Old 12th December 2018, 04:33   #261  |  Link
asarian
Originally Posted by videoh View Post
I like to remind people to look at the CPU utilization too, because savings can be applied to CPU things, especially encoding.
Consider my following script:
import vapoursynth as vs
core = vs.get_core ()
core.max_cache_size = 8192
core.avs.LoadPlugin ("C:/Program Files (x86)/dgdecnv/x64 Binaries/DGDecodeNV.dll")
vid = core.avs.DGSource (r'i:\jobs\inter.dgi', resize_w=1920, resize_h=1080, fulldepth=True)
vid = core.dghdrtosdr.DGHDRtoSDR (clip=vid, fulldepth=False)
vid = core.avs.DGDenoise (vid, strength=0.12, searchw=9)
vid.set_output ()
The typical CPU-utilization for a job like this is 99% CPU (for the x264 process), and about 0.3% for vspipe (YAY GPU!)
On a non-GPU accelerated jon, CPU saturation for the vspipe process is around 50% (with haf.QTGMC). So, yeah, whatever can be done in GPU, I'll take it!
Gorgeous, delicious, deculture!
asarian is offline   Reply With Quote
Old 12th December 2018, 05:18   #262  |  Link
videoh
Useful n00b
Have a look at DGBob() and PVBob() instead of QTGMC for deinterlacing if you are after blazing speed. Decomb is also implemented for GPU (DGTelecide and DGDecimate).
Maybe getting OT for this thread.
Old 10th January 2019, 07:51   #263  |  Link
asarian
You may like this one as it is GPU accelerated. Apply it after resizing on the GPU (if needed) for maximum performance.
I'm loving it!
I noticed, however, that sometimes DGHDRtoSDR still leaves things too washed out, as it were. See: https://1drv.ms/u/s!AhSxhQ9g_mrMlEJQ6vC4Z8ExAKlg
Those are stills from the movie Divergent. The overlapped image (on the right, with the black bars) is from the original blu-ray; the underlying, big image is what DGHDRtoSDR produced (with default values).
In Photoshop, I needed +48 contrast to have it look kinda like the blu-ray. Sadly, I found no contrast parameter for DGHDRtoSDR (brightness didn't seem to affect much of anything). Is there a way to achieve this?
EDIT: 'what DGHDRtoSDR produced' from the UHD source, of course.
Old 10th January 2019, 19:55   #264  |  Link
videoh
Useful n00b
Use Tweak() in your Avisynth script.
Old 10th January 2019, 21:10   #265  |  Link
asarian
Thanks. I see it's part of havsfunc itself.
Old 15th February 2019, 10:43   #266  |  Link
RainyDog
Is it possible to use fmtconv to resize and crop together?
For example, in avisynth you can the below script when the exact crop is a row of 21 black pixels at both the top and bottom to avoid either overcropping or undercropping by 2 pixels.
Spline36Resize(1920, 1038, 0, 21, -0, -21)
RainyDog is offline   Reply With Quote
Old 15th February 2019, 10:50   #267  |  Link
sneaker_ger
See documentation about "resample" "sx", "sy", "sw", "sh" parameters.
sx, sy
Coordinate of the top-left corner of the picture sub-area used as source for the resizing. They can be fractional. If negative, the picture is extended by replicating the left pixel column.
These parameters are arrays, so it’s possible to specify a different value for each plane. The last value is used for the unspecified planes. The coordinates are always related to the pixel dimensions, you don’t need to scale them with the chroma subsampling.
sw, sh
Size in pixels of the sub-area to resize. They can be fractional. If 0, the area has the same size as the source clip. If negative, they define coordinates relative to the bottom-right corner, in a Crop-like manner. These parameters are arrays like sx and sy.
Old 21st February 2019, 22:38   #268  |  Link
zorr
Originally Posted by Wolfberry View Post
If you are using the dll from the official release, I will recommend to use the one from ChaosKing's FATPACK or the one in my signature as it is compiled with a newer compiler and might save you from random crashes.
I'm using the FATPACK version but fmtconv.dll is dated March 2016 and has the exact same date as the official version. Is the more recent (and hopefully less buggy) version still available somewhere?
zorr is offline   Reply With Quote
Old 22nd February 2019, 09:10   #269  |  Link
asarian
I'm using the one Wolfberry linked to (his own version), but the link doesn't seem valid any more. Sad, because that one is very stable.
Old 23rd February 2019, 01:40   #270  |  Link
zorr
Could you share the file? It could be included in the next FATPACK.
Old 23rd February 2019, 02:53   #271  |  Link
asarian
Here it is: fmtconv.dll
It's for 64-bit, btw.
Old 23rd February 2019, 02:58   #272  |  Link
poisondeathray
wolfberry has 3 public shared fmtconv versions, which one are you linking to? or is it a different one ?
https://drive.google.com/drive/folde...mHKYLzO3elemlC
Old 23rd February 2019, 10:19   #273  |  Link
asarian
If I recall correctly, he had a separate vapoursynth directory there (which I couldn't find any more earlier either). The fmtconv version I took was dated 8 Dec 2018 (which I don't see any more either). Said directory had things like a new libdfttest too.
Old 23rd February 2019, 20:33   #274  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
A warning, as people still seem to be posting directly to threads and may not be aware:
It appears that the forum may have been hacked. There is a suspicious "test" announcement, apparently from tebasuna51 (but probably not), parts of the forum are not working, and there appear to be some malicious javascript files.
I'm not speaking in any official capacity here, but I would recommend, at the very least, NOT entering your password anywhere on Doom9 for the time being.
Please refer to this post: https://forum.doom9.org/showthread.p...wpost&t=176128
wonkey_monkey is offline   Reply With Quote
Old 27th February 2019, 19:43   #275  |  Link
asarian
The guy that did speak in an official capacity ('Swede'), is he legit?! He has locked his announcement, so I can't react, but suggests ppl change their password... which would be an ideal hack (as you need to enter your old password on the form there too) if it's illegit.
Old 27th February 2019, 20:23   #276  |  Link
videoh
Useful n00b
Swede is legit.
Old 27th February 2019, 21:39   #277  |  Link
asarian
Swede is legit.
Puts my mind at ease. Thanks.
Old 4th October 2019, 17:50   #278  |  Link
groucho86
Hi everyone,
Just opened up an issue on fmtconv's github, wondering if anyone had any insight here.
I have a SGamut3.Cine Linear EXR. It seems like the Linear to Slog3 conversion is clipping in the highlights.
import muvsfunc
core = vs.get_core()
input_path = 'source_sgamut
c = core.imwri.Read(input_path,float_output=True)
c = core.fmtc.transfer (clip=c, transs='linear', transd='slog3')
c.set_output()
Test material is here:
https://github.com/EleonoreMizo/fmtc...o_slog3_tb.zip
Includes:
source_sgamut3cine_linear.exr <-- source file
resolve_delinearized.tif <-- expected result
vs_delinearized.png <-- fmtconv result
groucho86 is offline   Reply With Quote
Old 4th October 2019, 19:14   #279  |  Link
age
Yes it looks so
import muvsfunc
#c = core.std.Expr(clips=[c], expr="  x 0.9 *")
c = core.std.Expr(clips=[c], expr="  x  0.01125000 >= x 0.01 +  0.19 / log 10 log / 261.5 * 420 + 1023 / 171.2102946929  95 -   x *   0.01125000  95 + /  1023 / ?")
c.set_output()
Not sure if the resolve result is right either, maybe there is need to scaling from linear to reflection multiply by 0.9
https://github.com/videovillage/Latt...sues/issues/17
https://pro.sony/s3/cms-static-conte...7494271406.pdf
age is offline   Reply With Quote
Old 4th October 2019, 20:27   #280  |  Link
groucho86
Thanks age! Your expr matches well to the DCTL I am using in Resolve. The 0.9 does not seem relevant in this case.
Any idea why fmtconv would be clipping? I looked at TransOpSLog3.cpp and nothing's jumping out at me. Maybe I'm not looking in the right place.
