Old 11th September 2021, 12:43   #19261  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
Originally Posted by legend View Post
I have nvidia GPU. I did not find x265 NVenc like other GUI. How do I enable this?
This has been asked about many times, and that's about as far as it goes
You'll have to look elsewhere to use this option.
Not poorly done, just doin' it my way !!!
So much to do, and so little time :(
Pauly Dunne is offline   Reply With Quote
Old 13th September 2021, 10:01   #19262  |  Link
LigH
LigH's Avatar
NVEnc is not x265. They are different H.265 video encoders. NVEnc uses your Nvidia GPU to encode H.265 video, x265 does not. Furthermore, x265 can be controlled in many more different ways than NVEnc, so it is suited much better for segmented encoding, and also it can run in several parallel instances (your GPU encoder chip can be used only by one process at a time). If you don't need segmented encoding, possibly distributed across a network of many PCs encoding different parts of a video, then you may not really need RipBot264...
New German Gleitz board
Old 13th September 2021, 12:38   #19263  |  Link
Pauly Dunne
Grumpy Old Man.
Very nicely explained, LigH.
So, not everyone has compatible nVidia GPU's, and also the fact that Distributed Encoding couldn't be used, then there's not really any point !!
So even if Atak took the time to implement this, only limited users would take what ever advantage GPU encoding might offer, if the spped of DE isn't there, and let's face it, DE is the most impressive function of any of the main available Encoding apps.
The same probably applies to wanting to use NV Decoding.
The only process that is probably an option would be to let RipBot do it's complete process, then before deleting the Temp files, to manually re-encode the files generated by RB, using NVEnc, so basically doubling the time taken to get the desired result.
Might be able to use the function introduced some time ago to run the "Job finished successfully.cmd" to automate some script / cli.
So just repeating what LigH said :-
Old 18th September 2021, 11:00   #19264  |  Link
phred1
Can't get RipBot EncodingServer to start
Hiya
Updated to latest version 1.21.6 from a much older version. Now I cant get the EncodingServer to start. Where do I start with finding what I have done wrong? All tools seems to be installed (some with green and some with black icons in the list).
phred1 is offline   Reply With Quote
Old 18th September 2021, 11:21   #19265  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Try again in SAFE MODE
Old 19th September 2021, 13:03   #19266  |  Link
Daringbaaz
Can Anyone Tell me Why There is some segments not Started or Not Completed,
Due to this My encoding Stopped on 99.4% and I Didn't Find any option to re-start That segments,
Please Help Me,
Daringbaaz is offline   Reply With Quote
Old 19th September 2021, 13:22   #19267  |  Link
Atak_Snajpera
You should check what EncodingServer (192.168.1.70:4000) is showing in both tabs.
Old 19th September 2021, 15:19   #19268  |  Link
Pauly Dunne
Grumpy Old Man.
Please Help Me,
I have that happen quite often...best thing is to Abort the Job.
Then restart the job, 9 times out of 10 it will remember how many chunks it has already encoded, and complete the job.
Old 21st September 2021, 21:04   #19269  |  Link
stillempty
@Atak - Thanks for all your hard work over the years. I have been using Ripbot264 for a long time and have always been able to tweak the things I need for excellent results. I hope you have not lost your passion for this program!
@Pauly Dunne - I truly understand the frustration of trying to improve things for strangers and not getting feedback. Sadly you probably only hear about the things that do not work. I would most definitely take a look at the builds you were putting together for the community!
I have been playing around with HDR10+ and Dovi recently and am now very close to having these things worked out in Ripbot264. I will share this info in the next few days, to hopefully save others some time.
Empty
stillempty is offline   Reply With Quote
Old 22nd September 2021, 01:28   #19270  |  Link
Pauly Dunne
Grumpy Old Man.
Empty
Hey Empty,
Thanks for the comment
I will be interested to see what you've come up with...
Old 25th September 2021, 10:37   #19271  |  Link
userx
userx's Avatar
Not able to create job
Hi
After last update i'm not able to apply new jobs to the queue.
The Done-button is not clickable.
Can anybody help?
userx is offline   Reply With Quote
Old 27th September 2021, 21:32   #19272  |  Link
ReinerSchweinlin
I encountered something similar in the avisynth tab: After "demo" of sharpening, the "ok" button grayed out. Selecting a crop area and switching back worked as a workaround.
Old 28th September 2021, 02:33   #19273  |  Link
Pauly Dunne
Grumpy Old Man.
3D Lut's Support
Hi Atak,
Remember way back here :-
https://forum.doom9.org/showthread.p...64#post1951664
I was able to add LUT's support to RipBot 3 weeks ago.
And then I read the "Avisynth+_Cube.txt"
Apply 3D LUT to HDR10 PQ clip obtained from DGSource():
loadplugin("...\dgdecodenv.dll")
loadplugin("...\avsresize.dll")
loadplugin("...\vscube.dll")
dgsource("THE GREAT WALL.dgi",fulldepth=true)
z_ConvertFormat(pixel_type="RGBP16",colorspace_op="2020ncl:st2084:2020:l=>rgb:linear:2020:f", dither_type="none")
Cube("...\test.cube")
z_ConvertFormat(pixel_type="YUV420P16",colorspace_op="rgb:linear:2020:f=>2020ncl:st2084:2020:l",dither_type="none")
As far as I know you can't use DGSource in RipBot... (or can you, and you've kept it to yourself)
It would be nice to use .dgi in RB.
BTW, everybody, an auto-update "snuck out" with LUT support
Old 28th September 2021, 17:00   #19274  |  Link
userx
userx's Avatar
@ReinerSchweinlin
Thanks for the hint.
I have to open the avisynth window, click into any setting box e.g. Resize -> OFF to get the OK of avisynth window clickable, exit this window by OK. Afterwards the Done-Button is clickable again.
Edit:
When changing the output filename / path AFTER this workaround DONE gets disabled again.
Old 28th September 2021, 21:16   #19275  |  Link
ReinerSchweinlin
Originally Posted by Pauly Dunne View Post
For several months now, I have made available very up to date & modified build's of RipBot264.
So as of date of posting this, I will no longer provide this service, and I will keep all my hard work to myself, and for my benefit only.
Sorry to hear that. In the last year, I have not had enough time to visit doom9 on a regular basis, so I didnīt even download your stuff or played with it. I can understand your frustration and - although I didnīt use your stuff - wanted to say thanx for your efforts and files...
@Atak
I am not sure if I did read correct between the lines - I got the impression you were absent a lot (but since I was absent, I am deriving that from what others wrote)... So I hope you are fine and of good health!
Old 29th September 2021, 01:48   #19276  |  Link
Pauly Dunne
Grumpy Old Man.
Hey Reiner,
I am happy to know that you would have been interested in trying my "stuff"....it doesn't mean that you can't still try it, but I doubt that I will post it again on the Forum.
Speaking of which, I don't want to sound like the Forum "detective", but you have posted no less than 31 times, so far this year, and one post was just before my post that you have quoted.....
I did have a couple of users "ask" for it, and they were very happy with all the extra filters & features, and even how much faster it seemed to be...but out of the many that downloaded it, I got nothin', hence my decision to "pull it".
Anyway, I would like to say that I will be pretty much leaving these forums, for the time being, I might post from time to time.
I will probably respond to any direct posts, but that's about it.
But when you don't seem to get the info you're seeking, and then if you sound a little frustrated, or defensive, they "warn" you, so why bother.
Old 29th September 2021, 02:40   #19277  |  Link
videoh
Useful n00b
Sounds contradictory to me. You got requests and good feedback but then you say you got nothing.
Also, you say you added filters and such. So it should not be an issue for you to add DGSource(), or am I missing something?
Old 29th September 2021, 03:16   #19278  |  Link
Pauly Dunne
Grumpy Old Man.
Come on videoh,
What I meant was, I had a couple of PM requests, BUT out of the close to a hundred or so downloads, when it was "open slather", I got nothing.
No contradiction...
I might be able to get it too work, but I don't know how to incorporate it into the way RipBot scripts are written, for encoding & decoding tasks.
It just confuses my old brain.......and I need to be "spoon feed", as I've said before, I really don't know what I'm doing, but if it works, it's great.
I think I've touched on this before with you, unless I'm getting the names mixed up.
I'd say that I wouldn't use it, I think it's nVidia based, and may not work with the Distributed Encoding process.
BUT there might be users out there that would like different options, and RipBot has none, it's LSmash or nothin'.
Old 29th September 2021, 04:49   #19279  |  Link
videoh
Useful n00b
We'll miss you, Pauly.
Old 29th September 2021, 14:54   #19280  |  Link
ReinerSchweinlin
Sherlock,
yes.
"having not mich time" or "being absent" doesnīt have to literally mean "no visit at all" Beleive me, I have been spending much less time on forums last year than I used to - I know, I was there
