4th October 2019, 20:36 | #281 | Link | |
Cary Knoop
4th October 2019, 21:09 | #282 | Link |
Hey Cary,
EXR is 16bit half float. Sample file is downloadable here. exrheader inspection: Code:
$ exrheader source_sgamut3cine_linear.exr file source_sgamut3cine_linear.exr: file format version: 2, flags 0x0 channels (type chlist): B, 16-bit floating-point, sampling 1 1 G, 16-bit floating-point, sampling 1 1 R, 16-bit floating-point, sampling 1 1 compression (type compression): none dataWindow (type box2i): (0 0) - (319 239) displayWindow (type box2i): (0 0) - (319 239) framesPerSecond (type rational): 24/1 (24) lineOrder (type lineOrder): increasing y pixelAspectRatio (type float): 1 screenWindowCenter (type v2f): (0 0) screenWindowWidth (type float): 1 timeCode (type timecode): time 00:00:00:00 drop frame 0, color frame 0, field/phase 0 bgf0 0, bgf1 0, bgf2 0 user data 0x0 type (type string): "scanlineimage" |
28th October 2019, 17:23 | #284 | Link |
There is information on these pages:
http://www.vapoursynth.com/doc/functions/resize.html http://avisynth.nl/index.php/Resize But some say it is out of date. I don’t know, I use bicubic with b=0,c=0.5. |
8th December 2019, 15:34 | #285 | Link | |
Sorry for the trouble! It’s been years since I worked on fmtconv so it was a bit difficult to dive into the code again.
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding |
8th December 2019, 15:56 | #286 | Link | |
Glad to see you! Last edited by redbtn; 8th December 2019 at 16:10. |
8th December 2019, 16:35 | #287 | Link |
Could you also make a release on github?
8th December 2019, 17:03 | #288 | Link | |
Can you tell me the name of the file ? Thank you ! |
8th December 2019, 17:48 | #289 | Link |
Just use the new r21 version posted by cretindesalpes.
9th December 2019, 11:54 | #290 | Link |
Fixed. Thanks for your report!
10th December 2019, 14:48 | #291 | Link |
Fixed now.
11th December 2019, 09:41 | #293 | Link |
There is no new release yet, but there will be soon a r22 with all the fixes. In the meantime, it is possible to compile the source code from the git repository.
11th December 2019, 15:46 | #294 | Link |
Here it is. fmtconv r22:
12th December 2019, 15:53 | #295 | Link | |
Can I ask why spline64 and spline taps=4 doesn't produce the same result? Last edited by redbtn; 13th December 2019 at 00:31. |
13th December 2019, 09:15 | #296 | Link | |
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding Last edited by cretindesalpes; 13th December 2019 at 09:33. Reason: URL error |
15th December 2019, 21:25 | #297 | Link |
I have some problems building fmtconv for x64 using Mingw64.
Created an issue on your git : https://github.com/EleonoreMizo/fmtconv/issues/14 After applying the patch I attached at the issue https://github.com/EleonoreMizo/fmtc...fmtc.patch.txt , the building works ok, but I'm not sure my patch doesn't mess up anything..... Last edited by Pat357; 15th December 2019 at 21:28. |
19th December 2019, 14:23 | #298 | Link |
Thank you, the patch was correct. I did several other modifications. Please check the git repository.
25th January 2020, 19:33 | #299 | Link |
One of the primary issues I run into, when building myself a VapourSynth setup for my outdated OS X system (10.10), was a broken/ non working build of "fmtconv".
I fetched the r22 release and build it with clang ("clang-700.1.81", as included in XCode 7.2, last available for Yosemite). It compiled w/o a hitch, just had the known linking problem with a missing libatomic (the GCC thingy). Removing the respective -latomic flag fixed that. But calling any "fmtc" stuff from a VapourSynth script made vspipe never return. It was busy looping a single thread @ ~100% CPU usage. A build of the older r21 release works fine. Also a build of r22 with gcc 9.2 works fine too (no -latomic linking problem this way either.) So there's some sort of change in r22 that makes older clang mess up the build. Interestingly I can't build the current master version from git with old clang nor gcc 9.2. The compilation fails rather similarly on stuff in src/conc/Interlocked.hpp. Here's the gcc9.2 output: https://pastebin.com/3NWWBJKW . Sadly I can't wrap my brain around this C++ stuff, so I have no idea what it wants to do there and how I could fix it. Also interesting is that this Interlocked stuff seems to be the stuff where the broken r22 clang build has trouble with. That's according to a process sample taken with Activity Monitor: it seems to hang around some of those "OSAtomicCompareAndSwap" functions in the stack trace. Just reporting. Maybe someone has run into the same issue and knows details why it happens exactly: compiler bug, fmtconv's code broken, etc.? Anyway… to make it short: if you got busy-looping issues with fmtc[onv] stuff on an outdated Mac OS X system, try a build of the lib with gcc-9.2! |
22nd July 2020, 08:41 | #300 | Link |
Cary Knoop
Bitdept function fails for ProRes 4444
Any idea why this fails on a ProRes4444 format? I presume it is the alpha channel.
c = core.ffms2.Source("prores4444.mov") c = core.fmtc.bitdepth(c, bits=16) c = core.fmtc.bitdepth(c, bits=16) File "src\cython\vapoursynth.pyx", line 1862, in vapoursynth.Function.__call__ vapoursynth.Error: bitdepth: argument clip is not of array type but more than one value was supplied Edited to add: Found out the solution myself, if an alpha channel is present two clips will be returned. This works fine: Code:
c = core.ffms2.Source("prores4444.mov") c = core.fmtc.bitdepth(c[0], bits=16) Last edited by Cary Knoop; 22nd July 2020 at 08:56. |
