Old 1st February 2010, 18:12   #41  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Originally Posted by kieranrk View Post
Just out of interest does Blu-ray let you code 1080p25 without using interlacing? Can you use 1080p25 will pic_struct or something?
Also is there anything about NumClockTS?
Not without --interlaced switch (scenarist) and earler version of HRD patches. I will now test with or without pic_struct. Please give me few hours
shon3i is offline   Reply With Quote
Old 1st February 2010, 21:45   #42  |  Link
Trahald
Wewkiee
Trahald's Avatar
While in practice it may be different, 1080p25 is not allowed.
...yeah...but...why on earth would I compare apples with apples?
Trahald is offline   Reply With Quote
Old 1st February 2010, 22:17   #43  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Encocoding progressive material with interlaced switch you get interlaced video 1080i25 which is allowed, and scenarist detect it as 1080i25.
Old 1st February 2010, 22:25   #44  |  Link
kolak
You ave to encode it as it would be 50i and it does work.
If you have a good player you may get original 25p on your TV.
Andrew
Old 2nd February 2010, 00:23   #45  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
PS3 plays 1080p 25fps without problems. I wouldn't be surprised if this also applies to other good brands.
Old 2nd February 2010, 16:43   #46  |  Link
kolak
It's not about what PS3 or even any other player can play- BD doesn't support pure 25p/30p modes.
PS3 can play much more than BD spec allows- it did play 100Mbit AVC, but at maybe 5fps
Andrew
Old 2nd February 2010, 16:49   #47  |  Link
mp3dom
Back to the NAL patch: At the end I'm not understanding if the current patch version (1.22) match the specs posted by Emulgator.
Old 2nd February 2010, 18:39   #48  |  Link
kieranrk
It does.
kieranrk is offline   Reply With Quote
Old 2nd February 2010, 20:18   #49  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Well support it as Secondary video, so is generaly supported. That's why i liked HDDVD, maybe is less overall bitrate and storage, but twice more Video and Audio combination are allowed.
Old 3rd February 2010, 16:23   #50  |  Link
renqian
here some primary question:
which Splitter Filter should i use to keep the field won't loss when i encoding?
and which decoder can playback the product correctly in 60fps on LCD or LCD TV?(i mean if i use the HTPC)
renqian is offline   Reply With Quote
Old 3rd February 2010, 16:45   #51  |  Link
rack04
Is anyone able to patch the latest git with v1.22?
rack04 is offline   Reply With Quote
Old 3rd February 2010, 23:49   #52  |  Link
rallymax
Rallymax
no. I've just manually done the change . When I get home I'll copy it onto my SVN tree so that I can generate a diff and post it.
rallymax is offline   Reply With Quote
Old 4th February 2010, 00:00   #53  |  Link
mp3dom
It does.
Thank you very much! Since you're so kind, can I ask what are the next steps before final commit? Is there something new that need to be tested? (with the Interra verifier I cannot test anything more). Thanks again!
Old 4th February 2010, 13:10   #54  |  Link
alwa
Ready to patch. The @@ get removed by patebin...
alwa is offline   Reply With Quote
Old 4th February 2010, 13:55   #55  |  Link
jpsdr
Can someone make a patch with it and the autoVAQ ?
Old 4th February 2010, 16:14   #56  |  Link
kieranrk
Need to fix max_cpb_delay_length with pulldown changes because it's wrong.
Also need to fix bug with calculation of displayed frames because it doesn't take into account any new parameters pass with the frame.
Needs a pengvado review.
Use the download button in pastebin.
Old 4th February 2010, 18:28   #57  |  Link
rallymax
Rallymax
I did that and it still wouldn't apply.
what are you all using as your patching command line - and is in on Msys?
Old 4th February 2010, 18:52   #58  |  Link
kieranrk
patch -p1 <in.diff
If it doesn't work I'll post a new one.
Old 4th February 2010, 19:20   #59  |  Link
rallymax
Rallymax
Version 1.22.
Patch: http://pastebin.com/m6ed0b13a
I used the above URL and did "download" and saved it as "nal-hrd-1.2.2.diff".
I then applied it in a Msys to a vanilla git checkout on Windows7 and got this error...
rallymax@CARTMAN /c/SVN/x264 <--- don't let the SVN throw you off. it is a git directory.
$ patch -p1 < nal-hrd-1.2.2.diff
patch unexpectedly ends in middle of line
patch: **** Only garbage was found in the patch input.
So I have no idea what's wrong. Note, that I've never applied a patch before so it could be the host that's screwed up not the patch itself.
Old 4th February 2010, 19:22   #60  |  Link
alwa
That does not help, the @@ are still missing... Try yourself if you don't believe me.
The file i uploaded on mediafire contains them, it works with the following command:
patch -p1 < nal-hrd1.22_fix.diff
Last edited by alwa; 4th February 2010 at 19:31. Reason: reread the thread a bit :)
