29th April 2017, 12:45 | #4261 | Link |
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
29th April 2017, 13:12 | #4262 | Link |
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
29th April 2017, 18:50 | #4263 | Link |
Might switch over to MPC-BE soon. Why doesn't BE use LAV filters? Are the internal ones better/different? Eg. hardware versus software decoding is selectable in LAV filters. In BE, it is hardware. Deinterlacing in BE is auto, which might conflict with madvr if you trust madvr to IVTC first.
29th April 2017, 20:41 | #4264 | Link |
@JarrettH
If you need LAV Filters, then just use them. I do not see any problem here. Everyone decides what to use.
30th April 2017, 05:49 | #4266 | Link | |
Mpc be lav
I watch a huge variety of movies , videos from all periods over a hundred years. some require more tweaking to get to play well enough to enjoy. other new blu rays, clearly do not need much or any at all. I have learned by trial and error, need to set a few profiles but even so, some old movies will not fit into any profile. By combining Madvr and the 2 MPC BE & HC players i have been able to watch hundreds of movies that just were not fit to watch on media players through the windows OS. nor would they play on the power dvd i paid for 10yrs ago or so. I am very happy that people were able to , and did create these great applications. john
GA990FXA UD3, FX8350 @4.5gz, MSI480 8GB GAMING X, GSkill 16Gb DDR3 1600, ANTEC 750W PSU,Sam B2430HD, LG42LD550, Onkyo TX-SR608. MPC-BE x64 /32 2235 or up to date MadVr91.5 or up to date |
30th April 2017, 17:48 | #4267 | Link | |
I'm also grateful this community over the last 15 years! There are so many smart, intelligent people here! Thank You, Guys!
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
1st May 2017, 17:20 | #4268 | Link |
Greetings,
is there a way to run two separate instances of MPC-BE with different options/settings? In the past it was possible to run portable version that stored settings in the .ini file, but that option no longer exists. Thank you. |
2nd May 2017, 04:17 | #4269 | Link |
@kopija
View->Options->Store settings in the player folder
2nd May 2017, 11:34 | #4271 | Link |
Using LAV with MPC-BE under Windows 8.1 EVR (Custom) or MadVR to play 3D on a 4k desktop, selecting the Line Interleaved option doesn't produce a 1920x2160 frame but a 1920x1080 frame in a window consisting of 2 truncated, wrapped around, offset and interleaved images, regardless of the MPC options I set.
If I select the Over/Under option I do get the expected 1920x2160 frame in a window. MPC stats suggest a 1920x1080 video which doesn't sound correct when there are 2 eye view frames of 1920x1080 joined together. Is there a bug in the Line Interleaved handling of MPC that scales 1920x2160 to 1920x1080 regardless, or have I missed a setting that wraps the window to the actual size and aspect ratio of the video? Because of the native 4k 3D line interleaved nature of the LG TV, I need MPC to only scale horizontally and not tamper with the vertical. It does this with Over/Under setting, so not sure why it would be different with line interleaved. |
2nd May 2017, 12:13 | #4272 | Link | |
If you want use internal 3D setting for line interleaved mode(for TV with passive 3D) - just set to Auto and use internal video decoder + EVR CP. And yes - line interlaved mode do output in 1920x1080(not 2160). There is no mode for 3D output in 1920x2160.
2nd May 2017, 12:34 | #4273 | Link | |
MadVR also outputs line interleaved as 1920x1080 by first downscaling each eye view to 1920x540 then combining them into a 1920x1080 frame. Any possibility MPC-BE could support line interleaved output for 4k passive TVs in future? LG's passive 3D 4k OLED TVs are perfect for this application as there is minimal processing and scaling involved after decoding. When I say 1920x2160 output, I mean as a window on the 4k desktop sized to the video. Scaling the window to fullscreen then provides the desired 3D output of 3840x2160 by only scaling horizontally. My assumption of the LAV->MPC-BE->EVR/MadVR process was that LAV would decode 3D to something like two separate 1920x1080 eye views, then pass them to MPC-BE which would interleave them to a 1920x2160 frame in a window on the desktop and thence scale it to 3840x2160 when displayed fullscreen, but this does not seem to be happening for a 4k desktop. |
2nd May 2017, 14:27 | #4275 | Link |
There is no official 3D4K video, only 1920x1080, and video-renderer do upscale to 4k resolution. No other solution.
2nd May 2017, 14:30 | #4276 | Link |
Also - for 3D decoding don't need LAV Video Decoder. Internal video decoder can do it.
2nd May 2017, 14:50 | #4278 | Link |
All "free" MVC decoders do, and even further, they even all use my wrapper code to do it, its fascinating how these features magically appeared everywhere last year
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 2nd May 2017 at 14:53. |
2nd May 2017, 14:54 | #4279 | Link | |
I don't understand why Over/Under works correctly in MPC-BE/MadVR and Line Interleaved doesn't: they are effectively the same frame size before scaling to desktop, but they don't appear as the same frame size in a window on the desktop. |
2nd May 2017, 14:54 | #4280 | Link | |
Seems ffmpeg/libav have given up on MVC decoder development? madVR doesn't do Over/Under. It does do top-and-bottom, but that's also half-resolution. Last edited by madshi; 2nd May 2017 at 14:56. |
