Old 23rd February 2008, 22:30   #1121  |  Link
Shinigami-Sama
Solaris: burnt by the Sun
Shinigami-Sama's Avatar
Originally Posted by molitar View Post
Now if I can only figure out how to get theatermode working on my secondary display
have fun
ATI's menu is a bitch like that
you might have to switch it back and forth a few times before the app realizes it is in theater mode as well..
Originally Posted by benjust View Post
interlacing and telecining should have been but a memory long ago.. unfortunately still just another bizarre weapon in the industries war on image quality.
Shinigami-Sama is offline
Old 23rd February 2008, 22:56   #1122  |  Link
luojs
Wow this is awesome! I am playing a h264 movie with NO CPU USEAGE! DXVA working perfectly using absolutely zilch cpu on my new 512MB Radeon 3870 video card!
Theatermode only works when using Overlay render.
luojs is offline
Old 23rd February 2008, 22:58   #1123  |  Link
Shinigami-Sama
I use it with VRM9 renderless all the time
its just a pain in the ass to get it to kick in
Old 23rd February 2008, 23:07   #1124  |  Link
jhoff80
So I have a bunch of files that result in a blocky mess with DXVA turned on, and I'm not entirely sure why thats the case. I would love if it would work right or just default to software mode for these cases. I uploaded a clip if people here would like to investigate why this is happening: http://download.yousendit.com/D48CFC7E03554E57
This is with an ATI 3870.
Also, I know I've mentioned it a few times already and I hate to sound like a broken record, but I'd really love this as a standalone filter.
jhoff80 is offline
Old 23rd February 2008, 23:58   #1125  |  Link
noee
I believe I have zeroed in on a bug. Please pardon if this has been reported already.
It appears, when using EVR-custom presenter w/Direct3D fullscreen, whenever I seek forward or back, in either DVD or MKV (x264), the CPU usage jumps to around 50-60% and the audio goes out of sync.
I discovered this as I've been trying to get Reclock working right. It doesn't seem to matter if I use Reclock or not and whether I have the ATI CCC running or not. Normal playback CPU utilization (for both ffDshow and the built-in decoder) is below 15%.
I have tried with the other renderers and the problem also exists with VMR9 renderless if I choose Direct3D fullscreen. Perhaps a clue?
I have an ATI HD2600XT running 8.2 CCC and driver. I have my monitor (LG 37" 1080P) set for 1080@24Hz. All sources I'm playing are 23.976fps with either AC3 or DTS audio streams, using Spdifer for pass through.
noee is offline
Old 24th February 2008, 00:48   #1126  |  Link
leeperry
Kid for Today
to get back on the binding options.
if you have a Logitech mouse, you can use this thing, which is a hack of the original XML scripts :
http://www.mstarmetro.net/users/rlowens/uberOptions/
you can bind anything on anything, and for each program separately...and no additional resident app!
works like a treat with MPC HC
leeperry is offline
Old 24th February 2008, 01:39   #1127  |  Link
p0w3rh0u5e
It's really nice to see this great player getting better and better, dxva-support is a great addition. Thank you very much for your hard work.
Just one question, is it planned to add decoders for eac3 and mlp?
p0w3rh0u5e is offline
Old 24th February 2008, 03:03   #1128  |  Link
Shinigami-Sama
as soon as its added to libavcodec it'll get put in
as of now that patch isn't commited so its not ready
Old 24th February 2008, 04:31   #1129  |  Link
molitar
Well I found System Default renderer let's theater mode work. And it is working in more than overlay mixer mode than because saving images work than. So that seems to work fine. I really don't see what use EVR mode is good for because no secondary display works at all with that mode so found it totally useless to my needs and curious why anyone would want to use it?
molitar is offline
Old 24th February 2008, 04:47   #1130  |  Link
samab
Originally Posted by _xxl View Post
Both your 403 and 421 builds were very slow on my very old computer (playing just the ordinary xvid video files). Don't know whether it's because you are building it with older directx sdk (version 32) or not.
MatMaul's 404 build (which was built with sdk 35) is playing normal speed for me with evr custom pres. I get about 10 frames a second with your 403/421 build somehow.
Thanks for all you people with your work.
samab is offline
Old 24th February 2008, 06:27   #1131  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
can we PLEASE release on something other than rapidshare? It's pretty dreadful. Megaupload or any of the other free file hosters are typically much better.
~MiSfit
Blue_MiSfit is offline
Old 24th February 2008, 08:57   #1132  |  Link
ranpha
~MiSfit
http://cid-94cc264fce430b66.skydrive...rc.hc.r421.zip
SkyDrive is much better, and has comparable connectivity too.
ranpha is offline
Old 24th February 2008, 09:00   #1133  |  Link
ACrowley
i ask again...
I cant use any Pan&Scan Mode with MPC HC .
It works perfect with standard MPC.
But i get a Blackscreen with all HC Versions.
The Movie is still playing and i hear the Sound ,but the Picture is Black.
ACrowley is offline
Old 24th February 2008, 13:39   #1134  |  Link
Miryan
Direkt link:
http://dl1.usite.hu/player/Media.Pla...0.11.8.421.zip
or
http://dl2.usite.hu/player/Media.Pla...0.11.8.421.zip
Miryan is offline
Old 24th February 2008, 16:46   #1135  |  Link
_xxl
ffdshow user
_xxl's Avatar
mpc-hc and *.ax r.421:
http://rapidshare.com/files/94552813....r421.zip.html
_xxl is offline
Old 24th February 2008, 17:40   #1136  |  Link
wyrd
wyrd's Avatar
Hi,_xxl
Thanks for new *.ax builds!
mirrored
http://tirnanog.fate.jp/mirror/Misc%...lters.r421.zip
wyrd is offline
Old 24th February 2008, 17:48   #1137  |  Link
molitar
What is the purpose of this .ax build? Is it for those that don't use software like cccp?
molitar is offline
Old 24th February 2008, 21:26   #1138  |  Link
ADude
Originally Posted by Casimir666 View Post
There is no need to import GRF : MPC can read EVO directly if you set-up properly internal/external filters.
Little tips :
- disable AC3/DTS and Mpeg internal filters
- install latest Haali splitter, and enable MPEG TS/PS source
- add all unwanted filters in "External filters" and set "block" radio button
I'm having difficulties with this.
I currently have MPC-HC setup nicely to play .MKV files using Haali and CoreAVC and SPDIFER in the external filters. .AVI files use ffdshow and SPDIFER. VC-1 files using Matroska container player nicely with Haali, WMVdecoder and AC3FILTER, etc.
.EVO defaulted to Zoom Player (since it was not setup in MPC-HC) and played with Haali, WMVdecoder but no sound decoder at all. When I changed the .EVO default to MPC-HC, it played the audio only but no video screen at all.
Thanks for any and all assistance !
PS I don't see "MPEG TS/PS" in any list.
s/w: Vista Home Basic 32bit (no Aero), MPC-HC, EVR Custom Presenter, CoreAVC Pro, ffdshow, SPDIFer
h/w: Antec 2480 case, Gigabyte GA-MA69GM-S2H, 4200+, 2.5gb+512mb, ATI x1250 IGP, MS MCE remote
ADude is offline
Old 24th February 2008, 21:47   #1139  |  Link
DrNein
For Theater Mode (mirroring), typically, enable it for display 1 and leave it in Standard Mode for display 2. With XP, the default renderer is VMR7 windowed and that is also the best (so either leave set to System Default or to be certain set to VMR7 windowed). Old Renderer may result in same but as it varies should be probably be avoided.
Clone mode results may differ but Extended is essentially required for practical purposes when the displays have different resolutions. Also, mirroring is disallowed by BD/HD DVD so the player must be moved to the second display to view there.
Overlay Mixer = quality issues (see film ratings text, for example)
VMR7 (windowed) = good
VMR9 (windowed) = no picture
VMR7 (renderless) = no DxVA, no mirroring
VMR9 (renderless) = no mirroring
Haali's Video Renderer = no DxVA, no mirroring
EVR (Vista / .NET3) = no DxVA, no mirroring (if it even works)
EVER Custom Pres. = no picture
DrNein is offline
Old 24th February 2008, 21:57   #1140  |  Link
ADude
If you look elsewhere in this thread and the Forum, EVR has better picture quality and solves some other problems.
EVR Custom Presenter (available so far only in MPC-HC) solves all problems with tearing, shuddering and other playback anamolies.
Home Theater PCs are used with an HD LCD TV as the main (primary display).
ADude is offline
dxva, h264, home cinema, media player classic, mpc-hc
