#181 | Link | ||
neo/vs -> original avs dfttest sigma/sigma2 8.0 -> 16.0 sbsize 16 -> 12 sosize 12 -> 9 tbsize 3 -> 5 so I think these need to be added in Quote:
See My Avisynth Stuff Last edited by real.finder; 24th March 2021 at 21:21. |
#182 | Link | |
24 years and counting...
I have a general question regarding dfttest. But the original thread I found is rather ancient so maybe this is a better place.
My question is regarding frequencies with the sstring-parameter. I would like to understand this better. ![]() From the Wiki: Quote:
Noise is usually somewhat fine detail, so higher frequencies should be filtered maybe more, than lower ones? I ran some tests on a sample with very fine/ high pitched noise and these sigma strings: 1) sstring="0.0:0 0.7:0 0.8:64 1.0:64" (strong filtering for hf and no filtering for lf) and vice versa 2) sstring="0.0:64 0.2:64 0.3:0 1.0" (no filtering for hf and strong filtering for lf) According to the Wiki, the first string should filter that very fine noise much better than the second. But the opposite seems to be the case. So I was wondering if that maybe a typo in the Wiki or I made a mistake. Can someone test and either confirm or disprove this?
#183 | Link |
seems both plugins here have same problem as https://github.com/HomeOfAviSynthPlu...f3kdb/issues/7 (at least in avs+)
See My Avisynth Stuff |
#184 | Link |
real.finder updated new commits to fix Update AVS headers and copy frame properties for AVS+ and VS. If anyone interested
https://github.com/HomeOfAviSynthPlu...commits/master https://github.com/HomeOfAviSynthPlu...pull/6/commits |
#187 | Link |
Here only x64 built by real.finder, need x86 build by someone, thanks
https://github.com/HomeOfAviSynthPlu...28/neo-x64.zip |
#188 | Link | |
#189 | Link |
https://github.com/HomeOfAviSynthPlu...FFT3D/releases |
#191 | Link |
I'm trying to load the plugin but failing. Here's what avsmeter reports:
Cannot load file 'C:/Program Files (x86)/AviSynth+/plugins64/neo-fft3d.dll'. Platform returned code 126: The specified module could not be found. Dependencies that could not be loaded: MSVCP140_ATOMIC_WAIT.dll Visual C++ Redistributable for Visual Studio 2015 is already installed, is there something else I should be installing? Thanks. |
#192 | Link |
You can download latest ver here:
https://github.com/abbodi1406/vcredist/releases |
#193 | Link |
Neo-DFTTest updated r8
https://github.com/HomeOfAviSynthPlu...TTest/releases Last edited by kedautinh12; 31st August 2022 at 09:54. |
#194 | Link |
Broadcast Encoder
Thanks for the heads up.
Github is on drugs this morning, though: Code:
<Code>ServerBusy</Code> <Message>Egress is over the account limit. RequestId:59449abb-501e-005b-2704-bd1b5e000000 Time:2022-08-31T06:40:34.5336533Z</Message> EDIT2: If you're using Windows XP please note that r8 x86 build will NOT work on Windows XP! Last edited by FranceBB; 31st August 2022 at 15:04. |
| Display Modes | |
