26th November 2024, 20:57 | #1 | Link |
Question about elementary AVC streams
So, I have two .avc streams, extracted from a BD, they are both a remux, no reencode whatsoever, the number of frames are the same, and comparing side by side the frames are virtually the same, no differences at all, same source, same result.
But for some reason, the hashes of the files are different. I was wondering, why could that be? Thanks in advance! |
29th November 2024, 18:10 | #2 | Link | |
a. If there were encoding involved: Multithreading,.. encode the same source with x264 and use '--non-deterministic' and the outputs will not be identical. b. If I remember correctly, even without encoding, muxing into mkv and extracting with different mkvtoolnix versions might result in non-identical outputs due to header handling,... Cu Selur |
29th November 2024, 18:19 | #3 | Link | |
a. No encoding, both should be just a remux. b. I extracted the avc streams them with the same mkvtoolnix versions, but maybe they were muxed into mkvs before with different mkvtoolnix versions, would that affect the result? I guess it shouldn't... It's not like I want to achieve something here, I'm just curious. |
1st December 2024, 13:03 | #8 | Link |
Sorry, but I still don't get it. Isnt the "the actual video data" the extracted avc stream? Are you saying that the .avc file has headers inside that cannot be removed/ignored in order to create a hash for only video data?
1st December 2024, 14:28 | #9 | Link |
SEI (supplemental enhancement information) messages do not affect the core decoding process, but can indicate how the video is recommended to be post-processed or displayed. So parts of SEI messages can be dropped, modified,... (repeated more or less frequent) when extracting the video stream.
So if you have a source stream that had the (complete) SEI data only in the first IDR frame but upon extraction is added to each IDR frame the extracted stream would be more 'robust' (to cutting/damage) than the original, while the data for the core decoding process hasn't changeg. => you might want to read up on SEI |
1st December 2024, 18:19 | #11 | Link |
Life's clearer in 4K UHD
It's a shame there's not a tool for adjusting the properties of AVC and HEVC elementary streams like 'Re-stream' has been able to do for many years ago with MPEG-2 elementary streams.
2nd December 2024, 06:34 | #14 | Link |
You can try to open both files in the analyzer like https://media-analyzer.pro/. Perhaps you might spot some differences right away. Once you find them, it’ll be easier to fix them if needed.
2nd December 2024, 15:13 | #15 | Link | |
2nd December 2024, 20:49 | #17 | Link | |
EDIT I actually managed to find differences, seems like one of the streams have a few of these: 00324107b7AVC End Of Sequence #31789 Is there a way to edit them or something similar, remove that data (or whatever it is), just to check again both files and see if they have the same hash? If not, in any case, which stream would be better, if I had to keep one? Thanks guys! Last edited by eXtremeDevil; 2nd December 2024 at 21:32. |
2nd December 2024, 22:06 | #18 | Link | |
ffmpeg -i bfd.264 -bsf:v filter_units=pass_types=1-5 -c copy out.264 Last edited by Z2697; 4th December 2024 at 15:45. Reason: "-c copy" |
3rd December 2024, 19:40 | #20 | Link |
I tried both commands, and the results of the "different" avc files are identical, same hash. Can we then say the videos are virtually the same? Since one has those "End Of Sequence" data, which video could be better to keep? I don't quite understand what "End Of Sequence" data do, and if it's better or irrelevant to have it.
EDIT BTW, why the result file is 3gb and the .avc file is 28gb? Last edited by eXtremeDevil; 4th December 2024 at 00:13. |
