Old 14th June 2022, 14:32   #201  |  Link
fkid
Originally Posted by -QfG- View Post
-v0.46
*Shows RPU/EL Layer Information in Injector (Profile, CM Version, Frames)
*Updated dovi_tool to v1.5.4.
Thank you for continued development. Still see the minor typo on line 371 of INJECTOR.cmd
if "%P4Extract%%MUXINMP4%%HDR10P_exist%"=="TRUEYESYES" set "HEADER_FILENAME=%~n1_[HDR10+ INJECTED].mp4"
should be this I think?
if "%MP4Extract%%MUXINMP4%%HDR10P_exist%"=="TRUEYESYES" set "HEADER_FILENAME=%~n1_[HDR10+ INJECTED].mp4"
fkid is offline   Reply With Quote
Old 14th June 2022, 20:21   #202  |  Link
SlimSwan
problem
Delete this post, my mistake.
SlimSwan is offline   Reply With Quote
Old 15th June 2022, 19:16   #203  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Thank you, i will fix it in the next update.
Original time is 1 h 5 min.
I use latest script.
FPS of video go to 25 I"dont know why?
Have you set "Mux in mkv" to "yes", or have you muxed the file by yourself?
In the last case, in mkvtoolnix by Video in the middle right box set the framerate manually to 24000/1001 and check the "Also Fix Bitstream" Button.
Or simply use the "Mux in MKV" Function from the tool.
EDIT:
-v0.46 Fixed
*Bugfixes
-QfG- is offline   Reply With Quote
Old 15th June 2022, 21:44   #204  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
The above is clearly pirated content, and the post has been removed. You must not discuss pirated content on doom9.
Old 21st June 2022, 12:50   #205  |  Link
Bioba
Hello,
I am writing to better understand what this tool does.
I read that it extracts and injects metadata for Dolby Vision, so I could extract the metadata from an untouched video file and then inject it into the same compressed video file?
Thanks to everyone who will explain me better :-)
Bioba is offline   Reply With Quote
Old 21st June 2022, 18:31   #206  |  Link
Rozin
How can i replace a profile 5 dolby with its profile 8.1 version. Profile 5 video plays with pink green tint. That's why I'm trying to convert the profile version. Or someone could help me to play profile 5 files without any tints on a dolby profile 5 support less device
Rozin is offline   Reply With Quote
Old 21st June 2022, 19:07   #207  |  Link
nevcairiel
You can't really convert profile 5 to profile 8.1, since it has no compatible base layer.
Old 21st June 2022, 19:58   #208  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
DV Profile 5 files uses the ITP Colorange instead of BT.2020. You can't edit this.
Old 21st June 2022, 21:44   #209  |  Link
Rozin
Ok got it.But Is there any way to play profile 5 files on pc. Like tweaking potplayer settings or using madvr. They show pink, green shaded all over. Or do i have to buy $1000 oled tv to play a profile 5?
Old 21st June 2022, 22:06   #210  |  Link
quietvoid
Use mpv with --vo=gpu-next.
LG C2 OLED | GitHub Projects
quietvoid is offline   Reply With Quote
Old 21st June 2022, 22:17   #211  |  Link
Rozin
What does this do? Passthrough profile 5 data or dropping it ? Please explain kind sir for I'm noob
Old 22nd June 2022, 10:13   #212  |  Link
Rozin
Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU. This is the dolby encoded into the file . I can't do anything to convert to 8.1? BL means base layer ryt?
Old 23rd June 2022, 07:31   #213  |  Link
rwill
I you manage to decode the Profile 5 to HDR10 and then convert the RPU to match that you could create a Profile 8.1 stream in theory. But chances are high that if your device does not support Profile 5 it also does not support Profile 8.1.
Old 23rd June 2022, 08:29   #214  |  Link
Bioba
I did a test with a film, I extracted the RPU.bin file with the demuxer, compressed the film, I put the RPU file in the correct folder.
I tried to inject the DV but I get an error and the script closes immediately.
I took a screenshot.
Old 23rd June 2022, 12:48   #215  |  Link
Rozin
Actually my laptop is Legion 5 pro which has dolby vision specified in the lenovo website and the lap came with dolby app preinstalled with dolby video extensions. I know the display is lcd (But 10bit) and its not the right hardware for dovi, but a license is a license. i dont understand why profile5 is not being decoded. is lenovo selling a 'pseudo' dolby vision license. ?
Old 23rd June 2022, 18:58   #216  |  Link
fkid
Originally Posted by Bioba View Post
This happens to me from time to time when file or folder has [] or () or some other characters in the path. It may be a limitation of running using explorer context menu? Any idea @-QfG-? I just temporarily rename the video file and/or folder to something short and simple, do the DEMUX/INJECT, then rename file/folder back.
Old 24th June 2022, 20:38   #217  |  Link
Bioba
Thanks!
Old 25th June 2022, 05:45   #218  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
The problem by this solution is, if the tool renames anything and you close the tool during process, or there is any error during process, the tool don't renamed the folder / Files back.
EDIT:
-v0.47
*INJECTOR supports custom.json files (copy edited custom.json to video source dir).
custom json scripts processed first!
*INJECTOR New function "Match L6 Metadata".
L6 Metadata will be edited for matching HDR stream Metadata.
*INJECTOR creates now a small Logfile by muxing.
*FRAMEINFO shows more informations about the RPU.
*Updated dovi_tool to v1.5.5.
Old 26th June 2022, 03:36   #219  |  Link
fkid
EDIT:
-v0.47
Thank you for the update! Just curious, under what scenario is the new feature used? *INJECTOR New function "Match L6 Metadata".
Old 26th June 2022, 17:58   #220  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Some releases have a RPU with l6 metadata over 10.000. The tool will not mux them, because 10.000 is the max value there. If you have this problem simply set L6 Metadata to the same values how the HDR stream have.
