5th December 2005, 00:59 | #282 | Link |
李姗倩 Lǐ Shān Qiàn
Send "Now Playing" information to mIRC through GTSdll
Dear Gabest:
This feature is cool but too powerful sending the info to every single channel you are in, almost flooding. How about sending the info only to the 'active' chanel (the window that gets focus), especially when you type /mpcvid manually in a specific chan? |
5th December 2005, 01:26 | #283 | Link | |
Be Brave!
5th December 2005, 06:17 | #286 | Link | |
Be Brave!
5th December 2005, 12:19 | #287 | Link | |
a good news, this is the answer from Gabest about our problem: "Yes, it's really bad, but I made the fixes already. There's also going to be a lot faster two pass bicubic resizer in the next version. |
5th December 2005, 13:43 | #288 | Link |
Maybe this is a stupid question, but somehow with earlier versions I could see the specific bitrate of a videofile in the properties (Shift+F10).
Now I see information like this: "XVID 640x352 25.00fps". Am I missing something here, because I've also tried previous version but now suddenly they too don't show me a bitrate value anymore but only fps. Is there some setting/tweak which I missed or something? Or maybe Gabest would be so kind to make it display like this "XVID 640x352 25.00fps 1606kbps" for instance in the next MPC update?
My hobby website |
5th December 2005, 14:22 | #290 | Link |
Not what I meaned exactly. I had it displayed in properties (Shift+F10) with some previous versions and now it's gone :s.
My hobby website |
7th December 2005, 02:12 | #291 | Link |
Works for me (6.4.8.7).
What doesn't work, however, is that when I downloaded the X3 HD trailer from Apple's site and changed the extension to .mp4, there's no sound in MPC. Here's what I get: Haali's Matroska splitter works fine (when I disable the built-in splitter in MPC). |
7th December 2005, 10:31 | #292 | Link |
With those QuickTime trailers I noticed this too. Somehow the integrated MP4 Splitter isn't capable of splitting AVC1 together with AAC, because the Elecard MP4 Demultiplexer (and I guess Haali as you say) have no problem rendering these trailers.
My hobby website |
7th December 2005, 14:11 | #294 | Link |
Life's clearer in 4K UHD
Quite honestly, I don't think changing the .MOV file extension to .MP4 is a sensible thing to do anyway.
If you want force MediaPlayer Classic to play .MOV files using a "direct-show" filter, you should really be visiting and changing these MPC options: - ..........Not that it will cure the AAC audio issue either! Or force YAMB to de-mux/re-mux the streams within the .MOV container to the .MP4 container! Cheers
7th December 2005, 19:22 | #295 | Link | |
you cant create a mp4 file by renaming the extension of a mov file
7th December 2005, 23:29 | #297 | Link | |
Performance of Windows Quicktime with HDTV Content is just ridiculously slow, sometimes only around 10 fps! Playback with ffdshow (when renamed to mp4) plays the same file very smooth and the CPU is only at 60-80 %... If I remember right, the Makers of Quicktime Alternative gave the tip to use Haali Media Splitter + rename to mp4 in order to watch HDTV AVC Movs. I think a lot of people dont really care if renaming movs to mp4 is "right", it's simply just about beeing able to watch those damn files if you happen to get one of those (normally I try to avoid movs as much as possible). It's ok that this "trick" still does not work with internal mp4 splitter, but nevertheless I think it would be great if it would work someday, even if renaming movs to mp4 is "evil" because it is not "the way it was meant to play". Edit: Another way to play those movs with realistic speed is to use VLC. Edit2: Ah, been to slow VLC is great, just its UI is awfull, I really like that of MPC... Last edited by Stebs; 7th December 2005 at 23:36. |
8th December 2005, 14:59 | #299 | Link | |
you dont need to rename to .mp4 for getting haali to work. haali supports .mov files (with .mov extension) no need for renaming
8th December 2005, 16:02 | #300 | Link |
Hmm, but how is it possible then to let Quicktime Alternative play normal movs and let AVC movs be played by ffdshow (since they are too slow with Quicktime)? - Would be glad if this is somehow possible in MPC without the renaming trick...
media player classic |
