19th March 2020, 22:34 | #841 | Link |
@GCRaistlin: Editing the text in "Remove text for HI could be possible - how does this work: https://github.com/SubtitleEdit/subt...leEditBeta.zip
19th March 2020, 22:52 | #842 | Link | |
My problem is just when I open an existing SRT from File / Reopen menu. Before the update, it opened both the SRT and the associated video file. Now, it doesn't open the video. I have to do it again each time I open the SRT. It concerns any codec / container. |
20th March 2020, 07:08 | #843 | Link |
@Lucius Snow: Do you still have problems in latest beta: https://github.com/SubtitleEdit/subt...leEditBeta.zip ?
If yes, what are the steps for re-creating this in detail (drag-n-drop or file open or shortcuts)? |
20th March 2020, 11:54 | #844 | Link | |||
92 00:07:54,641 --> 00:07:56,559 - l would take the idea to its extreme - - [ Whispering, lndistinct ] 93 00:07:56,643 --> 00:08:00,188 and draw parallels between reproduction in art. . . 577 00:38:09,245 --> 00:38:13,875 - Well, he said that, uh - - lt is actually as beautiful as the original. 578 00:38:14,000 --> 00:38:17,295 - that they thought it was an original for many, many centuries - - [ Man, ln ltalian ] When was it made? 1091 01:12:28,344 --> 01:12:32,014 - That impression is quite right, but. . . - [ Crowd Cheering ] 1092 01:12:32,181 --> 01:12:33,808 how can l say. . . Quote:
It does, thanks again.
Windows 8.1 x64 Magically yours Raistlin |
20th March 2020, 13:08 | #845 | Link | |
20th March 2020, 14:29 | #847 | Link |
That's what I described earlier:
My problem is just when I open an existing SRT from File / Reopen menu. Before the update, it opened both the SRT and the associated video file. Now, it doesn't open the video. I have to do it again each time I open the SRT. Difficult to explain more |
20th March 2020, 22:28 | #848 | Link | |
Nikse555
My current Latin.db - maybe you'll find my additions useful for all.
29th March 2020, 11:31 | #850 | Link |
Acid fr0g
@Nikse555
I am finding some encoding giving problems to your editor. Here you can find some. I hope the names are self explanatory enough. The only ones I can open with no problems on accented vowels and symbols are UTF16-LE ones. With UTF8 it is a mess
@turment on Telegram |
29th March 2020, 12:08 | #851 | Link |
@tormento: I don't think those files are correctly encoded, sorry.
EDIT: The UTF-8 files have UTF-8 BOM (EF BB BF) but they are not using UTF-8 encoding, they are ANSI encoded! Yes, really a mess Last edited by Nikse555; 29th March 2020 at 13:34. |
30th March 2020, 12:28 | #852 | Link | |
Acid fr0g
What about the other message about "L" OCR?
30th March 2020, 14:41 | #853 | Link |
I've updated latest beta somewhat: https://github.com/SubtitleEdit/subt...leEditBeta.zip
Your subtitle runs very well through the OCR using "Binary image compare" with number-of-pixels-is-space=7 and max-error-pct=1. I did not have any problems with "L". What OCR method are you using and what lines are problematic? Last edited by Nikse555; 31st March 2020 at 05:50. |
31st March 2020, 12:57 | #854 | Link | |
Acid fr0g
Many many "L": 570 00:51:39,520 --> 00:51:42,478 L know the book is tough, but l liked it. 571 00:51:42,600 --> 00:51:43,476 L know. Tried with a fresh installation and "untrained" OCR database?
31st March 2020, 14:32 | #855 | Link | |
Result here, starting with lowercase "L": Code:
l know the book is tough, but l liked it. |
31st March 2020, 15:20 | #856 | Link | |
Acid fr0g
I get capital L!
2nd April 2020, 18:15 | #857 | Link |
Pig on the wing
I've added the OCR fix list pair (Options -> Settings -> Word lists) l --> I to fix this, if I remember correctly. You can also do that after the OCR run.
That subtitle example was very straightforward to OCR and the characters look like most DVDs, so you get a lot of good matches for future subs. I uploaded my dictionary files and latin.db in case someone finds them useful (Nikse555 can freely use the content with SE if he wants to): https://drive.google.com/open?id=1Bo...8tAwXRn-IWRgnz https://drive.google.com/open?id=1Nz...CBOW9K93DZVxHb
3rd April 2020, 11:07 | #858 | Link |
Acid fr0g
One of the best things of SubRip was the possibility to save different matrixes and automatically scan for the most effective one on OCR when loading the sub bitmap file.
That gives the possibility not to pollute the good trained ones with some unusual subtitle, plus the possibility to organize them effectively. Moreover, Subtitle Edit could come with pretrained ones like SupRip did for the most commonly used fonts. @nikse would you, please?
3rd April 2020, 11:14 | #859 | Link |
Pig on the wing
SE does have the ability to use different databases for OCR and the scanning could be useful, I agree.
3rd April 2020, 11:21 | #860 | Link | |
Acid fr0g
Another missing thing is the possibility to expand selection, such as for % that sometimes goes wrong on OCR. A point and click expansion thing would be even better.
