Old 16th April 2020, 03:51   #21  |  Link
MeteorRain
結城有紀
I believe the change of bit depth should not change a parameter, at least in most cases.
Both vapoursynth-dfttest and dfttest scale parameters to the bit depth so it wasn't a problem.
I haven't decided what to do next, but I may start with a few. mvtools-sf is also a good candidate. Depending on my time availability.
My Projects
x265 - Yuuki-Asuna-mod
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 16th April 2020, 04:16   #22  |  Link
real.finder
so, parameter for those now float right? (if they not already), since float more flexible, For example if the parameter 0-255 with float we can set it like 112.5 and so, but with int we have only 256 options and that not suitable for more than 8bit
since mvtools already has HBD (still there are no float motion analyzing) and it's complex maybe it's good to start with basic things that has no HBD yet in avs+ like VagueDenoiser, EEDI3 and Dither_resize16/fmtconv and then back to mvtools in the end
See My Avisynth Stuff
Old 16th April 2020, 05:36   #23  |  Link
MeteorRain
結城有紀
Which parameters are you talking about? DFTTest has all parameters in float I believe (except for those modes, sizes and frame numbers).
And I've uploaded the release (r7).
My Projects
Old 16th April 2020, 05:41   #24  |  Link
real.finder
if they are, then no need to do anything I am just saying if any (Whether here or not)
Old 16th April 2020, 10:42   #25  |  Link
tormento
Acid fr0g
tormento's Avatar
I saw your readme.md is pointing to official FFTW download page.
Unfortunately they built only 3.3.5 version of dll, while there are many updated ones such as 3.3.7 or 3.3.8. The latest I can find is here and a fresh compile from you or pinterf with VS and clang (and perhaps Intel) to test would be nice.
@turment on Telegram
Old 16th April 2020, 16:38   #26  |  Link
real.finder
is [Neo] FFT3D / DFTTest stable yet? cuz I want to make scripts use them instead of non-neo one
also as I said in #22 more ports from VS will be nice since avs+ still need those updates for HBD, so I will make another wave of scripts updates
Old 16th April 2020, 19:58   #27  |  Link
MeteorRain
結城有紀
Whether it is stable depends on your bug report. If you're happy about it then I think it's stable enough.
What are the things that you are looking to replace in your script from VS counterparts? Those 3 you mentioned?
My Projects
Old 16th April 2020, 20:28   #28  |  Link
real.finder
yes and along with SangNomMod those the most important for now, but there are others with kinda less important like TTempSmooth, EEDI2, TCanny (there are TCannymod by chikuzen but I think with no HBD), Yadifmod (there are Yadifmod2 by chikuzen with not completed HBD), IT, DeblockPP7
and after that maybe these VS only like Bwdif, W3FDIF, VMAF, BM3D
Old 18th April 2020, 11:17   #29  |  Link
StvG
ffvideosource()
neo_ff3d() #r3 crash with no message, r1v4 is ok (x64)
StvG is offline   Reply With Quote
Old 18th April 2020, 11:40   #30  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
This is one of the cases where you can argue that it should change. We're dealing with transforms so there's a direct connection between input range and transformed range. Just my thoughts. I suppose scaling is easier but then a 0-255 range makes no sense. Either have a proper 0-1 float or make the int range a percentage or whatever.
Don't propagate 0-255 scaled ranges, they make me very unhappy since they make no sense AND lack fine enough steps to for higher bitdepths.
Myrsloik is offline   Reply With Quote
Old 19th April 2020, 10:05   #31  |  Link
MeteorRain
結城有紀
Originally Posted by StvG View Post
ffvideosource()
Can't reproduce here.
Source file resolution? (Tested 1280x720)
Source bit depth? (Tested 8-bit)
FFMS version? (Mine stamped at 2019-8-11)
Anything that I might have missed?
My Projects
Old 19th April 2020, 18:00   #32  |  Link
StvG
Tested with 1280x720 / 1920x1080 8-bit video, blankclip(pixel_type="yv12").
Added ConvertBits(16) before neo_fft3d() doesn't change the situation.
Tested with this FFMS2, latest LSMASH.
AVSMeter - https://images2.imgbox.com/e6/ba/oz2BaBV8_o.png
AVX-512 CPU.
Old 19th April 2020, 21:43   #33  |  Link
MeteorRain
結城有紀
Oh avx 512. Yea I don't have any testing environment. Can you try debugging it for me?
(Or I can try to use a CPU emulator or rent a server to debug it. Or I can simply remove it since it's not such a big deal to support it now.)
My Projects
Old 19th April 2020, 23:01   #34  |  Link
MeteorRain
結城有紀
Should have fixed it. The issue is more stupid than I thought.
Please try v4.
Also opt parameter is introduced so you can disable AVX512 manually.
My Projects
Old 20th April 2020, 11:14   #35  |  Link
StvG
Thanks. It works now.
The output of opt=1 and opt=2 is identical.
The output of opt=3 and opt=4 is identical.
The output of opt=1/2 is a bit different than opt=3/4.
Old 20th April 2020, 12:39   #36  |  Link
MeteorRain
結城有紀
Do you have a combination of resolution-depth-parameters that I can test?
By the way I did find some issues when running 2 instances together. I'll check that part later.
My Projects
Old 20th April 2020, 14:44   #37  |  Link
StvG
ColorBars(pixel_type="yv12") #whatever pixel_type
a=neo_fft3d(opt=3)
neo_fft3d(opt=2)
Compare(a,"yuv")
Live action video would have bigger difference.
Old 20th April 2020, 23:43   #38  |  Link
MeteorRain
結城有紀
Please try r5 as I fixed the race condition when multiple instances are running together.
My Projects
Old 21st April 2020, 12:51   #39  |  Link
StvG
The difference is still there.
Old 22nd April 2020, 06:35   #40  |  Link
kedautinh12
can you comment more detail?
