Old 28th November 2023, 22:26   #21  |  Link
Argaricolm
Originally Posted by Selur View Post
Nice! Thanks!
Did some quick tests, seems to work fine in Vapoursynth.
About color space support:
Would be cool if you could also add 10, 16, 32bit support, if possible.
(in detail: RGBS, RGBH, RGB48,RGB30, YUV420P10, YUV420P16, YUV420PS, YUV420PH, YUV444PH, YUV444PS, YUV444P10, YUV444P16)
Cu Selur
Redownload 1.11 release. I'v fixed it a little. It contained wrong check in avisynth version.
Next I will add RGB32 support.
Argaricolm is offline   Reply With Quote
Old 29th November 2023, 11:49   #22  |  Link
Selur
Selur's Avatar
Will do. Thanks!
Hybrid here in the forum, homepage, its own forum
Old 2nd February 2024, 00:19   #23  |  Link
Argaricolm
A new update.
Added new mode 1 (other numbers changed).
Added RGB32. But only for avisynth (vapoursynth strangely does not support RGB32).
Old 3rd February 2024, 20:36   #24  |  Link
Selur
Selur's Avatar
Using the latest version in Vapoursynth, when using:
# adjusting color space from YUV420P8 to RGB24 for Softlight
clip = core.resize.Bicubic(clip=clip, format=vs.RGB24, matrix_in_s="470bg", range_s="limited")
# color adjustment using Softlight
clip = core.Argaricolm.Softlight(clip)
I get just a black output, while using:
# adjusting color space from YUV420P8 to YUV444P8 for Softlight
clip = core.resize.Bicubic(clip=clip, format=vs.YUV444P8, matrix_in_s="470bg", range_s="limited")
works as expected.
Doesn't matter whether I use "CUDA 12.3/SoftLight.dll" or "CUDA 11.8/SoftLight.dll".
=> seems like v1.12 broke RGB24 support for Vapoursynth.
Cu Selur
Ps.: Do you prefer if I post such stuff here or on github?
Old 14th February 2024, 10:58   #25  |  Link
Argaricolm
"Added RGB32. But only for avisynth (vapoursynth strangely does not support RGB32)."
There is no RGB24 support (so far).
And strangely vapoursynth does not support RGB32. That should be faster in memory because of 4 bytes addressing.
Old 14th February 2024, 20:08   #26  |  Link
Selur
Selur's Avatar
afaik. Vapoursynth handles alpha channels in a separate 'stream/clip'.
Old 18th February 2024, 00:59   #27  |  Link
Argaricolm
Well for RGB32 i just use R,G,B bytes and skip alpha one.
So it's just like I use RGB24 but in RGB32 adressing.
In avisynth memory 4th byte is automatically set to FF (255) when 24bit (8*3) content is converted to RGB32.
So it's not realy a correct RGB32 support.
Maybe I need to change it to RGB24.
Old 18th February 2024, 08:41   #28  |  Link
Selur
Selur's Avatar
Yeah, sound like it should be RGB24 not RGB32 if the alpha channel isn't used.
Old 15th March 2024, 22:05   #29  |  Link
Argaricolm
New version 1.13.
Now RGB will work in Vapoursynth. It is RGB24 planar.
Also I'v updated CUDA toolkit to 12.4 version.
Old 16th March 2024, 13:48   #30  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
Am I missing something?
colorbars(pixel_type="rgb24", width = 3840, height = 2160).softlight
doesn't seem to do anything (same with a real image source). AvsMeter can't time the script because it's too fast, which kind of suggests the filter isn't doing anything. I tried it on two different computers (laptop and desktop) with Nvidia cards.
Does it just pass through the original clip if there is a CUDA issue?
Edit: RGB24 interleaved doesn't work, RGB32/YV12/presumably others does
Further edit: doesn't seem to work at all on my desktop computer, just returns unaltered clip...
Edit: Having looked at the code there is zero error handling/reporting, even for CUDA failures. You might want to add some!
wonkey_monkey is offline   Reply With Quote
Old 16th March 2024, 14:12   #31  |  Link
Selur
Selur's Avatar
RGB24 works in Vapoursynth here.
Old 16th March 2024, 20:12   #32  |  Link
Argaricolm
It does nothing if CUDA is not supported or not supported input format.
Old 16th March 2024, 23:27   #33  |  Link
wonkey_monkey
Error throwing would be very helpful to avoid confusion, e.g.:
	if (cudaStatus == cudaSuccess) {
	} else {
		env->ThrowError("SoftLight: CUDA failed");
and similar when none of the conditions in GetFrame are met (although testing should be in the constructor, ideally).
Going back in time a little:
Possible on CPU too. But it will be around some fps. While cuda version 10x more faster.
I've investigated my scepticism and although it will obviously vary depending on CPU, GPU, colourspace etc, for a YV12 input I found only a 1.4x-1.7x speed increase over CPU AVX code implementing mode=3 (pegtop).
For interleaved RGB input, AVX code was 1.3x faster than CUDA, even with AviSynth+ colourspace conversion overheads. Multithreading might give another 25%-50% boost.
Old 17th March 2024, 07:08   #34  |  Link
DTL
Because summing each frame on CPU is very slow.
To sum all samples of the frame at SIMD there are possible several ways:
1. Sum at integer - require unpacks of 8..16 samples to 32bits and use summing of standard SIMD full width * superscalar factor of sum dispatch ports first for all samples of a line.
Because it looks 32bit integer can not hold UHD frame samples number * 256..65535 samples values sum without overflow - it is possible to make intermediate division of intermediate sums for each line and accumulate normalized sums of the all lines of a frame. It is more complex to program in compare with float32 processing but maybe visibly faster for SD 8bit and some HD frame sizes.
2. Make unpack and convert to float32 and perform all of 1 in float32 domain.
So best performance implementation can have different processing engines inside for different frame sizes. At least 1920x1080 with 8bit still can be processed with integer full frame summing without 32bit accumulator overflow. Also with SIMD word summing programmer anyway have partial sums at the final SIMD word ready to partial normalizing with some more overflow protection (AVX2 SIMD word of 8 32bit integers provides additional +3bits to overflow so total capacity is 32+3=35bits) and without significant precision loss.
Method 2 can process any frame sizes in single engine but expected to be slower at non-UHD frame sizes.
CPU SIMD is not very slow - but algorithm requires at least 2 full frame passes: first analisys pass of sum and second is correction pass of adjustment so performance will depend on frame size fitting in availavle CPU caches (our lovely Xeon MAX with HBM onboard will be nice performer here).
Old 4th May 2024, 17:17   #35  |  Link
Argaricolm
A new release - 1.14.
Also a question for video gurus here:
As I see nearly ALL content that is released now on blurays or streamed through streaming services are encoded in limited color range (16-235). The question is why it is so?
Old TVs that had such limitations are already all in junk. And new TV's can't determine automatically that source is limited color range.
This results that we watch limited color range without convertion to full range. But we should watch limited range converted to full.
I understand that streaming services long ago could do this to make streaming smaller in size (limited color range take fewer space).
But now, when we have fast internet speeds nearly everywhere it is just ridiculous.
And for blurays I don't understand it at all.
It looks like some conspiracy to mock on people eyes.
Old 4th May 2024, 17:35   #36  |  Link
DTL
" The question is why it is so?"
It is industry standard to keep more quality with limited number of bits (until possible changing to float32 or at least float16 samples values encoding). But 8bit-narrow (limited) works good enough so it is unlikely industry will change to float16/32 any fast.
"This results that we watch limited color range without convertion to full range."
Physical display converts 16..255 Y code values to 0..PHYmax brightness values. So you not lost 236..255 code values encoded in 8bit narrow range. You can test it with 16..255 Y values test pattern. If display clips 236..255 to PHYmax it is broken and need repair or adjustment.
235 code value only marks position of nominal white - not max PHY white. Display hardware may treat 236..255 range very differently (depending on the processor cost and AI algoriphms included) - either continue to track system transfer function or make HDR-expansion of any type.
Old 4th May 2024, 18:29   #37  |  Link
Selur
Selur's Avatar
@Argaricolm: posted in the issue tracker over at GitHub, 10bit does not work in Vapoursynth
Old 4th May 2024, 22:20   #38  |  Link
Argaricolm
8 bit is not about limited color range.
Limited color range is 8 bit 16-235 levels of brightness (220 from 256).
When you view it on tv as it is - nothing is converted to full range.
You see incorrect colors and contrast.
But you have seen it for years now. So you think that it is "normal".
Here is example.
In limited color range there is no 0 and thats why in frames with a lot of black/dark you dont see black. You see only nearly black. This results in fewer contrast. And incorrect colors (because of contrast). For example you should see red color, but you will see light red.
It should do so. But how can it find out that it should?
For example - that batman 2022 video from above is surely limited color range but it does not have any info inside about limited color range. And I'v checked pixels. You can find values 0-15 inside any limited color range video. Its just they are fewer in numbers than should be. So I don't see any easy way for TV to determine - is video with limited color range or not.
Old 4th May 2024, 22:56   #39  |  Link
DTL
"You can find values 0-15 inside any limited color range video"
It is also correct - footroom in narrow range mapping is to hold filter undershoots to display better sharpness (visible in the PHY range above zero). See https://forum.doom9.org/showthread.p...87#post2000687
Old 4th May 2024, 23:38   #40  |  Link
wonkey_monkey
Here is example.
Are you saying all TVs have been getting it wrong since forever?
Because I don't think that is the case.
