Old 15th November 2010, 07:08   #521  |  Link
Alex_080
User of X264
Thanks Sirber for anime profiles ...working great.
Waiting for your next release....with u r new release plz update x264 1766 also.
Is it good use more threads in encoding ..new bencos use threads=8 .....old one use threads=3?
@ckmox
psy_rd=0.00
Is it good to use psy_rd =0.0 for anime encoding?actually i see many encoders use value like 0.4 or 0.6?
Alex_080 is offline   Reply With Quote
Old 15th November 2010, 11:32   #522  |  Link
ckmox
i recommend psy_rd=0.0 because im considering mini-size anime encoding too like if you encountered those 40mb anime rips that has like 250 bitrate only and if you use psy-rd on those kind of rips it will look too noisy so i say psy-rd is just good for video bitrates that is 700 above, and if you notice too psyrd for anime is low at 0.4 or 0.6 instead of 1.0 right? so that means psy-rd is not advisable most of the time in anime atleast imo
ckmox is offline   Reply With Quote
Old 15th November 2010, 13:13   #523  |  Link
Sirber
retired developer
Sirber's Avatar
I'm using ffmpeg, not x264 (directly). I get my build here:
http://ffmpeg.arrozcru.org/autobuilds/
in that time there were only dual cores, now it goes up to 8
Detritus Software
Sirber is offline   Reply With Quote
Old 15th November 2010, 15:42   #524  |  Link
Alex_080
User of X264
i want to use the level option of x264 in FFmpeg and i tried as level=5.1 but it shows parameter error. So can i use this option?
Old 15th November 2010, 15:49   #525  |  Link
Sirber
retired developer
Sirber's Avatar
I have no clue, best ask in this forum.
Detritus Software
Old 15th November 2010, 18:09   #526  |  Link
Alex_080
User of X264
Thanks Sirber i found..here is the script for anime i m using now.
coder=1
flags=+loop
cmp=+chroma
partitions=+parti8x8+parti4x4+partp8x8+partp4x4+partb8x8
me_method=umh
subq=9
me_range=20
level=51
g=300
keyint_min=25
sc_threshold=40
i_qfactor=0.71
b_strategy=1
psy_rd=0.00
aq_mode=2
aq_strength=0.50
qcomp=0.6
qmin=10
qmax=51
qdiff=4
deblockalpha=1
deblockbeta=1
bf=16
refs=9
directpred=3
trellis=2
flags2=+bpyramid+mixed_refs+wpred+dct8x8-fastpskip
wpredp=2
rc_lookahead=50
Old 15th November 2010, 18:14   #527  |  Link
Sirber
retired developer
Sirber's Avatar
beware that bencos's installer will overwrite the preset you modded next time you update.
I'll add a preset named "custom" what will not be overwritten so you can upgrade safely.
Detritus Software
Old 15th November 2010, 18:22   #528  |  Link
Alex_080
User of X264
ok Sirber for now i will make a backup copy of this present.
Are u going to add some filters like denoise,sharpen etc.
Old 15th November 2010, 18:29   #529  |  Link
Sirber
retired developer
Sirber's Avatar
very unlikely.
the source files are supposed to be already filtered.
Detritus Software
Old 15th November 2010, 18:32   #530  |  Link
Alex_080
User of X264
In some files(*.mkv) (now only 3 files shows like this) the video analysis and encoding done perfectly but when audio extraction start this error shows.
it only happen when audio extracting starts but if i do not click on ok then encoding done successfully.Is this my PC problem?
Old 15th November 2010, 18:55   #531  |  Link
Sirber
retired developer
Sirber's Avatar
could be a bug in ffmpeg, try updating the build: http://ffmpeg.arrozcru.org/autobuilds/
you can right-click on the file in the list, "info" in the menu, then you can see what's inside the mkv (codecs, streams, etc).
Detritus Software
Old 16th November 2010, 05:56   #532  |  Link
MajorX
can i use aviscript(.avs) file as input file in new bencos?
MajorX is offline   Reply With Quote
Old 16th November 2010, 06:17   #533  |  Link
Alex_080
User of X264
@MajorX
i m not expert in use of avs file but i do some test with new bencos and i think it support avs file with avisynth plugins.
i use this script..
LoadPlugin("C:\tools\avisynth_plugin\FluxSmooth.dll")
DirectShowSource("C:\Sample.mkv", fps=23.976, audio=true, convertfps=true)
FluxSmoothST(temporal_threshold=7, spatial_threshold=7)
Bencos encode it successfully without any error.But it can't keep the same DAR of output file as in input file.Like the input file have DAR 16:9 but output file have DAR 3:2.
Also there no subtitle in output file.
i try this also
LoadPlugin("C:\tools\ffms\ffms2.dll")
FFVideoSource("C:\Sample].mkv")
video analysis and encoding done correctly but it shows error when audio extraction start..i don't how add audio in this.
Old 16th November 2010, 19:11   #534  |  Link
Sirber
retired developer
Sirber's Avatar
there might not be a release in the coming few days, I have to move a lot of code to make the GUI multi-threaded, and keep the single-threaded part working (the current encoding chain).
Detritus Software
Old 17th November 2010, 01:53   #535  |  Link
Sirber
retired developer
Sirber's Avatar
I managed to run ffmpeg inside a thread, but when I start it with "poUsePipes" ffmpeg hangs and output no text, nor encode. Also, the loop "while oCli.Running" seems not working, the thread gets terminated and the process is still running.
what a pain..
[edit]
http://forum.doom9.org/showthread.ph...22#post1458222
[edit 2]
@ckmox looks like you've been through that lol:
http://forum.lazarus.freepascal.org/...c,10922.0.html
Detritus Software
Old 17th November 2010, 05:56   #536  |  Link
ckmox
what a pain..
ye the horror days, took me like 3 days to run that TThread
just a hint though dont call the main forms TProcess on TThread Execute method/area for example dont do it like this frmMain.oCli.Running instead make a TProcess variable for TThread
one thing i learn is never call frmMain things inside the TThread Execute method/area if you want to call some frmMain parts just make a procedure on TThread and that call Synchronize to it
you can look at the code of cyko on the execute method/area of TThread to know more that i didnt use any frmMain parts on it
if your worried about initializing variables just do it before TThread.Resume command for example the resume command for tthread is part of this procedure (scanThread is the TThread variable in the following)
procedure TfrmMain.btnEnqueueClick(Sender: TObject);
begin
    scanThread := TMyThread.Create(True);
    scanThread.FreeOnTerminate:=True;
    scanThread.venString := '';
    scanThread.x264String := '';
    scanThread.ii:= 0;
    scanThread.strScan := TStringlist.Create;
    scanThread.strScan.AddStrings(lstAdd.Items);
    scanThread.sPro := TProcess.Create(nil);
    scanThread.M := TMemoryStream.Create;
    scanThread.BytesRead := 0;
    scanThread.audioCount := 0;
    scanThread.OnTerminate:=@ScanDone;
    scanThread.Resume;
end;
and ye this question thread of mine is the one help me a lot http://forum.lazarus.freepascal.org/....msg54512.html
i recommend to pay attention more on theo's replies there
EDIT:
this could be helpful too -> http://www.mediafire.com/?9e9g3sbhxxmeeqg
its a program where i practice how to code the TThread named ScanThread
Old 17th November 2010, 13:27   #537  |  Link
Sirber
retired developer
Sirber's Avatar
the thread seems to run fine, the only problem I had is ffmpeg hang if I use "poUsePipes" inside the thread.
Detritus Software
Old 17th November 2010, 17:30   #538  |  Link
Alex_080
User of X264
Can i adjust Display aspect ratio(DAR) in new bencos ....like i want to change 4:3 to 16:9.
Old 17th November 2010, 17:31   #539  |  Link
Sirber
retired developer
Sirber's Avatar
Can i adjust Display aspect ratio(DAR) in new bencos ....like i want change 4:3 to 16:9.
not yet, I'll add the setting.
[edit]
looks like it's the "-aspect" flag, aka "-aspect 4:3" or "-aspect 16:9"
Detritus Software
Old 17th November 2010, 17:50   #540  |  Link
Alex_080
User of X264
ok thanks Sirber i will wait.can i encode a video file that contain no audio track? i do some test and i get some error 'Output file #0 does not contain any stream'.can it mux only video file after encoding video if it not find any audio track?
aac, bencos, gui, webm, x264
