Old 23rd April 2022, 14:09   #1101  |  Link
Dogway
I updated a few scripts today. Wanted to call out Boulder as I updated TransformsPack so now 'SSIM2' works over there or deep_resize().
deep_resize() also supports now ratio resize, so deep_resize(2) will mean to double the size, likewise deep_resize(0.5) is halving the size.
As I said I finally added accumulated scene stats to SoftLimiter, making the limiting work on a per-scene basis.
My plan is to include per-scene filtering in more functions so if you have a request for one of my filters let me know.
Now all the scripts are up-to-date with internal (oops, nope, ExTools needs a minor update). From now on I will add global stats parser to SceneStats, work on Zopti optimizations and finally finish TransformsPack final.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 23rd April 2022, 14:17   #1102  |  Link
Shinkiro
Originally Posted by kedautinh12 View Post
Can you share script you were change to expr??
setmemorymax(6000)
ffms2("video.mkv",cache=true)
ContinuityFixer(left=4, top=0, right=5, bottom=0, radius=0)
FillBorders(left=3,top=0, right=4, bottom=0, mode=0, y=2, u=3, v=3)
EdgeCleaner(strength=10, rep=false, rmode=17, smode=0, hot=false)
W=1920
H=1080
nnedi3_rpow2(rfactor=2, nsize=0, nns=4, qual=2, etype=0, pscrn=4, cshift="spline36resize", threads=8)
Blackmanresize(W, H, taps=4,0,0,-0,0)
ConvertTo16bit()
mthr = 16
bi = BitsPerComponent(last)
mthrHBD = ex_bs(mthr, 8, bi, true)
mlight1=last.flatmask(2, scale=5.0, lo=4, MSR=70, invert=false)
mdark1=last.flatmask(3, scale=7.0, lo=4, MSR=50, invert=false)
mask=last.ConditionalFilter(mlight1, mdark1, "AverageLuma()",">","60").ex_lut(Format("x {mthrHBD} <= x 0.5 * x 2 * ?"), UV=1).RemoveGrain((W>960) ? 20 : 11, -1)
deg1 = last.SMDegrain(tr=3,thSAD=340, thSADC=150, thSCD1=250,thSCD2=96, contrasharp=false, refinemotion=true, chroma=true, plane=4)
deg2 = last.SMDegrain(tr=2,thSAD=121, thSADC=50, thSCD1=156,thSCD2=96, contrasharp=false, refinemotion=true, chroma=true, plane=4)
deg=ConditionalFilter(deg1, deg2, "AverageLuma()",">","60")
ex_merge(deg ,last ,mask, luma=true, Y=3, UV=3)
LSFmod(ss_x=1.0,ss_y=1.0,strength=4,Smode=5)
FineDehalo(rx=2.8, ry=2.8, thmi=80, thma=128, thlimi=50, thlima=100, darkstr=0.0, brightstr=1.0, showmask=0, contra=0.0, excl=true)#.aWarpSharp2(depth=2)
db=last.neo_f3kdb(sample_mode=2, Y=64, Cb=64, Cr=64, grainy=44, grainC=0, range=15, dynamic_grain=false)
ex_merge(db, last, mask, luma=true, Y=3, UV=3) # пкрвый клип  (дебандинг) второй клип(чистые линии)
z_ConvertFormat(colorspace_op="470bg:601:470bg:f=>709:709:709:f",dither_type="none")
ConvertBits(bits=10)
Prefetch(8)
Ryzen 2700x | ASUS ROG Strix GTX 1080 Ti | 16 Gb DDR4
Windows 10 x64 20H2
KD-55XE9005 | Edifier R2800
Shinkiro is offline   Reply With Quote
Old 23rd April 2022, 17:55   #1103  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Thanks, did some eyeballing tests. It's definitely much sharper than a simple Spline36. 'SSIM' looks like it could be a good replacement for that instead. Are there any caveats I should be aware of?
Old 23rd April 2022, 18:07   #1104  |  Link
Dogway
Prerequisites only as it needs SimilarityMetrics, fmtconv, vsTCanny... Speed wise I guess slower but haven't benchmarked. Hopefully I didn't break something/logic.
Old 23rd April 2022, 19:04   #1105  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Something I noticed - 'Didée' as a string doesn't work correctly as it requires UTF8 support. VDub2 won't put the 'é' there in the script editor.
EDIT: and show=true won't help to see what is really being used since it shows whatever string is given in the function call.
Old 24th April 2022, 11:55   #1106  |  Link
Dogway
Thanks, "Didee" is also supported as alias so I changed default for that.
Do you mean to show also 'b' and 'c' coefficients? I know them by memory mostly, expected people to also familiarize but I can add them no problem.
Old 24th April 2022, 18:16   #1107  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Yes, I think it would be good to see what the actual resizer parameters are for each case. There's quite a few of them there
Old 29th April 2022, 14:42   #1108  |  Link
tormento
Acid fr0g
tormento's Avatar
@DogWay
I recently bought the Aniplex version of Full Metal Alchemist Brotherhood (an anime) and (I could easily guess) it's an upsampled version of the broadcast show.
There are many aliased black line arts (with some halo too) and what was some grain (not excessive though) now became pixel blocks, mostly in dark areas.
Is there anything I could do with your tools?
Some examples:
@turment on Telegram
Old 29th April 2022, 16:33   #1109  |  Link
Julek
Julek's Avatar
Originally Posted by tormento View Post
@DogWay
FMAB is a 960x540 animation upscaled to 1920x1080 with bicubic 0/1, the correction process (using VS) looks like this:
from vsutil import depth, split, join
import vapoursynth as vs
core = vs.core
src = core.dgdecodenv.DGSource(r"D:\Encodes\FMAB\00000.dgi")
src32 = depth(src, 32)
y, u, v = split(src32)
dsc = core.descale.Debicubic(y, width=960, height=540, b=0, c=1)
w2x = core.caffe.Waifu2x(dsc, noise=-1, scale=2, model=6, cudnn=True, tta=False)
w2x = join([w2x, u, v])
depth(w2x, 10).set_output()
Result: https://slow.pics/c/zSsrC5HW
CPU: AMD 3700X | GPU: RTX 3070Ti | RAM: 32GB 3200MHz
GitHub
Julek is offline   Reply With Quote
Old 29th April 2022, 16:40   #1110  |  Link
ChaosKing
Lineart looks great now!
Old 29th April 2022, 17:51   #1111  |  Link
tormento
Acid fr0g
tormento's Avatar
Is possible to have a AVS+ script?
I am really a noob with VS. Anyway, is it the CUDA filter version?
P.S: Results are awesome.
Old 29th April 2022, 18:05   #1112  |  Link
Dogway
Yes, I was going to recommend de-scalers, probably the aliasing is due to a bad upscaling, so it should be fixed by returning it to the original size and optionally upscaling with a better (AI) upscaler.
Julek example is wonders, not even it cleaned the aliasing but also the ringing.
A port attempt:
src   = DGSource("D:\Encodes\FMAB\00000.dgi")
src32 = ConvertBits(src, 32)
dsc   = DeBicubicResizeMT(ExtractY(src32), 960, 540, b=0, c=1)
# w2x   = Waifu2x(dsc, nr=0, scale=2, models="C:\opt\waifu2xAvisynth-models\models", jobs=4)
w2x   = nnedi3resize(dsc, 1920,1080)
w2x   = CombinePlanes(w2x, src32, planes="YUV",Pixel_Type="YUV420PS")
Adaptive_sharpen(w2x,0.5)
ConvertBits(10, dither=1)
Old 29th April 2022, 18:15   #1113  |  Link
Julek
Julek's Avatar
Waifu2x for AVS has the cunet model? It is the only model with good results, the other models damage the image a bit.
The second option is to use just nnedi3_rpow2.
GitHub
Old 29th April 2022, 18:49   #1114  |  Link
Dogway
I don't know, it's this build but only for AVS 2.6 x86.
There are other AI upscalers in AVS+ like FCBI, SuperResXBR or FSRCC. But I don't think any is modeled for anime.
EDIT (alternative with less ringing):
src32 = ConvertBits(last, 32)
dsc   = deep_resize(ExtractY(src32), 960, 540)
w2x   = deep_resize(dsc, 1920,1080,grain=0,deconv=0)
w2x
aWarpSharp2(depth=4,type=1,blur=3,thresh=128,chroma=2)
FastLineDarkenMOD(prot=0, thinning=10, strength=30)
# some denoise
sec  = ex_bs(0.51, 8, 10, fulls=true, flt=true)
ex_lutxy(ex_median("median5"), Format("x y == x dup y x - sgn {sec} * + ?"), UV=3)
Old 29th April 2022, 19:01   #1115  |  Link
tormento
Acid fr0g
tormento's Avatar
We need something that works with GPU of we can get old waiting
Old 29th April 2022, 19:22   #1116  |  Link
tormento
Acid fr0g
tormento's Avatar
Can you "take my hand" and lead me to files needed, i.e. urls etc?
I can "stupidly" apply your script if you give me some coordinates.
Old 29th April 2022, 19:56   #1117  |  Link
Julek
Julek's Avatar
Talk about a VS installation? I am a little busy today, but I can give a very detailed explanation tomorrow.
In advance I can tell you that we have 3 cunet options:
caffe (CUDA ver) which has a brightness bug
w2xnvk (Vulkan ver), which is slower than caffe, but has a bug-free release.
mlrt (CUDA ver) which is the fastest of them, but has the same bug as caffe
It's possible to mitigate the effects of the bug with Expr, or just use w2xnvk R3.2
GitHub
Old 29th April 2022, 19:59   #1118  |  Link
tormento
Acid fr0g
tormento's Avatar
Thank you in advance. Please cover every aspect so that other users can have benefits too.
Old 30th April 2022, 10:53   #1119  |  Link
Dogway
You might be interested in this:
https://github.com/dnjulek/jvsfunc/b...xpr.py#L10-L55
I did ccd using only Expr, I saw that AVS does not yet have a native plugin and I think this might help.
To help with vs-expr: https://github.com/AkarinVS/vapoursy...pr-expressions
Finally ported. It acts more like a chroma deblocker so added into DeblockPack. I added a few optimizations and features so you might want to give it a look.
Old 30th April 2022, 10:57   #1120  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Is there a clear method for defining the upscale method? I have some film sources which are clearly rather poor upscales and would like to downscale back to the original resolution for the encode.
avisynth, dogway, filters, hbd, packs
