Old 6th January 2023, 18:10   #1641  |  Link
Nikse555
Originally Posted by Matt Kirby View Post
Why isn't it possible to set linebreaks as shown in video preview of an ass -file "WrapStyle 0"
IMO this is a poor choice.
Wrap style 0 gives way too long lines that are difficult to read and it also does not split lines at periods or commas which also improves readability.
You can get pretty close by this:
In Options - Settings - General - Rules: Set "Single line max length" to 80 (depending on font/style)
In Options - Settings - Tools - Auto break: keep only "Break by pixel width"
(When "Advanced Sub Station Alpha" was born and monitors/TVs were small, WrapStyle 0 was probably okay... around 1996...)
Nikse555 is offline   Reply With Quote
Old 6th January 2023, 18:50   #1642  |  Link
Matt Kirby
Ah ok, I understand you. My workflow is (when I translate subs) that I stretch the subs in X-Scale to 134 % at a 16:9 film. So an item becomes no more width as 4:3 in a display. After finished work I set the x-factor back to 100%. So I thought I could save the line breaks (I made in 134 % modus).
Matt Kirby is offline   Reply With Quote
Old 6th January 2023, 21:08   #1643  |  Link
Nikse555
OK, zooming in temporary with wrap style 0 makes sense. Still, you can make better breaks by taking comma/periods into account.
Sorry, SE does not have a single-line-max-pixel-width which is probably what wrap style 0 uses.
Old 15th January 2023, 19:29   #1644  |  Link
Atlantis
I have OCRed and got an incorrect word LI. The problem is, Spell Check doesn't catch it. It's in French and LI is not in the Names List or User word list.
Where is it? I want to remove it. We need a search function that can find a word in any list.
Atlantis is offline   Reply With Quote
Old 23rd January 2023, 07:09   #1645  |  Link
Nikse555
@Atlantis: Sorry, the French spell check dictionary allows this... perhaps you can find another French dictionary? (SE requires Hunspell/OpenOffice dictionaries. The .dic/.aff files needs to be placed in the "Dictionaries" folder)
Old 27th January 2023, 00:28   #1646  |  Link
Atlantis
I don't understand. The French spell check dictionary allows what exactly? Do you mean LI is a word in the dictionary?
Old 29th January 2023, 14:38   #1647  |  Link
Amstramgram
Hello everybody !
In 3.6 version, is there a way to permanently change default style for ssa subtitles ?
It was quite easy in 3.5 but I can't find how to do it in the new version.
Thank you in advance for your answers.
Amstramgram is offline   Reply With Quote
Old 29th January 2023, 15:53   #1648  |  Link
Nikse555
Yes, "LI" is accepted by the French spell check dictionary.
Old 29th January 2023, 18:00   #1649  |  Link
Nikse555
Originally Posted by Amstramgram View Post
Hello everybody !
SE has more features for "Advanced Sub Station Alpha" (.ass). For ASSA you can set a default style in the "ASSA styles windows" which is the big red "A" in the toolbar when an ASSA file is open.
I think the default SSA style, just uses the default ASSA style...
Old 30th January 2023, 17:35   #1650  |  Link
Amstramgram
Thanks for your answer !
It almost works !
New default settings registered for ass files are passed to ssa but with some random strange differences in margins (left margin passes from 10 to 0, right margin from 10 to 2) or alignment (from center to left) !!!.
Old 31st January 2023, 20:57   #1651  |  Link
Nikse555
@Amstramgram: OK, I see the margin error, thx
Should be fixed here: https://github.com/SubtitleEdit/subt...leEditBeta.zip
(shadow was written as e.g. "1,0" and hence comma separated styles after, like margins, was displaced)
Also, I though people used ASSA and not SSA. Any specific reason? I guess I could add a separate default SSA style...
Old 1st February 2023, 13:45   #1652  |  Link
Amstramgram
Thank you so much @Nikse555 !!!
It works… Except for colors (I think hexa values should be converted to long integer BGR)…
The reason why i need ssa is that I'm an old, old, old VirtualDub (now VirtualDub 2) user.
I have never found a recent equivalent as versatile...
It's a real Swiss army knife with its editing features, audio visualization, etc...
But the only way to insert subtitles properly is to use Avery Lee's old 32-bit subtitle plugin. And this plugin only supports ssa format…
Old 1st February 2023, 21:26   #1653  |  Link
Nikse555
@Amstramgram: Are colors correct now? https://github.com/SubtitleEdit/subt...leEditBeta.zip
Thx for the info about SSA/VirtualDub. I think I tried that... many years ago
Old 2nd February 2023, 11:06   #1654  |  Link
von Suppé
von Suppé's Avatar
Version 3.6.11 shows erratic behaviour when editing text in the text-box. Not always, but often the keyboard's "Delete" key acts as "Backspace" when the cursor is placed at the end of a line. Also, starting to "select" in the middle of a word and then dragging it to left, the whole word gets selected.
Anyone else experiencing this? I checked version 3.6.10, which doesn't have the issues. I'm on Windows 7.
Old 2nd February 2023, 18:16   #1655  |  Link
Amstramgram
All is perfect !!!
Thank you very much for giving me your time.
Old 2nd February 2023, 21:06   #1656  |  Link
Nikse555
@von Suppé: Sorry, I cannot re-create this.
(You can switch text box control, by going to Options - Settings - Appearance - and toggle "Use syntax coloring")
@Amstramgram: Cool, and thx to you for testing/verifying
Old 3rd February 2023, 13:15   #1657  |  Link
von Suppé
von Suppé's Avatar
Use syntax coloring doesn't change anything.
Weird. Reinstalled 3.6.11 and the issue still pops up every now and then. Not always though. Where there's a difference with the portable 3.6.11, where I haven't encountered it.
To try and recreate the issue, please (anybody) confirm:
Open SE, start new file. Format is set on "SubRip (.srt)" and Encoding on "UTF-8 with BOM". Right-click in field and "Insert line". In the textbox, type "Line one" <Enter>. Second line type "Line two" <Enter>. Third line type "Line three". Do not <Enter>.
With mouse, place cursor at the end of line 2 (so directly after the word "two". First hit on the spacebar does not produce a space. Second time it does.
Then hitting the <Delete> key for the first time, cursor jumps back. Second time also, ending between the "w" and "o" of the word two. Next <Delete>, the "o" will be erased and cursor jumps back between "t" and "w".
Thanks in advance to anyone for trying.
Old 3rd February 2023, 17:20   #1658  |  Link
Amstramgram
Well... I've tried. I followed your instructions to the letter. Several times.
But i can't reproduce the weird bug you describe.
Same thing when selecting a part of a word and dragging it : it works as expect without selecting the whole word...
Old 4th February 2023, 22:36   #1659  |  Link
Janusz
@von Suppé:
I can reproduce the error described in your example only if the [Settings/Appearance/Use syntax coloring] box is checked. Otherwise, the Backspace and Delete keys work as expected.
Sorry for my mistakes - I'm using a translator.
Janusz is offline   Reply With Quote
Old 5th February 2023, 15:25   #1660  |  Link
Nikse555
@von Suppé/Janusz: Strange... is this better: https://github.com/SubtitleEdit/subt...leEditBeta.zip ?
