#2141 | Link | |
OK, done more testing, now it's over to you to see if anything else can be done. I have added the audio, a couple of .srt's (they're small for comparison), and the error msg that Waveform pops up... And a read me.txt, so please read thru that, saves me adding it here. https://www.mediafire.com/file/yahfa...folder.7z/file
Main Systems:- 9970X on Gigabyte TRX50 AERO D 7970X on Asus Pro WS TRX50-Sage WiFi 9950X3D on MSI Carbon X670E 7950X on Gigabyte Aorus Elite B650 i9-13900KF on MSI Tomahawk B660 |
#2142 | Link | |
Video damager
Here is srt produced with Pro version: https://pastecode.io/s/nds33xaw Code:
faster-whisper-xxl.exe boot.flac -l en -m large-v2 --vad_method pyannote_v3 -o source --standard --max_gap 1 -hst 2 -ct float16 --ff_vocal_extract mb-roformer --realign BTW, that CPP srt is weird, 00:00:00-00:00:30 is not in audio, timestamps are off by up to dozens seconds.
InpaintDelogo, DoomDelogo, JerkyWEB Fixer, Standalone Faster-Whisper - AI subtitling Last edited by VoodooFX; 10th January 2026 at 12:47. |
#2143 | Link | |
![]() BTW, did you bother to check if my files opened Waveform ??
#2144 | Link | ||
Video damager
You wont be able to use that as those are only Pro features. Quote:
Yes, opened after I named your files properly.
InpaintDelogo, DoomDelogo, JerkyWEB Fixer, Standalone Faster-Whisper - AI subtitling |
#2145 | Link | |
Thanks
#2146 | Link | |
Video damager
Yes to both.
#2147 | Link |
Audio Sync
Above this message there are a lot of pleas for help regarding audio sync and loss of sync and clipped audio. I'm sorry that I don't have time to respond but I hope what I write here will help.
ISOM containers like MP4 and MOV can contain edit lists. I believe that's also true of MKV but I don't use MKV. If you edit audio without recoding it, that will likely result in an edit list being generated and attached to the AV. If you then audition the AV without recoding the audio, and if there is an edit list, then the player/utility may or may not appear to have synchronized audio depending upon whether it honors edit lists and how well it honors edit lists. You can detect and view edit lists via FFprobe, but it's complicated. SE's waveform rendering -- specifically, the rendered pictures of the timing -- seems to have some issues with edit lists. What I do is recode the audio in an MP4 so that there's no edit lists. The audio must be cleaned of edit lists. For example, don't just 'FFmpeg -ss...' or 'FFmpeg -to...' or 'FFmpeg --itsoffset...' or 'FFmpeg -itsscale:a...' without recoding the audio -- for the final AV and any temporary AV that you're going to use in SE. If I'm going to be working on the audio extensively, I recode it to frac so that it's a separate .FRAC stream and then edit to my heart's content. If I need to see it in an AV, I make a temporary AV just to do the viewing. Then, in the final MP4, I recode the frac to whatever audio I want. By keeping the frac audio separate, it stays pristine and the final MP4 has no edit lists. All that takes planning and it is tedious to make temporary AVs just to see some result I need to see, but it's worth it in the end. All that I've written above is in addition to some SE waveform rendering issues that appear to be unrelated to edit lists. I'm still trying to figure it out. I've written extensively about edit lists during the past month and my explorations are here in the SE forum. I promised to clean up my documentation and I reiterate that promise. But that has to wait until the time when I've figured it all out. I hope my experiences help you. In the mean time I'm positioning subtitles based on the audio that MPV plays, not on the positions of the waveforms that SE renders. Last edited by markfilipak; 15th January 2026 at 00:30. |
#2148 | Link | ||
#2149 | Link |
@ VoodooFX,
Me again, I have a very short clip (35 seconds) that is in German or French, and it's singing (sort of), and I just can't get all the words. Any suggestions ??, could I maybe send it to you, to have a play ?? Regards
#2150 | Link |
Video damager
Sure.
To stop offtopic, continue in the right thread: https://forum.doom9.org/showthread.php?t=184859
#2151 | Link | |
Thanks, will send it off shortly.
#2152 | Link |
Audio Sync
I have some solid information.
I found a situation that 'shows' speech (waveform) on one side of a scene change but 'says' speech (MPV) on the other side of the scene change. The hh:mm:ss.mmm of the scene change is 100% correct. If I put the subtitle where the speech is shown (waveform), it's wrong (external MPV). If I put the subtitle where the speech is said (internal MPV), it's right (external MPV). Background: - Waveform was extracted and drawn by internal FFmpeg. - What waveform shows gets earlier and earlier. - I had captured the audio via MKVToolNix. - I had to use -itsscale:a in (external) FFmpeg to sync the audio. - There is no edit list in the resulting audio stream. _No_ edit list, yet waveform is being drawn by internal FFmpeg as though there _is_ an edit list that internal FFmpeg is _ignoring_. That would mean that there actually is an edit list which internal MPV, external MPV, and external FFmpeg are all honoring but internal FFmpeg (waveform) is not. But FFreport shows no edit list. I am totally baffled. The 'error' in waveform is too specific and too accurate and too persistent (video-to-video-to-video) to be accidental. Yet FFreport shows _no_ edit list. ...Is there an edit list or isn't there an edit list? Hell, I don't know anymore. I need someone to help, to work with me. Nik is busy re-inventing the wheel. Last edited by markfilipak; 20th February 2026 at 21:12. |
#2153 | Link |
Subtitle Edit 5 beta-1 is now out
![]() https://github.com/SubtitleEdit/subtitleedit/releases If you're on mac, be sure to follow the installation instructions: https://github.com/SubtitleEdit/subt...-ov-file#macos SE 4 was getting increasingly hard to maintain — especially on Linux. SE 5 has rewritten UI in Avalonia UI and works much better on Linux now. Works on mac as well (cross platform with single codebase). Note that SE 4 will still be maintained for a while, and you can have both SE 4 and 5 installed (use portable versions). Please give the beta a spin and let me know if you run into trouble. Note: SE 5 requires Win10 or newer. Yeah, re-inventing the wheel surely takes a lot of time
#2154 | Link | |||
#2156 | Link |
The beta does move the video and time when doing frame-by-frame when editing PGS subtitles, but it doesn't move the subtitles alongside them when I selected an image. It also doesn't show the end times for the subtitles and the PGS subtitle edit menu doesn't show the video in this format: 00:00:00:00
| Thread Tools | |
| Display Modes | |
