Old 26th November 2007, 16:27   #261  |  Link
Sirber
retired developer
Sirber's Avatar
It's not like you can't reach me by email or PM here.
anyway. I'm almost out of the dev business...
Detritus Software
Sirber is offline   Reply With Quote
Old 26th November 2007, 16:59   #262  |  Link
sillKotscha
what's this for?
sillKotscha's Avatar
hey, jey, jey... no need for excuses or arguments... I just wanted to ask
in other words you don't think you will look forther into that issue, don't you?
too bad... but thanks for your answers
latest mix sets: http://soundcloud.com/sill
sillKotscha is offline   Reply With Quote
Old 26th November 2007, 17:18   #263  |  Link
Sirber
retired developer
Sirber's Avatar
bencos is most likely dead. The IDE works badly under vista and compiled bins don't even run (under vista).
ra6 I dev it once each 3 months, and I don't plan adding more codecs. x264 and AAC is enough for most tasks.
Detritus Software
Old 26th November 2007, 17:22   #264  |  Link
sillKotscha
what's this for?
no, for most users
Old 2nd December 2007, 15:10   #265  |  Link
and-y
@sirber's quote
"bencos is most likely dead..."
"ra6 I dev it once each 3 months"
>_<
lil bit sad to hear it T_T
but i appreciate all of what you give for us...
(thanx a lot, really help me to rip more smaller.)
and maybe I just can say just do what you really pleasant to do ^_^
(cause I think what you made from the bottom of your heart is more important.....)
and-y is offline   Reply With Quote
Old 30th December 2007, 12:23   #266  |  Link
Veterinar
Then why don't you rip off the core with all the logic and without interface, wrap it up in nice package (able to compile) and publish it for download? Somebody might add different interface to it, maybe even commandline.
Veterinar is offline   Reply With Quote
Old 4th January 2008, 19:58   #267  |  Link
JLe2k
hey does anyone know what settings the anime profile on this had or even what settings on real anime 5/6 i think they're the same profile throughout the versions
JLe2k is offline   Reply With Quote
Old 22nd January 2008, 04:30   #268  |  Link
Mgz
I still use RA5 for batch transcoding FRAPS video into XVID
x264/AAC is out of question because I have an old version of Sony Vegas 4.0 (the new version is 500$ or something >.< )
Mgz is offline   Reply With Quote
Old 28th January 2008, 20:46   #269  |  Link
IceManZ
Hi Sirber,
I give a try to RA 6 and I applied the update but RA crashed when MP4Box merged video / audio (=file not found).
If I keep the old version of MP4Box I get a "out of bounds" error.
Is it possible, when you got a few minutes, to check this.
Thanks a lot for all your hard work.
OS : Win XP.
IceManZ is offline   Reply With Quote
Old 28th January 2008, 21:12   #270  |  Link
Sirber
retired developer
Sirber's Avatar
1) This is bencos thread
2) I'm not developing anything anymore.
for your issue, look if all files are there, add the missing ones and retry.
Detritus Software
Old 24th March 2008, 17:15   #271  |  Link
Sirber
retired developer
Sirber's Avatar
Quick update:
* New mencoder, mplayer and mp4box bins
* Recompiled bencos against Lazarus 0.9.24 beta and QT4 framework
* Works under Vista with UAC deactivated (Didn't try with UAC)
http://www.detritus.qc.ca/files/benc...080324-QT4.exe
Detritus Software
Old 24th March 2008, 20:08   #272  |  Link
DarkZell666
aka XaS
DarkZell666's Avatar
I had to download libqt4intf.dll before the latest version you just posted could start :
http://svn.freepascal.org/cgi-bin/vi...&pathrev=13686
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS
DarkZell666 is offline   Reply With Quote
Old 25th March 2008, 02:26   #273  |  Link
Sirber
retired developer
Sirber's Avatar
@DarkZell666
Thanks!!, maybe I had it via Lazarus. Adding it to the setup!
[edit]
Added. Please redownload if needed
Detritus Software
Old 4th April 2008, 13:32   #274  |  Link
krusty999
Can BENCOS suport constant quality encode??
I have a question can BENCOS suport constant quality encode (crf) like MEGUI??
Good work.
krusty999 is offline   Reply With Quote
Old 4th April 2008, 14:08   #275  |  Link
Sirber
retired developer
Sirber's Avatar
Good work.
It could, but it doesn't. It only provide variable bitrate based encoding.
Detritus Software
Old 7th April 2008, 13:04   #276  |  Link
krusty999
Can add Constant Quality Encode? or tell me how can calculate the bitrate to do something like crf(quality 24) encoding.
Old 7th April 2008, 18:55   #277  |  Link
Sirber
retired developer
Sirber's Avatar
Sorry, I'm not adding features that I'm not using.
I can get you a copy of the sources if you want to patch it in.
Detritus Software
Old 9th April 2008, 07:28   #278  |  Link
killerhex
hey sirber are all your programs development dead
killerhex is offline   Reply With Quote
Old 9th April 2008, 14:57   #279  |  Link
Sirber
retired developer
Sirber's Avatar
yes! all of them!
Detritus Software
Old 30th May 2008, 03:41   #280  |  Link
Mgz
<-- still faithful user of RealAnime 5.0 @_@, I fraps a lot and RealAnime 1 click 2-pass XVID enconding no-bs approach saves me a lot of time and HD space . But still I want to upgrade to xvid 1.1.2 :-/ but development is dead, oh well.
so what GUI/program do Bencos/RA users use/move to anyway ?
aac, bencos, gui, webm, x264
