Old 13th August 2009, 22:00   #9121  |  Link
ikarad
@ikarad,
There is no point in repeating your bug reports over and over again. You will just have to wait and be patient.
You can monitor the changelog here:
http://mpc-hc.svn.sourceforge.net/vi...c-hc/?view=log
If the log does not mention anything about those bugs, then it means they have not yet been fixed.
I repeat just because in one of the problem there is a 7 GB sample and I have uploaded this sample two months ago. although, soon, files will disappeared. And to upload this sample, it's two weeks with my connection.
And with this problem I can't use a little sample.
ikarad is offline
Old 13th August 2009, 22:50   #9122  |  Link
leeperry
Kid for Today
you can upload files up to 2 gigs on this host: http://www.depositfiles.com/en/#
but a sample shouldn't be more than 100mb IMHO
leeperry is offline
Old 13th August 2009, 23:34   #9123  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by Keiyakusha View Post
This is a dialog "Properties -> Mediainfo"? If so, I already saw this in new builds since xvidvideo.ru went on vacation...
I made support long time ago - but commit to svn only now;
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline
Old 14th August 2009, 00:06   #9124  |  Link
Aleksoid1978
1230:
http://aleksoid.tosei.ru/Dist/MPCHC_1230_x86.7z
http://aleksoid.tosei.ru/Dist/MPCHC_1230_x64.7z
standalone filters:
http://aleksoid.tosei.ru/Dist/Filter...rs_1230_x86.7z
http://aleksoid.tosei.ru/Dist/Filter...rs_1230_x64.7z
changelog:
Fixed : broken "Lauch files in fullscreen" in rev 1222;
Fix : crash on malformed AAC streams;
ADD : Support MediaInfo.dll;
Old 14th August 2009, 02:44   #9125  |  Link
hdboy
There's a change in the way open file works that I think should be reverted to the old behavior.
When I select File > Open file..., if I select a file from the recent list and click Browse, MPC used to open the directory that file resides in. e.g., if I choose a file called "D:\video\home\cat.avi" from the recent drop down list, then when I click Browse it will open at the d:\video\home\ directory. This behavior makes sense.
However, now MPC always opens at the last directory that I opened a file from. Since it's always possible to go to the last used directory by File > Quick open file..., I think this behavior is not only redundant but takes away a functionality that is both convenient and logical. I'd like to see this revert to the previous behavior. Hope this makes sense.
Btw, I am using windows 7. I don't know if this is a windows 7 issue or a change in MPC.
hdboy is offline
Old 14th August 2009, 03:34   #9126  |  Link
stax76
Might be related to Win 7, I noticed different file browser behavior in my applications switching from XP to Win 7. Why not try a older MPC build to find out?
stax76 is offline
Old 14th August 2009, 04:25   #9127  |  Link
Aleksoid1978
Windows rememer path for OPenFileDialog for current app, that's all.
MPCHC don't remember path for open files.
Old 14th August 2009, 07:14   #9128  |  Link
Scoty
How can i use the standalone filters?
Scoty is offline
Old 14th August 2009, 07:18   #9129  |  Link
Aleksoid1978
regsvr32 <filename.ax>
Old 14th August 2009, 07:21   #9130  |  Link
Scoty
Thank you.
Scoty is offline
Old 14th August 2009, 07:23   #9131  |  Link
_xxl
ffdshow user
_xxl's Avatar
Should we add mediainfo lib to mpc-hc?
_xxl is offline
Old 14th August 2009, 07:28   #9132  |  Link
tetsuo55
MPC-HC Project Manager
i think we should
tetsuo55 is offline
Old 14th August 2009, 07:53   #9133  |  Link
Scoty
Sync video ok, DXVA on - but green atrefact on screen;
I have the same Problem with all 12xx Builds. With 11xx Builds working fine.
Scoty is offline
Old 14th August 2009, 09:10   #9134  |  Link
ikarad
thanks but it's the only solution to show the problem with subtitle.
ikarad is offline
Old 14th August 2009, 09:12   #9135  |  Link
tetsuo55
Casimir has your sample already. (the first time you posted it)
tetsuo55 is offline
Old 14th August 2009, 10:00   #9136  |  Link
click2
aka mappy
click2's Avatar
MPC-hc seems to display my avisynth error message incorrectly. The problem isn't present in WMP or graphedit.
Here's more details (crosspost).
<Dark_Shikari> its linux, I don't really care :: <pengvado> #x264 is not for dancing.
click2 is offline
Old 14th August 2009, 11:26   #9137  |  Link
clsid
Instead of adding the 1 MB mediainfo.dll, maybe it could be linked statically? Then it would add only a few hundred KB.
clsid is offline
Old 14th August 2009, 11:48   #9138  |  Link
ikarad
thanks
ikarad is offline
Old 14th August 2009, 12:45   #9139  |  Link
Aleksoid1978
It's bad idea. As now - you can install MediaInfo.dll from developers site(it's copy to %WINDIR%\System32) and don't need in MPC folder. if MediaInfo.dll update - copy and all.
If link static - need add many source to project, and update sometimes.
Old 14th August 2009, 13:50   #9140  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Doesn't make sense to me. In this case, why not do that for all internal libraries ? MediaInfo library needs zlib (already in mpc-hc project) and zenlib. That's all. and I'm pretty sure that some internal libs used by mpc-hc are bigger than mediainfo.
Kurtnoise is offline
dxva, h264, home cinema, media player classic, mpc-hc
