Old 5th August 2018, 00:28   #941  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Originally Posted by pinterf View Post
Download xy-VSFilter / XySubFilter v3.1.0.800
-- Native support for YUV420P10 and YUV420P16 formats in Avisynth filter TextSub and probably VobSub.
thank you very much indeed for making it available in 10bit and 16bit!!
I don't have to do this anymore:
#Hardsub 8bit
s16 = last
DitherPost (mode=-1)
TextSub("Ep1.ass")
#Overlay 8bit subs to 16bit video
Dither_convert_8_to_16 ()
s16.Dither_limit_dif16 (last, thr=1.0, elast=2.0)
Thank you!!
Originally Posted by hello_hello View Post
pinterf,
I'm having an issue with VSFilter 3.1.0.800.
Full XP discloser: I'm running XP.
If I have VSFilter in a script it results in the following error when I try to preview it in AvsPmod:
LoadPlugin: unable to load "C:\Program Files\MeGUI\tools\avisynth_plugin\VSFilter.dll", error=0x3e6
That's because when he compiled he didn't target XP in Visual Studio 2017.
The dll calls DeleteProcThreadAttributeList and InitializeProcThreadAttributeList that are missing in the XP kernel.
Old 6th August 2018, 09:38   #942  |  Link
pinterf
for hello_hello's problem:
Actually vsfilter was compiled with the v141_xp toolset with the usual /Zc:threadSafeInit- option.
pinterf is offline   Reply With Quote
Old 6th August 2018, 20:25   #943  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
That's weird, 'cause I tried to run it on an XP virtual machine just to be sure and it doesn't recognise the command "TextSub()" with the new DLL, 'cause it fails to load and when I opened it with Dependency Walker I noticed these two missing function calls.
(And by the way, I have all the C++ Redistributable on my VM 2005 - 2017 and it's an AVX2 capable CPU, although XP supports up to SSE4.2 only).
Old 28th August 2018, 12:18   #944  |  Link
Siso
Soul Seeker
Siso's Avatar
Can anyone help me with xy-vsfilter 3.0.0.400, when I watch 1.85:1 movies the subtitles are in high quality. But when I watch 2.35:1 or 2.40:1 movies, the subtitles quality is low...
Siso is online now   Reply With Quote
Old 28th August 2018, 13:06   #945  |  Link
sneaker_ger
xy-vsfilter renders the subtitles at the video resolution. So if you want to increase quality you would have to upscale (at least the chroma) in the chain before the picture reaches xy-vsfilter.
But it is more straight-forward to use a subtitle renderer that renders at the display resolution to begin with like e.g. the internal subtitle renderer (ISR) of MPC-HC or XySubFilter.
Old 28th August 2018, 13:31   #946  |  Link
jmonier
Are you using madVR as the renderer and LAV Splitter? xy-vsfilter interfaces directly with them and then should not have the problem you are seeing.
jmonier is offline   Reply With Quote
Old 28th August 2018, 14:19   #947  |  Link
Siso
Soul Seeker
Siso's Avatar
Yes I'm using madvr and lav filters.
Old 28th August 2018, 14:20   #948  |  Link
Siso
Soul Seeker
Siso's Avatar
Is the bug with the italics has been fixed in xysubfilter?
Old 28th August 2018, 15:17   #949  |  Link
sneaker_ger
Madshi released a fixed version for it. I think it's still not in pinterf's fork, though.
https://forum.doom9.org/showthread.p...84#post1839284
Old 28th August 2018, 19:53   #950  |  Link
Siso
Soul Seeker
Siso's Avatar
Thank you for the link.
Old 4th September 2018, 12:14   #951  |  Link
pinterf
New build, download v3.1.0.801
An issue with random x64 crashes was reported on git and it looked interesting enough
Then I have found some "new" commits in the original rc4 branch, including the fix for italics issue, so I included them also. I hope they work, there are quite a few branches there.
Note: as original authors have said, treat this version as a beta.
Note2: I'm just a re-builder and not developer of the product. Use my build as-is.
Warning: problems under xp reported, despite my v141_xp settings.
v3.1.0.801 (20180904)
- fix random crash in x64 build (address truncated to 32 bits, Rasterizer::Draw and Rasterizer::FillSolidRect were affected)
- XySubFilter.DLL now compiled with v141_xp toolset instead of v141 (like VSFilter.DLL)
- From upstream (madshi, Cyberbeing)
  - Fix a possible infinite loop in the Real Text subtitle parser on 64-bit
  - Fix external SRT subtitles with italic tag not being flagged as repositionable
  - Disable repositioning for SSA/ASS subtitles with default position level
  - Add setting to allow repositioning of SSA/ASS dialog
Old 7th September 2018, 00:40   #952  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Still, VSFilter 3.1.0.801 doesn't work on my XP Professional (with Microsoft Extended Support) with Avisynth+ r2728.
None of your modified version work on XP, even though you compiled with v141_xp.
I have all the C++ Redistributable installed, from 2005 to 2017, by the way.
I tried with a simple script, but AVSPmod didn't recognize the command "TextSub" in the first place.
When I tried to run it:
So I tried to run AVSMeter and it reported "Invalid Access Memory Location (998)".
I decided to investigate why and it seems that two kernel calls are missing in Windows XP: InitializeProcThreadAttributeList and DeleteProcThreadAttributeList.
Unfortunately, these two functions have been introduced in Windows Vista.
InitializeProcThreadAttributeList is a bool.
It returns a zero value if it fails or a non-zero value if it succeeds.
It has lpAttributeList (which is the attribute list and it can be NULL to determine the buffer size required to support the specified number of attributes), dwAttributeCount (which is the count of attributes to be added to the list), dwFlags (which is a reserved parameter and it must be zero) and lpSize.
BOOL InitializeProcThreadAttributeList(
  LPPROC_THREAD_ATTRIBUTE_LIST lpAttributeList,
  DWORD                        dwAttributeCount,
  DWORD                        dwFlags,
  PSIZE_T                      lpSize
DeleteProcThreadAttributeList is a void and thus it does not return a value. It simply has lpAttributeList which is the attribute list created by the InitializeProcThreadAttributeList function.
void DeleteProcThreadAttributeList(
I took a look at Wine and it seems that they implemented the call, so I tried to take their implementation and use it as a wrapper to basically direct the call to it instead of to the kernel, but unfortunately it didn't work (I messed it up when I tried to adapt it, I'm 100% sure).
Any thoughts?
Old 7th September 2018, 09:39   #953  |  Link
nevcairiel
Going multiple levels down in Dependency Walker is not meaningful, since you cannot control what other DLLs use. You can only check what your own DLL imports directly, and if those are fine then thats not it. From the error it sounds like the DLL crashes on load, not that it fails to load due to missing symbols.
Old 7th September 2018, 10:07   #954  |  Link
pinterf
Don't know, what happens, all I have found is:
https://developercommunity.visualstu...-target-s.html
And the DLLs were compiled with /MT instead of /MD, so no redistributables are needed.
Old 7th September 2018, 15:34   #955  |  Link
jpsdr
Stupid question, you didn't forget the /Zc:threadSafeInit- option ?
My github.
Old 10th September 2018, 06:38   #956  |  Link
tonyxc600
Trying to open external PGS subtitles (whether autoloading or manual) results in my player freezing for extended periods of time, and when it does finally load the text is either greatly out of sync or don't display at all.
Muxing the subs into the video allows it to load correctly. The issue is also consistently reproducible when I extract subs from any video and try to load them externally.
Is this a known issue with external PGS subs?
tonyxc600 is offline   Reply With Quote
Old 10th September 2018, 15:40   #957  |  Link
pinterf
No, it's there.
Old 20th September 2018, 18:29   #958  |  Link
Siso
Soul Seeker
Siso's Avatar
Do the subtitle output options in XYVsfilter - YCbCr level range "auto" and YCbCr matrix should always be on "auto"? In the OSD when they are on auto it says Colorspace: TV BT.601(auto), if I set the matrix to "guess" it says TV BT.709 (Guessed). I watch only BT.709 content. Which option is the right one?
Old 20th September 2018, 19:06   #959  |  Link
leave it at the default settings because this topic is very simple and very complicated at the same time.
the issue comes from the software creating the ASS sub titles usual aegisub which doesn'T really care about color matrix in the past and was using BT 601.
the content you watch is not of important it is the ass sub colors relative to the video.
it get's really complicated on how they fixed this issue.
Old 20th September 2018, 19:08   #960  |  Link
Siso
Soul Seeker
Siso's Avatar
My subtitles are in srt, but I guess the defaults will work, right huhn?
