5th November 2021, 15:06 | #602 | Link |
I have some problem with oyster_deringing
I've added float "h" in the function : Code:
oyster_Deringing(clip src, clip ref, int "radius", float "h", float "sigma", float "mse0", I've change the lesser or equel for greater or equal to 0 here: Code:
Assert(h>=0, "Oyster.Deringing: h has to be greater than 0!") If I put strength2 = 1.1 before the function call in line 364 I get script error:invalid arguments to function oy_loop. |
5th November 2021, 18:04 | #603 | Link |
Thanks for the report! I will have a look and report back, but Oyster and Plum are both WIP (work in progress) so I'm not positive it works even when fixed. To start with the BM3D plugin isn't fully ported so many settings are missing which may be critical for the correct output, and second I'm not sure mvtools is as robust in AviSynth+ as it is in VapourSynth, one example is 32-bit support which has some issues as reported here.
EDIT: ok updated. Good luck making it work, it hangs on my rig. I guess iterating KNLMeansCL four times isn't actually avisynth friendly.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 5th November 2021 at 18:30. |
6th November 2021, 12:45 | #605 | Link |
Sorry guys, but I don't see what you guys are seeing.
DNR..........................................................................DNR+LFR+DCTR ............ Anyway I have some ideas to improve the DCTFlicker pass. On another note, yes MatchClip() which is required for prefilter=5 and some other functions as a replacement for Utils-r41's MatchColorFormat() is not yet released (due in TransformsPack). I'm trying to catch up with all the frameprops changes by pinterf.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
6th November 2021, 14:25 | #606 | Link |
Acid fr0g
This part (present in raw) plain and simply disappears. The only one with some hint of it is DNR+LFR only. Plus, I am having the error: Script error: There is no function named 'MatchClip'. (D:/Programmi/Media/AviSynth+/plugins64/SMDegrain-3.3.5d~Dogway.avsi, line 887) (D:/Programmi/Media/AviSynth+/plugins64/SMDegrain-3.3.5d~Dogway.avsi, line 217) Perhaps I have deleted some necessary plugin. Which is which?
@turment on Telegram |
7th November 2021, 18:08 | #609 | Link |
Ok, maybe I did wrong by presenting all the steps, but I like to keep transparent always. My point was DNR+LFR+DCTR improving over DNR/DNR+LFR, which I think it does. There are dozens of different ways to fix the pointed issue, one of them is raising the cutoff but it wasn't my intention to show an example of perfect denoising, because it simply doesn't exist as stated by Didée. I'm trying hard and have some things in mind to improve low frequency denoising.
@tormento, read my previous post. MatchClip is included in yet-to-be-released TransformsPack, which got delayed due to latest avisynth changes in frameprops. Hopefully I can release tomorrow. It replaces MatchColorFormat from Utils-r41 so one less dependency. It's only needed for prefilter=5 though.
7th November 2021, 20:00 | #611 | Link |
It's written but not released. I was holding back all my scripts for over a week solely because MatchClip (read about the conventions disaster here), so I pulled the trigger.
If you are too desperate use this (disclaimer, use latest avs+): Code:
# Matches 'a' to 'b' clip format (size, length, color model, Jab, bitdepth) function MatchClip (clip a, clip b, string "kernel", string "matrix", bool "length", bool "fast") { krn = Default (kernel, "Spline16") fst = Default (fast, true) mfc = Default (length, false) # Match also framecount YUY2 = b.IsYUY2() rgbb = b.isRGB() rgba = a.isRGB() w = b.width() wa = a.width() h = b.height() ha = a.height() fc = b.FrameCount() fca = a.FrameCount() p_type = b.PixelType() p_typea = a.PixelType() bib = b.BitsPerComponent() bia = a.BitsPerComponent() isHD = (w > 1099 || h > 599) isHDa = (wa > 1099 || ha > 599) isUHD = (w > 2599 || h > 1499) isUHDa = (wa > 2599 || ha > 1499) mat = Default(matrix, rgbb != rgba ? isUHD ? "Rec2020" : isHD ? "Rec709" : "Rec601" : Undefined()) a bib > bia ? ConvertBits(bib, fulls=rgba) : last if (!fst) { ConvertFormat(w, h, fmt_i=p_typea, fmt_o=p_type, cs_in=mat, cs_out="", kernel=krn, gamma=false, tv_range_in=!rgba, tv_range_out=!rgbb, fulls=rgba, fulld=rgbb, show=false) } else { rgbp = rgbb && b.isPlanar() isScl = w != wa || h != ha mod = rgba && rgbb || isy(a) && isy(b) ? 1 : 2 yv411 = b.isYV411() yv411a = a.isYV411() yv444 = b.is444() yv444a = a.is444() fmt = Format_fuzzy_search(b, p_type, bib) fmta = Format_fuzzy_search(a, p_typea, bia) bc = bicubic_coeffs(krn) krn = bc[1]>=0. ? "Bicubic" : krn cplace = rgbb || yv444 || yv411 ? "MPEG1" : isUHD ? "top_left" : "MPEG2" cplacea = rgba || yv444a || yv411a ? "MPEG1" : isUHDa ? "top_left" : "MPEG2" not42 = LeftStr(fmta[1],2) != "42" # Match dimensions isScl ? w > h ? RatioResize(w,mode="adjust2w",kernel=krn,mod=mod,b=bc[0],c=bc[1]) : \ RatioResize(h,mode="adjust2h",kernel=krn,mod=mod,b=bc[0],c=bc[1]) : last PadResize(w,h,mode="dilate", mod=mod) # ConvertBackToYUY2 bug: https://forum.doom9.org/showthread.php?p=1038027#post1038027 isy(b) ? rgba ? DotClip([0.298967,0.586421,0.114612]) : ConvertToY(mat) : \ rgbb ? rgbp ? Eval( "ConvertToPlanarRGB (mat,interlaced=false"+(yv411a ? "" : ",ChromaInPlacement=cplacea")+", chromaresample=krn)") : \ Eval( "ConvertTo" +string(fmt[3])+"(mat,interlaced=false"+(yv411a ? ")" : ",ChromaInPlacement=cplacea, chromaresample=krn)")) : \ yv411 ? Eval( "ConvertToYV411 (false,mat," +(not42 ? "" : """ChromaInPlacement=cplacea,""")+"chromaresample=krn)") : \ YUY2 && rgba ? Eval("""ConvertBackToYUY2 (mat """) : \ Eval( "ConvertToYUV"+string(fmt[1])+"(false,mat," +(not42 ? "" : "ChromaInPlacement=cplacea,")+" chromaresample=krn"+(yv444 ? ")" : ",ChromaOutPlacement=cplace)")) } bia > bib ? ConvertBits(bib, dither= 1, fulls=rgbb) : last mfc ? fca > fc ? Trim(last, fc-1) : last+BlankClip(b,fc-1) : last # Planar to Interleaved YUY2 && !rgba ? ConvertToYUY2() : last }
8th November 2021, 17:59 | #613 | Link |
Acid fr0g
Another needed function:
Script error: There is no function named 'Format_fuzzy_search'. (D:/Programmi/Media/AviSynth+/plugins64/MatchClip~Dogway.avsi, line 35) (D:/Programmi/Media/AviSynth+/plugins64/MatchClip~Dogway.avsi, line 56)
8th November 2021, 18:07 | #614 | Link |
That's in TransformsPack. I'm finishing the script (QC) just waiting for pinterf input so I don't do things twice.
11th November 2021, 20:59 | #615 | Link |
Updated DCTFilter, hope it's fine now:
I will upload tomorrow with TransformsPack, which isn't finished of course but it's fine to play with already.
19th November 2021, 11:12 | #616 | Link |
Acid fr0g
Much better. Thanks.
Did you alredy implemented atan2 expr from Avisynth+ 3.7.1 test build 27 (20211117) in your scripts? I saw some legacy comments but the functions are still there.
19th November 2021, 17:46 | #617 | Link |
Yes, I forgot to add in the changelog. So far it's only used for the cylindrical models in TransformsPack. It's a tiny bit faster than my approx. but it's internal and more precise so a winner for me. I don't think 'atan' is yet optimized but I didn't see it used in any of my scripts.
I will keep the legacy functions for reference, this is also some kind of algo spread sheet for learning.
19th November 2021, 19:28 | #618 | Link |
By the way, I want to introduce SoftLimiter() a filter I have been working on for the last days. It's an inclusive limiter, that means not only it drops out out of range values, but also will include out of range values in a rolloff manner. This is adaptive in the sense that further out of range values will rolloff stronger.
There's also a dynamic mode where you don't need to input the range floor/ceil after inspection. It uses ShowChannels() which works only over 8-bit so precision is not very granular. dyn=0 is static (default), dyn=1 uses accumulative loose min/max, which is a set and forget safe mode, dyn=2 is more granular and probably better when the source range floor/ceil varies, and dyn=3 which is very granular. For comparison this is SoftLimiter2() by raffriff42 And here an example with a tailored sample with range floor at 11 and ceil at 245: Limiter() SoftLimiter() I also optimized the HSV, IPT and OkLab conversion functions and they are ready to shine, now work over any bitdepth. Here's a comparison for the hue perceptual uniformity. Since Luma and Chroma channels are mapped differently I matched those by eye. HSV IPT OkLab
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 26th November 2021 at 17:32. |
19th November 2021, 23:13 | #620 | Link | |
Banana User
InpaintDelogo, DoomDelogo, JerkyWEB Fixer, Standalone Faster-Whisper - AI subtitling |
avisynth, dogway, filters, hbd, packs |
