#1 | Link |
Vapoursynth: Telecine with VIVIC
How do I accomplish these tasks in Vapoursynth, or just the last part, at least?
Automatic comparisons with telecine sources can be improved by utilizing VIVTC's frameprops. The comparison tool can skip frames marked with the Combed property to avoid leftover interlaced frames being left in the comparison. Additionally, decimation differences can be accounted for by utilizing VIVTC's scene change property and avoiding frames +-1 around scene changes. Last edited by jay123210599; 19th January 2025 at 22:07. |
#2 | Link | |
![]() Join Date: Oct 2001
Sounds like normal VIVTC usage with a fallback deinterlacer as post-processor for combed frames:
clip2clip = clip
clip2clip = havsfunc.QTGMC(Input=clip2clip, Preset="fast", opencl=True, TFF=True, FPSDivisor=2)
clip = core.vivtc.VFM(clip=clip, order=0, field=2, mode=1, mchroma=True, cthresh=9, mi=80, chroma=True, blockx=32, blocky=32, y0=16, y1=16, scthresh=12, micmatch=1, micout=False)
# VDecimate helper function
def postprocess(n, f, clip, deinterlaced):
if f.props['_Combed'] > 0:
return deinterlaced
else:
return clip
clip = core.std.FrameEval(clip=clip, eval=functools.partial(postprocess, clip=clip, deinterlaced=clip2clip), prop_src=clip)
clip = core.vivtc.VDecimate(clip=clip, cycle=5, chroma=True, dupthresh=1.1, scthresh=15, blockx=64, blocky=64))
This will only work as you intended if: a. VFM is tuned to the source to properly notice the residual combing after field matching b. the chosen deinterlacer is tuned to properly removes the combing. c. you tune the VDecimate setting to the source. Remembering: Quote:
I still prefer using TIVTC. (but sometimes I get better results using VIVTC) Cu Selur Last edited by Selur; 23rd January 2025 at 20:50. |
#3 | Link | |
I'm slightly confused: Take 29.97fps -> 23.976fps for example, theoretically 1 out of 5 frames should be dropped to get the "correct" output, but deinterlacing the combed frames may leave all 5 frames. Will it cause incorrect framerate and/or other problems because frames are now "unevenly distributed"? Or I'm misunderstanding the cause of combed frames. I thought they were frames that automatic IVTCs can't deal with. What if they are truly interlaced frames? Also, I heard of 2-pass ivtc, which seems to output a VFR clip. While it solves the frame rate problem, the implementation does not include a deint step for the residual before Vdecimate. I'm not sure if I should use a similar QTGMC+frameval after that? PS. the implementation refers to https://github.com/DJATOM/VapourSynt...htools.py#L370 |
#4 | Link |
About your confusion and telecine / 3:2 pull-down, look at https://en.wikipedia.org/wiki/Three-two_pull_down and the 'An illustration of the process' image,...
If your source if truely interlaced or mixed, this is the wrong approach. 2pass ivtc is mainly useful for mixed content, can't say much about it, since I never used it. Just wanted to answer your initial question.
#5 | Link |
How do you use this with 59.94 material that you want to turn into 23.976?
I recently downloaded StaxRip and Hybrid to use as a replacement for MeGUI for processing HDTV recordings from our local ABC and Fox stations, but I haven't figured out how to do it on StaxRip. Is there a VIVTC equivalent to TFM(), TDecimate(cycleR=3). That's what I use in MeGUI. |
#6 | Link | ||
TFM() # only if content has combing TDecimate(mode=1, cycle=5, cycleR=3) # every 5 frames keep cyble-cycleR = 2 If you are not sure a pull-down should be applied, you might better want to use "sRestore(frate=23.976)" for the decimation. Quote:
clip = core.vivtc.VFM(clip, order=0)
return deinterlaced
else:
return clip
clip = core.vivtc.VDecimate(clip)
| Tags |
| decimation, interlaced, telecine, vapoursynth, video comparison |
| Thread Tools | |
| Display Modes | |
