Old 24th June 2005, 21:37   #1  |  Link
Wilbert
Uploading pictures, clips or other files to a webserver
Some webservers for uploading pictures, clips and other files.
Uploading pictures:
http://www.imageshack.us/ (up to 1 MB)
Uploading pictures, clips and other files:
http://www.mediafire.com/ (up to ... MB)
http://www.rapidshare.com/ (up to ... MB)
http://www.savefile.com/filehost/ (up to 60 MB)
http://www.putfile.com/ (up to 10 MB)
http://www.badongo.com/ (up to 500 MB)
http://fileho.com (limit ?)
more: http://forum.doom9.org/showthread.php?t=129613
Old 24th June 2005, 21:59   #2  |  Link
unskinnyboy
unskinnyboy's Avatar
This is the master list of all free image hosting sites:
http://www.free-webhosts.com/free-image-hosting.php
Browse thru and take your pick.
EDIT: a few more file hosting sites
http://www.yousendit.com/ send upto 1 GB
http://www.filecabi.net/ (10MB limit)
http://www.filecabin.com/ (3MB limit)
http://www.spacepur.de/ (200MB limit, they say "Eroticsites desired", not sure what that means though)
http://www.megaupload.com/ (500 MB limit, damn slow though IME)
http://www.mytempdir.com/ (25 MB limit)
http://www.simple-share.com/ (they don't mention the size limit)
unskinnyboy is offline   Reply With Quote
Old 12th July 2005, 19:26   #3  |  Link
unskinnyboy
I have been using this little tool (just 295 KB) called Imageshackert for quite some time now and wanted to share this with you. This is an Imageshack uploader tool and is quite fast and a big timesaver.
Website - http://buggyashell.nl/progs/imageshackert/ (in Dutch)
Download link - http://buggyashell.nl/progs/imageshackert/download/ (software is in English).
Extract the imageshackert.exe from the zip file and put it in a folder (e.g: C:\Program Files\Imageshackert), now put a shortcut to this to your Desktop or Quick Launch bar (I have the shortcut on my QL bar).
Launch the app and set the options as below:
The app:
Browse and select the file, and click 'Host it':
The file gets hosted and the url also copied to clipboard, the only thing left to do is to paste it into the forum between the [IMG] tags! DONE!
Since we all do a lot of image hosting, I hope you find this as useful as I did.
Old 14th August 2005, 03:17   #4  |  Link
animeultima
animeultima's Avatar
www.usmanbiz.com upload: 1gig - 1 gigabyte space 5 gigs bandwidth (free)
animeultima is offline   Reply With Quote
Old 14th August 2005, 07:14   #5  |  Link
unskinnyboy
Where? All I can see is a weird page with lot of logos? and this is a web hosting companies' site? Also I didn't see any free options there. Is this some scam? Looks dodgy.
Old 14th August 2005, 08:36   #6  |  Link
Shinigami-Sama
Solaris: burnt by the Sun
Shinigami-Sama's Avatar
wow
that has to be one of the worst webspace deals ever too..
and I didn't see the free thing either
Originally Posted by benjust View Post
interlacing and telecining should have been but a memory long ago.. unfortunately still just another bizarre weapon in the industries war on image quality.
Shinigami-Sama is offline   Reply With Quote
Old 14th August 2005, 08:52   #7  |  Link
Zyphon
Zyphon's Avatar
@unskinnyboy
Have you ever used the ImageShack QuickLoad tool >here<?
Once installed all you have to do is right-click on a picture and then select"ImageShack Quickload." to upload to ImageShack.
It requires MS Framework.NET to work though.
Just wondered if anyone has used it seems like a neat little tool and a breeze to use.
Regards
Michael.
Zyphon is offline   Reply With Quote
Old 14th August 2005, 11:46   #8  |  Link
Wilbert
@animeultima,
Is there free hosting on that site or not?
Old 14th August 2005, 13:58   #9  |  Link
MTM
After much search on the site , I found the following : link.
Regards,
MTM.
MTM is offline   Reply With Quote
Old 14th August 2005, 17:24   #10  |  Link
danpos
BDVD Team
danpos's Avatar
I've installed and used it and one really does the life more easy for me when I need hosting some picture.
danpos is offline   Reply With Quote
Old 14th August 2005, 19:19   #11  |  Link
unskinnyboy
Originally Posted by Wilbert
@animeultima,
I don't think so. That guy was probably trying to fish for customers from amongst gullible people. Please remove that link if possible.
@unskinnyboy
Thanks man. Looks good, will try this out.
Old 16th August 2005, 07:39   #12  |  Link
Shinigami-Sama
imageshack has lack listed a couple of my man forums, so thats kinda usless for some, but it hasn;t blacklisted doom9 yet so thats good
Old 16th August 2005, 09:11   #13  |  Link
Wilbert
No, he wasn't. Please check the link MTM posted (free hosting: 1 GB with banner, and 512 MB without banner). Looks fine to me.
Old 16th August 2005, 10:31   #14  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
I can't say I've had any good experiences downloading files hosted via "rapidshare"...
Everytime I log onto their "free" service I'm told the following: -
Cheers
Old 16th August 2005, 15:09   #15  |  Link
unskinnyboy
@SMD, 62.254.0.34 is the IP address of an NTLWorld web proxy cache. In most international (or UK based) forums, if you search for the IP 62.254.0.* (hostname - nott-cache-??.server.ntli.net) via the vBulletin/phpBB AdminCP, you will see many users for the same IP address. Each of those IP belongs to an NTLWorld gateway, which sorts of hides your real IP address from the outer world (not sure if this is the primary purpose of WPCs though, haven't seen this issue anywhere in NTSC land till now) - good in a way in that it offers some amount of privacy protection, bad in a way in that if a website decides to ban/blacklist one of these IPs, many people gets affected.
More detailed/useful info - http://homepage.ntlworld.com/robin.d...trancache.html
Old 16th August 2005, 15:40   #16  |  Link
SeeMoreDigital
Thanks...
This sort of thing is way over my head but your explanation has helped tremendously!
Do you know how/why "Premium Account" holders are not affected by the same limitation.... Not that I'm going to buy one!
Would it be worth our while if some of us Doom9 members pooled some money together and bought some additional web server space, so members could host "test files" of up to, say 10MB over a short period?
Cheers
Old 16th August 2005, 16:33   #17  |  Link
unskinnyboy
If you look at the RapidShare FAQ, they have given a lucid explanation for this:
Your system complaints about that I am already downloading files or that I have already downloaded too much. But I did not download anything! Whats wrong there?
Our system checks your IP-address in order to count the downloads. If you are getting this message and you really did not download anything, then you are using a proxy-server, which is used by other people as well. Even if you have no proxy-server set up in your configuration, there are providers who put transparent proxy-servers between you and the net. Even if you are completely sure that you have no proxy-server attached, you are wrong. Compare the IP-address of the error-message with your real internet-IP. Those will differ. We only see your Proxy-IP. But what can you do? You have to disable this proxy-server. If you are not able to disable the proxy-server, we can only suggest you to get a Premium-account. Premium-users are recognized by cookies, not IP. Unfortunately we cannot disable our IP-check, else people would download so much that we would have to close down this service.
Now how to get around this?
The easiest way is to use an anonymous proxy. A little bit of googling will give you plenty of proxy lists, but most of them are snail-slow, if not already defunct within a few hours of getting listed. I poked around a bit more for a less painless method and I found this page. If you read the thread, you can see a couple of workarounds suggested. Worth trying.
Us Doom9'ers buying webspace is not going to be of much use. Who will have access? Who controls the access? Also, you can't really go around and police the uploads, user A wants to upload a file of 10 MB, but alas no space left etc. Not to mention possible legal issues if the webspace thingy gets associated with Doom9, since this can also be interpreted as file-sharing (!!). If needed, there are many other alternatives to Rapidshare, so you are better off using them..namely YouSendIt.com + the others listed in the beginning of the thread.
Old 16th August 2005, 16:55   #18  |  Link
SeeMoreDigital
Perhaps such files could be policed by the moderators... in much the same way small "bmp, doc, gif, jpe, jpeg, jpg, pdf, png, psd, txt and zip" attachments are done now.... However, unlike the afore mentioned files, each video or audio file would be deleted automatically after two or three days!
And thanks for the link
Cheers
Old 28th August 2005, 01:23   #19  |  Link
animeultima
hey, i just completely forgot about this post. I do not work for the site, and i could care less if they shut down. Dang! I would have told y'all if I remembered. I was looking for another post and couldn't find it so i did a search of posts i made, and came across this. haha. They have like 1 gig of space and 5 gigs of bandwidth. They supposidly have a plan with unlimited space and unmetered bandwidth. My cousin has a site with that and it is doing good for him. I wish he would let me use it for anime but he doesn't want to take any chances with my stuff. So he says I got to get my own.
Old 28th August 2005, 04:32   #20  |  Link
Backwoods
ReMember
Backwoods's Avatar
www.uploadhouse.com
Backwoods is offline   Reply With Quote
