Old 9th December 2024, 20:54   #4921  |  Link
jimbobub
Staxrip, Hybrid and Ripbot264 all have audio sync being off. Handbrake, Clever ffmpeg, avidemux and tmpgenc all have good audio sync. I'm converting a home video from dvd that is, according to mediainfo, 29.97 interlaced tff. h264 is the encoder output. I've tried encoding the audio to ac3 and other times I tried passthrough. With various staxrip decoders some show the source file as 29.97 and others 29.918. My goal is to be able to use qtgmc deinterlacer. I tried yadif bob as well with no luck with proper a/v sync. Is there a setting that I am missing that could help? Thanks.
jimbobub is offline   Reply With Quote
Old 10th December 2024, 03:22   #4922  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
You may report the sourcefilters that assume the wrong fps,
and for DVD decoding I suggest DG's MPEG2Source or DGSource (indexing comes first)
http://avisynth.nl/index.php/DGDecode
http://avisynth.nl/index.php/DGDecNV
and you may feed a Avisynth Script to Staxrip ending with Assumefps("ntsc_video")
Old 10th December 2024, 13:33   #4923  |  Link
jimbobub
Thanks for you response. I'm an intermediate, just barely, when it comes to playing around with stuff such as with the code editor. I'm willing to try but will need some help if you or others are willing. I have staxrip 2.42.2. I did see mpeg2source listed in the source options and I did try that decoder before and it did list the source frame rate correctly but after encoding to mp4, the audio is out of sync. I did not see dgsource listed in source decoders. Regarding dgdecode and dgdecnv, I do not know how to add them to staxrip if not already in there. If they are how to adjust the settings?
Old 10th December 2024, 14:47   #4924  |  Link
jimbobub
To be more exact on what I am trying to do. I have home videos that were transferred from vhs to dvd. I want to convert the dvd mpegs (29.97 interlaced tff) to mp4 bluray (59.94 progressive). Using handbrake for example I was able to do all this with no problem. I used yadif bob for a nice smooth motion video and sync was fine. Handbrake however has no color, contrast and brightness adjustments. On the original vhs videos these are a bit too high. What I like about staxrip is qtgmc and the color, contrast and brightness adjustments.
Old 10th December 2024, 16:13   #4925  |  Link
Emulgator
Emulgator's Avatar
You may upload a sample.
wetransfer.com, up to 2GB free, uptime now down to 3 days IIRC.
Old 13th December 2024, 13:23   #4926  |  Link
Shuichiyagami
iam just use Staxrip recently, but now i want to try external filters like sharpening, so can somebody gave me the tutorial to use external filters?
Shuichiyagami is offline   Reply With Quote
Old 14th December 2024, 18:27   #4927  |  Link
Emulgator
Emulgator's Avatar
You would feed an AviSynth script to Staxrip.
Any tutorial comes with the script or can be taken from
http://avisynth.nl/index.php/Externa...ers#Sharpeners
Old 31st December 2024, 13:22   #4928  |  Link
Shuichiyagami
I got an error like this when use anti-aliasing script.
Script Error
Python exception: Failed to load L:\Fansub\StaxRip-v2.44.0-x64\Apps\Plugins\VS\nnedi3\NNEDI3CL.dll. GetLastError() returned 126. The file you tried to load or one of its dependencies is probably missing.
Traceback (most recent call last):
File "src\\cython\\vapoursynth.pyx", line 3124, in vapoursynth._vpy_evaluate
File "src\\cython\\vapoursynth.pyx", line 3125, in vapoursynth._vpy_evaluate
File "L:\Download\[SubsPlease] Shadowverse Flame - 31 (1080p) [EC8C15F3].mkv_temp\[SubsPlease] Shadowverse Flame - 31 (1080p) [EC8C15F3]_new_view.vpy", line 20, in <module>
core.std.LoadPlugin(r"L:\Fansub\StaxRip-v2.44.0-x64\Apps\Plugins\VS\nnedi3\NNEDI3CL.dll", altsearchpath=True)
File "src\\cython\\vapoursynth.pyx", line 2860, in vapoursynth.Function.__call__
vapoursynth.Error: Failed to load L:\Fansub\StaxRip-v2.44.0-x64\Apps\Plugins\VS\nnedi3\NNEDI3CL.dll. GetLastError() returned 126. The file you tried to load or one of its dependencies is probably missing.
And how to automatically not include subtitle and attachment if the video we want to encode already have that?
Old 1st January 2025, 12:58   #4929  |  Link
Emulgator
Emulgator's Avatar
the r in Front is suspicious to me. Does it belong there ? Remove it. Reload.
Goto L:\Fansub\StaxRip-v2.44.0-x64\Apps\Plugins\VS\nnedi3\NNEDI3CL.dll
Is NNEDI3CL.dll there ? If yes, report to the StaxRip developers.
Sub/Attach muxing settings: Staxrip implements these project-based and assumes these as default=yes, keep them
You just untick these:
Project -> Options -> Subtitles -> Default Subtitle -> None
Project -> Options -> Attachments -> Add Attachments to Muxing -> untick
Old 1st January 2025, 13:08   #4930  |  Link
Z2697
It's python "raw string literal" that basically just saves the need for escaping (i.e. you can see the single backslash is used instead of double backslash you would normally need)
Z2697 is offline   Reply With Quote
Old 1st January 2025, 13:24   #4931  |  Link
Z2697
Script Error
The template and start up option is likely what you want. Although I'm not sure if the container options is saved with template, haven't used staxrip for quite a while.
Old 1st January 2025, 13:38   #4932  |  Link
Emulgator
Emulgator's Avatar
r -> python "raw string literal"
Ah, ok.
Old 1st January 2025, 18:18   #4933  |  Link
DMD
DMD's Avatar
Happy New Year to all
In the X264 encoder section (StaxRip 2.44.1) I can't get the commands to hide the items displayed in mediainfo “Witing library and Encoding setting”.
Any ideas?
Thanks
my PC with Ryzen 7950X
DMD is offline   Reply With Quote
Old 1st January 2025, 20:43   #4934  |  Link
Leo 69
Any ideas?
Thanks
There's no such setting in StaxRip. You can remove that information with ffmpeg:
ffmpeg -i input.mkv -c copy -bitexact -map_metadata -1 -vbsf filter_units=remove_types=6 output.mkv
Leo 69 is offline   Reply With Quote
Old 1st January 2025, 21:26   #4935  |  Link
DMD
DMD's Avatar
Can I include the command line in the Custom section?
Old 2nd January 2025, 06:06   #4936  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
--------------------------- Frame Mismatch ---------------------------
WARNING: Target file has -1 frames, but should have 59914 frames!
Encoding was probably terminated at 0,0% with a mismatch of 59915 frames!
Has anyone a solution for this, this is every time during x265 Encode.
Have sync issues with the DV layer, can't fix this error.
x264 core:164 r3198+7 bf259fa [Mod by Patman] modified (writes no encoding settings). This is the Encoder from StaxRip 2.44.1
https://mega.nz/folder/Qtch1Yjb#6pTc3OusOT7yrOaijOHLsA
-QfG- is offline   Reply With Quote
Old 2nd January 2025, 08:42   #4937  |  Link
DMD
DMD's Avatar
Thank you very much
It was what I was looking for, I will keep it carefully.
Old 2nd January 2025, 17:20   #4938  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
If you have a new x264.exe you can send it to me and i will modify the file .
Old 2nd January 2025, 20:39   #4939  |  Link
DMD
DMD's Avatar
Thank you.
I'll keep abreast of new releases.
Old 4th January 2025, 16:38   #4940  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Ok, here the funny result. Using an Old StaxRip Version (v2.3.1) with most identcal settings:
(I can't use 2.44 templates with 2.3.1, so i rebuild it for 2.3.1)
(Thread #4396)
STAXRIP v2.3.1:
--------------------------- Video encoding ---------------------------
x265 4.1.0.54 [PatMan]
B:\_RIPPING\StaxRip_2.1.3.0\Apps\Support\avs2pipemod\avs2pipemod64.exe -y4mp B:\VIDEO\Arcane.S01E09_temp\Arcane.S01E09.avs | B:\_RIPPING\StaxRip_2.1.3.0\Apps\Encoders\x265\x265.exe --crf 12 --preset slower --tune animation --profile main10 --level-idc 5.1 --vbv-bufsize 90000 --vbv-maxrate 90000 --hme-search umh,umh,star --hme --refine-analysis-type off --min-keyint 1 --keyint 24 --no-open-gop --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1)" --hdr10 --colorprim bt2020 --colormatrix bt2020nc --transfer smpte2084 --range limited --repeat-headers --no-info --hrd --aud --uhd-bd --no-strong-intra-smoothing --subme 5 --deblock -1:-1 --bframes 4 --ref 4 --no-sao --no-rect --no-amp --sar 1 --refine-mv 0 --rd 6 --rdoq-level 1 --tu-intra 1 --tu-inter 1 --limit-tu 0 --output-depth 10 --frames 56310 --y4m --output B:\VIDEO\Arcane.S01E09.hevc -
avs2pipemod[info]: writing 56310 frames of 24000/1001 fps, 3840x2160,
sar 0:0, YUV-420-planar-10bit progressive video.
y4m [INFO]: 3840x2160 fps 24000/1001 i420p10 sar 1:1 unknown frame count
raw [INFO]: output file: B:\VIDEO\Arcane.S01E09.hevc
x265 [INFO]: HEVC encoder version 4.1+54+9-0c07fe364 [Mod by Patman]
x265 [INFO]: build info [Windows][MSVC 1942][64 bit] 10bit
x265 [INFO]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
x265 [INFO]: Main 10 profile, Level-5.1 (High tier)
x265 [INFO]: Thread pool created using 32 threads
x265 [INFO]: Slices : 1
x265 [INFO]: frame threads / pool features : 6 / wpp(34 rows)
x265 [INFO]: Coding QT: max CU size, min CU size : 64 / 8
x265 [INFO]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra
x265 [INFO]: HME L0,1,2 / range / subpel / merge : umh, umh, star / 48 / 5 / 4
x265 [INFO]: Keyframe min / max / scenecut / bias : 1 / 24 / 40 / 5.00
x265 [INFO]: Lookahead / bframes / badapt : 40 / 4 / 2
x265 [INFO]: b-pyramid / weightp / weightb : 1 / 1 / 1
x265 [INFO]: References / ref-limit cu / depth : 4 / off / on
x265 [INFO]: AQ: mode / str / qg-size / cu-tree : 2 / 0.4 / 32 / 1
x265 [INFO]: Rate Control / qCompress : CRF-12.0 / 0.60
x265 [INFO]: VBV buffer / maxrate / init : 90000 / 90000 / 0.900
x265 [INFO]: tools: limit-modes rd=6 psy-rd=0.40 rdoq=1 psy-rdoq=1.00
x265 [INFO]: tools: rskip mode=1 signhide tmvp b-intra deblock(tC=-1:B=-1)
x265 [INFO]: tools: dhdr10-info
avs2pipemod[info]: finished, wrote 56310 frames [100%].
avs2pipemod[info]: total elapsed time is 24316.033 sec.
x265 [INFO]: frame I: 2508, Avg QP:12.07 kb/s: 43225.82
x265 [INFO]: frame P: 14182, Avg QP:14.24 kb/s: 30505.64
x265 [INFO]: frame B: 39620, Avg QP:18.04 kb/s: 10256.31
x265 [INFO]: Weighted P-Frames: Y:18.9% UV:9.0%
x265 [INFO]: Weighted B-Frames: Y:10.9% UV:5.4%
encoded 56310 frames in 24324.01s (2.31 fps), 16824.65 kb/s, Avg QP:16.81
Start: 09:13:44
End: 15:59:08
Duration: 06:45:24
General
Complete name : B:\VIDEO\Arcane.S01E09.hevc
Format : HEVC
Format/Info : High Efficiency Video Coding
File size : 4.60 GiB
Video
Format : HEVC
Format profile : Main 10@L5.1@High
HDR format : SMPTE ST 2086, HDR10 compatible
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
---------------------------- Job Complete ----------------------------
Start: 09:13:43
End: 15:59:08
Duration: 06:45:25
StaxRip v2.44.1:
x265 4.1+54+9-0c07fe364-.Mod-by-Patman.-x64-avx2-msvc1942
B:\_RIPPING\StaxRip\Apps\Encoders\x265\x265.exe --reader-options library=B:\_RIPPING\StaxRip\Apps\FrameServer\AviSynth\AviSynth.dll --crf 12 --preset veryslow --tune animation --vbv-bufsize 80000 --vbv-maxrate 90000 --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1)" --hdr10 --colorprim bt2020 --colormatrix bt2020nc --transfer smpte2084 --range limited --chromaloc 2 --dolby-vision-profile 8.1 --dolby-vision-rpu "B:\VIDEO\Arcane - League of Legends - Season 1\Arcane.German.DTSHD.S01E09.2160p.UHD.BluRay.DV.HDR.HEVC.Remux.Repack-QfG.mkv_temp\HDRDVmetadata.rpu" --profile main10 --level-idc 5.1 --rd 6 --rdoq-level 1 --tu-intra 1 --tu-inter 1 --limit-tu 0 --sar 1 --qcomp 0.6 --ref 4 --bframes 4 --selective-sao 0 --rskip 0 --no-open-gop --no-info --no-sao --no-rect --no-amp --hme-search umh,umh,star --hme --repeat-headers --aud --uhd-bd --min-keyint 1 --keyint 24 --hrd --hdr --hdr-opt --output-depth 10 --output "B:\VIDEO\Arcane - League of Legends - Season 1\Arcane.German.DTSHD.S01E09.2160p.UHD.BluRay.DV.HDR.HEVC.Remux.Repack-QfG.hevc" --input "B:\VIDEO\Arcane - League of Legends - Season 1\Arcane.German.DTSHD.S01E09.2160p.UHD.BluRay.DV.HDR.HEVC.Remux.Repack-QfG.mkv_temp\Arcane.German.DTSHD.S01E09.2160p.UHD.BluRay.DV.HDR.HEVC.Remux.Repack-QfG.avs"
avs+ [INFO]: using external Avisynth library from: "B:\_RIPPING\StaxRip\Apps\FrameServer\AviSynth\AviSynth.dll"
avs+ [INFO]: AviSynth+ 3.7.3 (r4003, 3.7, x86_64)
avs+ [INFO]: 3840x2160 fps 24000/1001 i420p10 sar 1:1 frames 0 - 56309 of 56310
raw [INFO]: output file: B:\VIDEO\Arcane - League of Legends - Season 1\Arcane.German.DTSHD.S01E09.2160p.UHD.BluRay.DV.HDR.HEVC.Remux.Repack-QfG.hevc
x265 [INFO]: HME L0,1,2 / range / subpel / merge : umh, umh, star / 48 / 4 / 5
x265 [INFO]: References / ref-limit cu / depth : 4 / off / off
x265 [INFO]: VBV buffer / maxrate / init : 80000 / 90000 / 0.900
x265 [INFO]: tools: rd=6 psy-rd=0.40 rdoq=1 psy-rdoq=1.00 signhide tmvp b-intra
x265 [INFO]: tools: strong-intra-smoothing deblock(tC=1:B=1) dhdr10-info
x265 [INFO]: VES muxing with Dolby Vision RPU file successful in x265
x265 [INFO]: frame I: 2508, Avg QP:14.78 kb/s: 28317.83
x265 [INFO]: frame P: 14182, Avg QP:16.85 kb/s: 18461.53
x265 [INFO]: frame B: 39620, Avg QP:19.81 kb/s: 5210.96
x265 [INFO]: Weighted P-Frames: Y:20.3% UV:10.4%
x265 [INFO]: Weighted B-Frames: Y:13.2% UV:7.2%
encoded 56310 frames in 29991.06s (1.88 fps), 9577.36 kb/s, Avg QP:18.84
Start: 04:32:34
End: 12:52:27
Duration: 08:19:52
General
Complete name : B:\VIDEO\Arcane - League of Legends - Season 1\Arcane.German.DTSHD.S01E09.2160p.UHD.BluRay.DV.HDR.HEVC.Remux.Repack-QfG.hevc
Format : HEVC
File size : 2.63 GiB
Frame rate : 23.976 FPS
Video
Format : HEVC
Color space : YUV
Bit depth : 10 bits
Start: 04:32:34
End: 12:52:27
Duration: 08:19:52
WARNING: Target file has -1 frames, but should have 56310 frames!
Encoding was probably terminated at 0,0% with a mismatch of 56311 frames!
I think there is any pipeline problem with StaxRip 2.44x.
I using the same Encoder (x265 from StaxRip 2.44.1).
Also no A/V sync errors after Muxing FEL from original file.
