8th December 2009, 22:08 | #81 | Link | ||
3 + 4) because of 1+2 the file handle could not be closed and therefore it can not be deleted/written during MeGUI closing ==> fixed I will upload the new build soon. |
8th December 2009, 22:27 | #82 | Link | |
Kurtnoise stopped after the last release which caused a lot problems for many users. I don't know exactly of what nature these problems were but it seemed the way some users reacted might have played a role, users with little support and understanding. If that's true it would be sad for supportive users like Inspector.Gadget. A way to deal with it could be to ignore unhelpful feedback and only support helpful feedback instead.
8th December 2009, 23:21 | #83 | Link | ||
New build has been uploaded: Code:
- [MeGUISettings] removed the http://megui.org/auto/ update server - [VideoEncodingComponent] + [MeGUISettings] added file format saving - [x264ConfigurationPanel] Turbo mode can be changed in automated 2 or 3 pass |
9th December 2009, 00:11 | #85 | Link |
- [VideoEncodingComponent] + [MeGUISettings] added file format saving Every setting I tried works from the main x264 configuration GUI except I'm still having a problem setting a value for rc-lookahead (doesn't show up in command line at all) |
9th December 2009, 06:04 | #87 | Link | |
9th December 2009, 06:18 | #88 | Link | |
9th December 2009, 06:29 | #89 | Link | ||
Create a backup of your MeGUI folder (in case something goes wrong) and copy the new files into the original directory. Last edited by Zathor; 9th December 2009 at 06:32. |
9th December 2009, 06:36 | #90 | Link | |
Thankyou guys for all! |
9th December 2009, 11:14 | #92 | Link |
Which value do you would like to set and so on. At the moment I can confirm that a value of 40 will never be displayed regardless of the preset level. This is wrong and will be fixed. All other values should be shown in the command line (if it is not the default value of the preset). Please enter for example 41 and it should be visible.
9th December 2009, 15:05 | #95 | Link | |
9th December 2009, 16:15 | #98 | Link | |
When I installed it, the tools "oggenc2", "STX264", and "TXviD" all still asked to update. I updated oggenc2, but as I imagine the profiles you included are probably more updated than the ones included in STX264 and TXvid I downloaded them (to get rid of the "update" question) but did not install any of the profiles. I don't know if it is possible to avoid those tools not appeariing as updated, but I thought I'd mention it in case. |
