Old 19th March 2022, 22:30   #7101  |  Link
tebasuna51
tebasuna51's Avatar
Thanks Barough, this build work fine for me.
Old 29th March 2022, 08:00   #7102  |  Link
simple_simon
Originally Posted by disklib View Post
The AVS Script Creator preview window seems to be cropping the right side of the image frame.
I experienced this when I upgraded to MeGUI 2928 and DGIndex 2005+. I went down a rabbit hole trying to get the Index to work (fake license file/manual upgrade/enable NV version/etc) so my recollection of all the steps I took is a mess, but I can say I experienced the problem once I upgraded beyond MeGUI 2924 + DGIndex 2002. I just restored back to those versions and the crop preview is now correct.
The crop was about 6 pixels from the right edge, which in my case happened to correspond to the black pixels on that edge of the frame. When I encoded that the black pixels were included in the mp4. I confirmed the crop spinner was set to 0 in the Script Creator window. If I'm remembering correctly I think I tried clicking the right spinner up a few times (0 to 2 to 4 pixels) and surprisingly noticed no change to the preview image on that edge.
I just noticed this also. It must be an error in MeGUI though (not DGIndex) because I'm using LSMASHWorks to index and getting the same problem.
And I foolishly deleted my older versions. Where can I download "megui-core-2927-64.7z" until this issue is corrected?
simple_simon is offline   Reply With Quote
Old 29th March 2022, 14:06   #7103  |  Link
kedautinh12
only 2924 is older had link download. You can download megui-core-2924 here
http://megui.tmebi.de/test/?C=M;O=D
Old 31st March 2022, 08:43   #7104  |  Link
simple_simon
Cool! Thanks
Old 7th April 2022, 06:28   #7105  |  Link
kedautinh12
L-SMASH-Works (20220406)
https://github.com/HomeOfAviSynthPlu...Works/releases
Old 11th April 2022, 00:08   #7106  |  Link
kedautinh12
MKVToolNix v67.0.0
https://mkvtoolnix.download/windows/releases/67.0.0/
https://mkvtoolnix.download/doc/NEWS.md
Old 16th April 2022, 04:15   #7107  |  Link
kedautinh12
ffms2_6ad7738
https://forum.doom9.org/showthread.p...60#post1967460
Old 20th April 2022, 17:40   #7108  |  Link
kedautinh12
MP4Box v2.1-DEV-rev119-gd2f75dd7b
https://www.mediafire.com/file/vku45...GCC112.7z/file
Old 24th April 2022, 08:39   #7109  |  Link
LeXXuz
21 years and counting...
LeXXuz's Avatar
Pardon me, but why are you guys posting all these tools in here?
LeXXuz is offline   Reply With Quote
Old 24th April 2022, 10:14   #7110  |  Link
Barough
Barough's Avatar
So that users can manually update MeGUI if they want until Zathor gets around to do the updates on the server.
Skickat från min SM-S908B via Tapatalk
Do NOT re-post any of my Mediafire links. Download & re-host the content(s) if you want to share it somewhere else.
Old 24th April 2022, 23:40   #7111  |  Link
Danette
NOTE: Below was posted previously. I have since submitted a bug report on the Sourceforge MeGUI site.
When encoding (x264) script (One-Click) using MT and using certain script, MeGUI crashes with the message: “MeGUI has stopped working.” This happens when using either the batch function or loading files individually. Of course, this closes MeGUI, so no log or error messages are recorded. Sometimes (I can’t reproduce it intentionally), the MeGUI crash message is preceded by a visual C++ Runtime Library error message that goes on to say that “This application has requested the Runtime to terminate it in an unusual way”, but this is rare.
When I reopen MeGUI, the batch files are still in the queue and when I start the second file (which crashed, above), it encodes normally, but then the next file in the queue crashes when it begins encoding. This cycle goes on and on through all files in the batch.
When I run the full script without MT, there is no problem. Similarly, when I run the script, without Decimate() or QTGMC(InputType=1,Preset="Medium”), but with MT, it runs fine. In other words; either the Decimate() filter OR the QTGMC(InputType=1,Preset="Medium”) filter, alone or together, will cause the crash in MeGUI.
The script used is:
SetFilterMTMode("DEFAULT_MT_MODE",2)
MPEG2Source("C:\xxxx.d2v", cpu=0)
TFM(slow=2)
Decimate()
AssumeTFF()
CropResize(0,0, 0, 0, 0, -0,InDAR=15.0/11.0,ResizeWO=True,Resizer="Lanczos4Resize")
GradFun3()
Prefetch(3)
MeGUI version is v2913, AviSynth+ v3.7.2 (Redistributable (x86) v14.31.31103), filters and dependencies all seem to be current.
Found this in the Windows log /application:
Application: MeGUI.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
at MeGUI.AviSynthClip.dimzon_avs_init_3(IntPtr ByRef, System.String, System.String, AVSDLLVideoInfo ByRef, MeGUI.AviSynthColorspace ByRef, MeGUI.AudioSampleType ByRef, System.String)
at MeGUI.AviSynthClip.OpenAVSScript(System.String, System.String, Boolean, System.String ByRef)
at MeGUI.AviSynthClip+<>c__DisplayClass68_0.<.ctor>b__0()
at System.Threading.ThreadHelper.ThreadStart_Context(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Threading.ThreadHelper.ThreadStart()
Followed by this:
Faulting application name: MeGUI.exe, version: 1.0.2913.0, time stamp: 0x5d962e52
Faulting module name: avisynth.dll, version: 3.7.1.0, time stamp: 0x61cf9ff3
Exception code: 0xc0000005
Fault offset: 0x000db860
Faulting process id: 0x1ac
Faulting application start time: 0x01d858a1df69b791
Faulting application path: C:\Program Files (x86)\MeGUI-2913\MeGUI.exe
Faulting module path: C:\Windows\system32\avisynth.dll
Report Id: d21d136a-c498-11ec-82d4-8056f23b3d03
Danette is offline   Reply With Quote
Old 25th April 2022, 01:54   #7112  |  Link
kedautinh12
dgdecnv_242
http://rationalqm.us/dgdecnv/binaries/dgdecnv_242.zip
Old 26th April 2022, 10:53   #7113  |  Link
LeXXuz
LeXXuz's Avatar
Ah. Got it
Old 27th April 2022, 01:35   #7114  |  Link
Danette
Thanks for all of these updates. I didn't realize that Zathor was MIA (I guess my bug report on Sourceforge will be never be solved).
Is there a way to get MeGUI's updater to load these zipped files (I assume after placing them in the update_cache folder), or do the unzipped contents need to be manually placed into the appropriate locations?
Old 27th April 2022, 01:52   #7115  |  Link
Barough
Barough's Avatar
Zathor is MIA from here but he's on Sourceforge once in a while. All issues should be posted on MeGUI's issue tracker on Sourceforge.
Regarding the updates..... you need to manually extract and replace the files in question.
Sent from my SM-S908B via Tapatalk
Old 27th April 2022, 09:25   #7116  |  Link
tebasuna51
tebasuna51's Avatar
I see in one log from your megui bug:
---[Information] AviSynth Wrapper
----[Information] Version: 1.0.2847.0
----[Information] Date: 06-05-2018
----[Information] Interface: 3
----[Information] File Version: 3.7.2
----[Information] File Date: 18-03-2022
Remember replace the AvisynthWrapper.dll
If you still have the old AvisynthWrapper.dll try check Options -> Main -> Always use the included AviSynth and see if the problem persist.
If run fine with the included Avisynth+ version 3.5 r3106 it is not a MeGUI problem.
Old 30th April 2022, 01:47   #7117  |  Link
Danette
Ugh!! How careless of me - I knew that ... in the past. That solved it. Thanks. At least my mistake forced me to update all my filters and add the manual updates to create MeGUI v2928.
Old 5th May 2022, 19:11   #7118  |  Link
kedautinh12
L-SMASH-Works 20220505
edit: older ver error with Megui when indexing VFR video
Old 6th May 2022, 08:11   #7119  |  Link
Zetti
DGIndex/DGMPGDec 2.0.0.7
http://rationalqm.us/dgmpgdec/dgmpgdec2007.zip
Source: https://rationalqm.us/board/viewtopi...p=15684#p15684
Zetti is offline   Reply With Quote
Old 8th May 2022, 01:18   #7120  |  Link
kedautinh12
Getting close to stability. One more time, please re-download DGMPGDec 2.0.0.7 and update 64-bit DGDecode.dll. The property _AspectRatio was removed. _SARNum/_SARDen were changed to report the "pixel size", aka PAR. The alias D2VSource() was removed so as not to collide with other 3rd-party software.
