2nd October 2022, 11:07 | #241 | Link |
Acid fr0g
How is it done with other, more friendly, software, such as Totalcode Studio or, perhaps, Dolby Media encoder? I really have no interest in 7.1 but 5.1.2 would be nice to have.
@turment on Telegram |
2nd October 2022, 11:44 | #243 | Link |
Life's clearer in 4K UHD
Me too... I guess a dedicated 'Looking for an Atmos encoder' topic will now need creating...
2nd October 2022, 18:36 | #244 | Link |
Like I say Mainconcept Totalcode do not offer the 5.1.2 layout, I don't know if Dolby Media encoder can do it, not Dolby Encoder Engine.
I can encode to DTSMA to C L R Ls Rs LFE Vhl Vhr (see image) and play fine in my AVR 5.1.2 like the Atmos or Audition eac3 encodes. Code:
139.404.590 CoreAT.thd Source TrueHD Atmos 7.1 81.928.230 Core71.thd Source without Atmos metadata 216.505.028 Core71.wav Decoded to 71 98.373.524 Core71.dts Encodec to DTS-MA 71.615.788 Core71.flac Encodec to Flac 5.1.2 216.505.004 Core3D.wav Atmos decoded to 5.1.2 with Dolby Ref Pla 117.133.232 Core3D.dts Encodec to DTS-MA 88.144.518 Core3D.flac Encodec to Flac 24.064.000 Core3D_k24.ec3 Audition recoded to 1024 Kb/s 9.024.000 Core3D_384.ec3 Audition recoded to 384 Kb/s
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 2nd October 2022 at 19:19. |
4th October 2022, 03:52 | #246 | Link | |
>I think it has 3db attenuation and 90 degree phase shifting enabled just like in the xml templates for DEE, but I never used DME No, the bug is just some off-by-ones. Plex decoder and ffmpeg decoder agree (besides some zeroes in the end). Besides 3 db is just for EAC3, no... Last edited by Balling; 4th October 2022 at 05:29. |
31st October 2022, 21:01 | #250 | Link |
If your are referring to the 5.1 dts core, I use TSmuxer GUI...
31st October 2022, 21:41 | #251 | Link | |
Acid fr0g
Audio Format : DTS ES XXCH XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Bit rate mode : Variable / Constant / Constant Bit rate : Unknown / 1 509 kb/s / 1 509 kb/s Channel(s) : 7 channels / 7 channels / 6 channels Channel layout : C L R Ls Rs LFE Cb / C L R Ls Rs Cb LFE / C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 16 bits Compression mode : Lossless / Lossy / Lossy Code:
Audio Format : DTS ES XXCH Format/Info : Digital Theater Systems Commercial name : DTS-ES Discrete Duration : 1 h 40 min Bit rate mode : Constant Bit rate : 1 509 kb/s Channel(s) : 7 channels / 6 channels Channel layout : C L R Ls Rs Cb LFE / C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 1.06 GiB (100%)
@turment on Telegram Last edited by tormento; 31st October 2022 at 21:49. |
31st October 2022, 21:53 | #252 | Link |
31st October 2022, 22:56 | #253 | Link | |
31st October 2022, 23:48 | #254 | Link | |
The core 1509 Kb/s is accepted to be passed by SPDIF and played by DVD players 5.1 only but if you want encode to AC3 you need downmix it, from the MA or from the core. If you want encode to DDP: Audition and TotalCode have the equivalent channel layout 3/3 L R C LFE Ls Rs Cs. Like in this century Ls/Rs is decoded to SL/SR we need remap the wav order FL FR FC LFE BC SL SR -> ...|c4=c5|c5=c6|c6=c4
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 1st November 2022 at 00:13. |
1st November 2022, 09:40 | #255 | Link | |
Acid fr0g
Yes, that's the way I will follow. It's so weird that DEE can't encode it.
1st November 2022, 16:31 | #257 | Link |
I currently don't have my AVR handy (it's in the loft), but the last time I checked sending a DTS-ES bit-stream to it from my OPPO via HDMI, the 'DTS-ES' icon lit up on the AVR. Same goes with DTS 96/24 content
I didn't try the SPDIF optical or electrical outputs from my OPPO to the AVR.
2nd November 2022, 03:20 | #259 | Link |
Yes.
TotalCode asks for 3/3 L R C (LFE) Ls Rs Cs, forget MediaInfo order please, when you decode the DTS to WAV/W64 the order is FL FR FC LFE BC SL SR then you need remap the BackCenter to the end (c6=c4) to match the CenterSurround
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 2nd November 2022 at 03:23. |
2nd November 2022, 11:03 | #260 | Link |
@tormento, post moved to https://forum.doom9.org/showthread.p...43#post1977643
eac3 |
