Old 22nd December 2021, 10:26   #21  |  Link
Dogway
The results looks good!
I didn't know it was all for Gibbs noise, in that case you don't want to touch edges but just right outside them. Normally edge masks will have their center at the gradient change, that means half the edge mask will occupy the edge itself. FlatMask() is very robust so what you can do is subtract the edge mask with FlatMask's ridge mask.
Example:
a=ex_edge("qprewitt")#~ .ex_expand()
b=flatmask()
ex_makediff(a,b,dif=false)
I updated the filter with new args so now you can tune the mask gain (to convert from ridge to a proper flat mask) and low cutoff. It's also faster since I changed the derivatives to custom ones and changed defaults.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 22nd December 2021, 14:49   #22  |  Link
Blankmedia
Nice, I'll try that snippet and your new flatmask!
It wasn't all about Gibbs Noise, but the mask at first picked up a bit to much of it, so it was protecting it. (if I understand correctly, i.e the thin parallel line).
Here's a sample, it encoded at 1.2fps with that command :
avs4x26x64 --x26x-binary x265 --preset veryslow --profile main10 --merange 44 --no-rect --no-am --no-sao --aq-mode 1 --aq-strength 1.0 --rd 4 --psy-rd 1.6 --psy-rdoq 5.0 --rdoq-level 1 --qcomp 0.75 --rdpenalty 1 --tu-inter-depth 2 --tu-intra-depth 2 --ctu 32 --max-tu-size 16 --input-depth 16 --dither --crf 22 --pools 4 --colormatrix "bt709" --colorprim "bt709" --transfer "bt709" --videoformat 2 --sar 1:1 -o "output.265" "input.avs"
https://mega.nz/file/hl4mlLDS#hPe987...qHUZYZD44mqtDI
Blankmedia is offline   Reply With Quote
Old 22nd June 2022, 07:20   #23  |  Link
madey83
Originally Posted by Blankmedia View Post
Thanks Dogway I used your code and it's amazing!
Also I added a bit of a luma mask (thanks again) and a debanding call after your cleanup. I made 2 Hqderingmod call to reduce some parallel lines, but I'm not sure yet if I' gonna keep it.
It seems to give consistent result :
src = FFMS2()
src.HQderingmod(mrad=2,minp = 2 , nrmode =0, sharp = 0, show=False).HQderingmod(mrad=2,minp = 2 , nrmode =3, sharp = 0, show=False)
a = last
ex_boxblur(0,1,mode="mean")
turnright()
ex_median("verticalS")
turnleft()
ex_median("IQM")
neo_f3kdb(5,preset="very high",grainy=0, grainc=0, blur_first=true, sample_mode=4)
# Add lumamask to get dark haris and shoes and stuff, also limit texture degradation in dark area
lumen = lumamask(b=00,w=50, invert=True,uv=128).Santiag().ex_inflate(1,uv=128).Converttoy()
lumen = lumen.Levels(40,0.7,240,0,255)
# Valley Mask
dana = FlatMask(1)
# Add regular edge mask
a=a.ex_edge("qprewitt").Converttoy()
emask = dana.ex_lutxy(a,"x dup * 0.1 * y + 0.5 *")
#~ emask = ex_logic(emask, lumen, "or") ## create artefact
emask = emask.ex_lutxy(lumen,"y x > y x ?")
# Clean up
emask.ex_smooth(2,sharp=true)
This is my whole script so far, but it needs tuning a bit. I went way over board with a lot of things.
FFMS2(chemin)
RoboCrop(LeftAdd=2, TopAdd=2, RightAdd=2,  BotAdd =2, align=True)
fmtc_bitdepth(bits=32)
fmtc_resample(css="444", fulls=False, fulld=True)
fmtc_matrix(mats="601", matd="709", fulls=True, fulld=True)
fmtc_matrix(mat="709", fulls=True, fulld=False, col_fam="YUV")
fmtc_resample (css="420")
src16 = fmtc_bitdepth(bits=16, dmode=8)
fmtc_bitdepth(bits=8, dmode=8)
src = last
turnright()
turnleft()
ex_median("IQM")
# Valley Mask
dana = FlatMask(1)
a=src.ex_edge("qprewitt").Converttoy()
# Clean up
emask = emask.ex_smooth(2,sharp=true)
emask16 = emask.fmtc_bitdepth(bits=16)
src16= src16.GibbsNoiseBlock(mode_RG=26)
sharp0 = src16.NonlinUSM(z=3, pow=1.1, str=0.25, rad=9).mergechroma(src16)
sup1   = src16.MSuper(pel=2,sharp=2)
sup2   = sharp0.MSuper(pel=2,sharp=2,levels=1)
bv1    = sup1.MAnalyse(isb=true, delta=1)
fv1    = sup1.MAnalyse(isb=false,delta=1)
bv2    = sup1.MAnalyse(isb=true, delta=2)
fv2    = sup1.MAnalyse(isb=false,delta=2)
sharpy = src16.MDegrain2(sup2,bv1,fv1,bv2,fv2)
denoised = src16.GibbsNoiseBlock(mode_RG=26).minideen(radius=1).Halobuster(h=12)
denoised  = denoised.TemporalDegrain2(degrainTR=1, grainLevel=1, postFFT=0, postTR=1, postSigma=1.0, postDither=-1, postMix=0, extraSharp=True, fftThreads=1, debug=false)
ex_merge(denoised, sharpy, emask16,true).maa2()
DFMDeRainbow(maskthresh=12)
EDI_RPow2(4,CShift="Spline64Resize",FWidth=960,FHeight=720, nsize=0, nns=3, qual=2, etype=1, taps=4)
emask16 = emask16.spline64resize(960,720)
source = last
sharp0 = source.mt_adddiff(mt_makediff(source,source.removegrain(4)),U=2,V=2) # "median sharpen" (won't create halos on its own, IF the source is halo-free)
sup1   = source.MSuper(pel=2,sharp=2)
bc1    = source.MCompensate(sup2,bv1,thSAD=500)  # using the super clip from the median-sharpener, to provide
fc1    = source.MCompensate(sup2,fv1,thSAD=500)  # more headroom for the limiting process
max    = mt_logic(bc1,fc1,"max").mt_logic(source,"max")
min    = mt_logic(bc1,fc1,"min").mt_logic(source,"min")
sharp1 = source.LSFmod(preset="slow", strength=200, smode=5, edgemode=1).CAS(0.5).mergechroma(last) # chroma sharpen usually is unadvantageous
sharpy2 = sharp1.mt_clamp(max,min,0,0,U=2,V=2).FastLineDarkenMOD4(strength=75, prot=60, luma_cap=190, threshold=4, thinning=1).FastLineDarkenMOD4(strength=75, prot=60, luma_cap=190, threshold=4, thinning=1)
#~ shapy2
ex_merge(source, sharpy2, emask16,true).maa2()
emask16 = emask16.ex_inpand(1,"plus",thres=128)
deh = source.FineDehalo(rx=2.5, ry=2.5, thmi=80, thma=128, thlimi=50, thlima=100, darkstr=0.3, brightstr=1.0, showmask=0, contra=0.3, excl=true)
ex_merge(deh, last, emask16,true)
w=656
h=480
fr=44
a1 = src16.Trim(fr, fr).Spline64Resize(w,h).Subtitle("Source frame" + String(fr))
a2 = emask16.Trim(fr, fr).Spline64Resize(w,h).Subtitle("Mask frame" + String(fr)).ConvertToYUV420()
a3 = last.Trim(fr, fr).Spline64Resize(w,h).Subtitle("Result frame" + String(fr))
ligne1 = Stackhorizontal(a1, a3, a2)
fr=77
ligne2 = Stackhorizontal(a1, a3, a2)
fr=5000
ligne3 = Stackhorizontal(a1, a3, a2)
fr=10000
ligne4 = Stackhorizontal(a1, a3, a2)
fr=15000
ligne5 = Stackhorizontal(a1, a3, a2)
fr=20000
ligne6 = Stackhorizontal(a1, a3, a2)
fr=25000
ligne7 = Stackhorizontal(a1, a3, a2)
fr=30000
ligne8 = Stackhorizontal(a1, a3, a2)
stack = Stackvertical(ligne1, ligne2, ligne3, ligne4, ligne5, ligne6, ligne7, ligne8)
return stack
#~ ConvertToStacked().Dither_out()
Prefetch(threads=1)
Zoom in
Thanks to everyone again.
Hello @Blankmedia
it looks very impressive.
Could you advice how to use your script in StaxRip app?
madey83 is offline   Reply With Quote
Old 23rd June 2022, 02:34   #24  |  Link
Blankmedia
Originally Posted by madey83 View Post
Hello @Blankmedia
I wish I could help you but I've nerver used StaxRip.
But can't you just use avisynth and x264 or x265?
masks
