10th June 2014, 00:06 | #22 | Link |
I have an issue with Gamma calibration test. I have adjusted my monitor for daylight environment - bars blend at the right values, sharpness test gives the completely blended rectangle, all is fine. Then I tried to adjust my monitor for lamplight environment - I have changed R, G, B monitor settings, then adjusted gamma curves. Bars blend at the right values again - but sharpness test gives the rectangle with visible circle inside. That's not good. By adjusting gamma curves I have achieved the completely blended rectangle but now 10% green bar blend at 1.8 instead of 2.17 and 10% gray bar blend at 2.1 instead of 2.17.
So now I should choose between good look of sharpness test and good look of gamma calibration test. The gamma calibration test description says that 10% isn't very important but we always want best, not just good. What could be the reason of the issue? Wrong R, G, B values I believe 'cause I haven't changed anything else. So actually I have 3 choices: two ones I wrote above and non-ideally RGB for lamplight. So what to choose? Or maybe is there a soft test that will help me to change R, G, B correctly?
Windows 8.1 x64 Magically yours Raistlin |
10th June 2014, 09:03 | #24 | Link |
huhn, that's understood, but I'm talking about "best with what we have for now". So my question is simple - what is more important in my case: good-looking Gamma calibration test (bar blend at the right values), good-looking Sharpness test (the circle blends with the rectangle), or correct RGB monitor values? 'Cause I'm able to get only any 2 of 3 at the same time.
10th June 2014, 11:07 | #25 | Link |
Angel of Night
Most monitors just can't be calibrated completely, even to sRGB, let alone to multiple targets or wider gamut. You're lucky you can get close enough to eyeball it as good in one viewing condition, so you might have to stick with that or something close. If your monitor doesn't have multiple user presets for multiple viewing conditions, it's way more trouble than it's worth to constantly change them back and forth; I just picked my usual (evening time) and stuck with it.
Ultimately, only you can say what's actually most important, but you're already 90% there or more, and the more tuning you do the less payoff is left. Getting 2 of 3 right and the third close is fantastic, given the dismal state of color on most monitors. |
10th June 2014, 12:27 | #26 | Link | |
So am I right that the reason of my non-ideal adjusting for lamplight is non-ideal RGB monitor settings, not the fundamental impossibility of the ideal adjusting - 'cause for daylight I've found settings that are closer to the ideal?
