, if you choose to render subtitles as part of the video, you would probably not want to add any embedded subtitles over top of them, so if rendered is selected, turn off adding the embedded subs automatically |
17th June 2023, 02:41 | #20233 | Link |
I have never been a fan of how RB deals with subtitles, the setting's are a little vague in description.
However, 99% of the time I only run the video thru RB, as I generally convert the audio to some other format/bitrate, and I extract the subs to spell check & check grammer, etc, then either have them it the same folder/directory as the re-muxed video/audio, or run them thru MKVToolNix. The only time I think I will be running everything (video, audio & subs) thru RB is if I need to edit using the new Segments option. I haven't used RB in well over a month, so I haven't run into these problems, anyway. |
17th June 2023, 09:41 | #20234 | Link | |
https://www.virustotal.com/gui/file/...50f0?nocache=1
17th June 2023, 09:51 | #20235 | Link |
I appreciate your response, but MS defender is the default AV, will be hard to expect everyone to uninstall or disable MS's default program and go with something else. I was in a bind today, so went back to my backup option, which was Handbrake. Low and behold, apparently they finally ported their program to 10-bit.
hope you find a way around it. |
17th June 2023, 11:51 | #20237 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 17th June 2023 at 11:53. |
18th June 2023, 10:53 | #20238 | Link |
Another small autoupdate relating to subtitles..
At first I thought there was a bug, but then I just started clicking, and got the menu....(hover over the text box)
There is also this new setting in RipBot264.ini Code:
SubtitlesFilterList= Last edited by TDS; 18th June 2023 at 11:03. |
18th June 2023, 16:46 | #20239 | Link | |
