Old 1st June 2009, 10:12   #8121  |  Link
hoborg
Originally Posted by tetsuo55 View Post
Which bug report is that on the tracker?
I am not sure if it is listet in tracker...
Original post:
http://forum.doom9.org/showthread.ph...59#post1276859
Working machine: Win10x64 + Intel Skull Canyon
My HTPC.
How to start with Bitcoin
hoborg is offline
Old 1st June 2009, 11:02   #8122  |  Link
tetsuo55
MPC-HC Project Manager
Originally Posted by Kurtnoise View Post
Here is a patch to handle AC3-in-MP4 files created by Nero Digital...I hope NG will update their tools to be compliant within the standard soon. Still, Nero 9 uses this material. Samples for testing : file 1 | file 2.
Note: I know that several constants are not used yet but might be useful for future patches.
Thanks, we can use every patch you can think off with regards to splitter problems
Original post:
i can reproduce with the latest version 1137, please add this issue to the tracker.
I hope another ffmpeg updates fixes it.
tetsuo55 is offline
Old 1st June 2009, 12:04   #8123  |  Link
hoborg
I can reproduce with the latest version 1137, please add this issue to the tracker.
Added.
http://sourceforge.net/tracker/?func...61&atid=854651
My HTPC.
hoborg is offline
Old 1st June 2009, 19:41   #8124  |  Link
73ChargerFan
73ChargerFan's Avatar
We now have 78 bugs left ( a couple unconfirmed that might still get closed as cannot reproduce )
I know of a show stopping bug, but haven't thought about it for a long time, and am surprised that it isn't already in the bug tracker.
dts 1536 over spdif stutters
My work around is to use spdifer. I'll test & verify with latest build before adding to the bug tracker. I'm using XP.
73ChargerFan is offline
Old 1st June 2009, 23:34   #8125  |  Link
Mixer73
I can't believe the love shown by Beliyaal, Tetsuo55, Casimir, Alexins... Sorry if I have forgotten a regular contributor.
I think I've seen 100 builds since I started really using MPC-HC, as a former Zplayer and KMplayer user, I can now say that with the right settings MPC-HC gives perfect playback for me when its configured right.
Awesome job devs, You deserve a pat on the back for your commitment to a sometimes thankless job.
On another note is the xvidvideo.ru site down?
Mixer73 is offline
Old 1st June 2009, 23:37   #8126  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Xvidvideo.ru is down, here latest 1141 build :
http://aleksoid.tosei.ru/mpc_x86_1141.7z
http://aleksoid.tosei.ru/mpc_x64_1141.7z
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline
Old 2nd June 2009, 00:23   #8127  |  Link
gngn
the hedgehog
gngn's Avatar
thanks for providing this version. i was curious about the improvment with DXVA.
now files with 12-15 ReFrames will have DXVA with XP (SD and HD). only files with Reframes 16 will freeze.
Athlonx2@2,9Ghz,2G DDRAM2@800Mhz,WinXPSP3 x86,GF8600GTS-256M,Nvidiadrivers 295.73
latest MPC-HC (MVS2010 SP1, GCC 4.7.1)
VMR9renderless+VMR9MixerMode+YUVMixing,VSync+AccurateVSync,all GPUflushes on
gngn is offline
Old 2nd June 2009, 00:36   #8128  |  Link
Aleksoid1978
What Output use ??? Under XP only in "system" no limit on ReFrames.
Old 2nd June 2009, 00:45   #8129  |  Link
allak
Regarding bug:
If I understand the report correctly, I am unable to reproduce.
Using the latest MKVtoolnix I've muxed a 16:9 avi to MKV, forcing the aspect ratio to 4:3 in the "Format Specific Option" tab for the video track.
As expected, the resulting mkv file is played by MPC-HC with the video squeezed.
Maybe it was simply a badly muxed file, or may some other patch has also fixed this problem (the bug is pretty old, august 2008, with no followup).
Anyway, we do not have a sample and we can't ask the anonymous submitter: if nobody else can reproduce I think the bug could be closed.
tested with the madVR, Haali, ERV and VMR9 rederers
allak is offline
Old 2nd June 2009, 01:17   #8130  |  Link
gngn
the hedgehog
gngn's Avatar
on XP MPC-HC couldn't decode files with more than 11 ReFrames. it worked with CoreAVC (but even CoreAVC turns to software-mode on files with RF=16)
it only works now after Casimir666's changes in rev1141. so the DXVA limitations for XP inside MPC could be removed now.
but there is a problem now for me with some "more demanding" 1080p files: the frame rate judder is sometimes chaotic probably depending on the scene, and if i select the BicubicResizer instead of the BilinealPS2.0 then it gets even worse, and even worser if i enable some Shaders (YV12Chroma + Sharpencomplex2).
rev1136:
rev1141:
sample here
as a sidenote: before 1141 it was possible to have more than 1 instance of MPC-HC and DXVA, now MPC falls back to the ffmpeg on the second instance
edit: some of the SD anime encodes i have will get older frames inbetween on DXVA playback, and then video freezes. audio continues. in this sample video freezes at 0:17 sec
i hope that it's not my graphics-card giving up on me )
gngn is offline
Old 2nd June 2009, 03:07   #8131  |  Link
malados
Originally Posted by malados View Post
I have one question about the DXVA decode and display.
When the DisplayNextFrame() function is called, it will search one nPicIndex to GetDeliveryBuffer and m_pAMVideoAccelerator->DisplayFrame to display the frame.
After display, the flag bUsed will set to 0 if this frame will not be reference by another frame.
So, the Index may be using for next decode buffer immediately.
The "decoded" frame will be updated on screen immediately caused by the same buffer index "nPicIndex" as previous display frame.
What is the problem? Does someone have any idea?
Is any one have idea about the buffer question?
malados is offline
Old 2nd June 2009, 09:29   #8132  |  Link
konsulat
I added this bug to the tracker
Thanks for fixing it. Now all my HD videos with 16 Reframes play without freezing.
With SD video encodes (less than 1280x720) and 16 Reframes DXVA is not active. But there is one rare occasion when SD videos with 16 Reframes use DXVA and video freezes - linked files.
When I start the main file and it is encoded with 10 Reframes for example MPC-HC uses DXVA. Linked file is encoded with 16 Reframes and when MPC-HC plays it at some frame video freezes. If I play the linked file separately, MPC-HC won't freeze because it doesn't use DXVA. It's the same as the bug above but if it's needed to add another bug to the tracker I'll do it.
konsulat is offline
Old 2nd June 2009, 13:01   #8133  |  Link
Aleksoid1978
I make test version - http://aleksoid.tosei.ru/mplayerc_1143_test.7z - work AR, fast move/switch between monitors, window and fullscreen mode.
Old 2nd June 2009, 13:17   #8134  |  Link
tetsuo55
Here is a possible solution for the various crashes/corruptions related to multi-screen problems and UAc prompts ETC..
Originally Posted by byuu
I also got the video to stay up after ctrl+alt+delete. Really, this was ridiculous. DirectDraw was a simple surface->Restore() call, but Direct3D was a nightmare. Totally different ways to recover it based on surface vs texture mode, and you basically have to destroy every last resource, then call device->Reset(), the re-initialize it all again. I wrapped all the code I could to avoid code duplication. And it turns out just resetting isn't enough for the issue with textures when you resize windows, so that still re-initializes everything. Oh, and you can't just re-initialize when you lose the D3D device: it'll actually crash the application. You have to reset the device before you can use it again, period. And when you lose the device, in order to try and recover it, you have to release all the old resources first, so you have to then write protection checks at the top of every user-visible function to make sure they don't try and access resources you released while trying to restore. Because you see, it won't restore when you're in the ctrl+alt+delete menu, it'll keep failing and you have to keep trying over and over until it works. And you can't sleep once you detect device loss, because then the audio will hang.
Originally Posted by kode54
byuu wrote:
FitzRoy wrote:
Powering off a game causes the audio to stutter forever. Same thing that happens when you're dragging the title bar.
byuu wrote:
I can fix unload, but the title bar thing is a limitation of Windows deadlocking userspace code when you click on it. Linux and OS X don't have that problem.
You can try muting between WM_(ENTER|EXIT)SIZEMOVE messages, assuming you can intercept them.
tetsuo55 is offline
Old 2nd June 2009, 14:04   #8135  |  Link
tetsuo55
I mentioned updating the baseclasses before.
The newest release can be found here:http://www.microsoft.com/downloads/d...displaylang=en
On 27-4-2009 MS said they would not be updating the directshow baseclass redist dll's, this probably also means that they won't be updating the baseclasses at all. However they could still update them through windows update (redist is no longer required with XP sp2 or newer)
I guess this is a logical step seeing as all the focus is on media foundation.
tetsuo55 is offline
Old 2nd June 2009, 14:32   #8136  |  Link
tetsuo55
I've noticed that some parts of MPC-HC and more often external filters require admin rights to work correctly(At least on windows 7).
(See also this related bug report http://sourceforge.net/tracker/?func...61&atid=854651)
Here is a MS tool that can test applications for problems running as a limited user: http://blogs.msdn.com/aaron_margosis...d-preview.aspx
Basically MPC-HC(or the external filters) should ask for admin rights only when really needed. (prompt uac on action that requires admin rights if not already running with admin rights)
EDIT:
Here is a document explaining the admin rights only when needed functionality
http://www.codeproject.com/KB/vista-...Elevation.aspx
tetsuo55 is offline
Old 2nd June 2009, 14:44   #8137  |  Link
cca
Anime Otaku
Revision 1141 seems to cause problems with DXVA in certain files. Example follows:
As you can see in this screenshot, playback is not smooth but the video stutters. The same exact file has no such problem with revision 1137.
Unfortunately I don't know how the file was encoded, it is a freely available anime fansub. The problem seen is 100% reproducable, happens every time with revision 1141 with this video, never happens with rev. 1137.
AMD FX8350 on Gigabyte GA-970A-D3 / 8192 MB DDR3-1600 SDRAM / AMD R9 285 with Catalyst 1.5.9.1/ Asus Xonar D2X / Windows 10 pro 64bit
cca is offline
Old 2nd June 2009, 14:49   #8138  |  Link
tetsuo55
We need a sample.... (you will have to cut it). Also please post a media info log in [ code ] [ / code ]
tetsuo55 is offline
Old 2nd June 2009, 15:01   #8139  |  Link
chiyuwang
H264 with DXVA crash?
when using VMR9 renderer it crashes to dxvadecoder.cpp line416
chiyuwang is offline
Old 2nd June 2009, 15:16   #8140  |  Link
cca
Anime Otaku
Unfortunately I do not how to cut matroska files, nor what a media info log is. I don't produce videos, only play them. I assume it cannot be too hard, but I got no clue atm.
cca is offline
dxva, h264, home cinema, media player classic, mpc-hc
