25th November 2013, 00:11 | #303 | Link |
Some first observations:
1. Installer doesn't play nice with avisynth, assigns new plugin directory and doesn't restore old after uninstall 2. Installer installs VC++ redist even though they were already up to date 3. Installer migration option deletes avisynth plugins, luckily they were backed up. 4. Installer isn't extractable, if extractable it's a simple copy/paste of avisynth.dll Wasn't this supposed to be extractable like avisynth installers? 5. Getting all sorts of dll missing with avisynth+, avsrecursion.dll and opencl.dll mostly which are in avisynth+ and avisynth plugin directories. 6. Some speed tests: With a 1080i mpeg2 source with dss2x86/dssx64(lav avcodec decoding).tfm().tdecimate().lanczosresize() 2.6a5icl 720x404 = 37.96 fps (50-60% cpu) 1280x720 = 25.74 (100%) avs+: 720x404 = 36.98(50-60%) 1280x720 = 24.74(100%) avs64 (JoshyD) 720x404 = 25.02(30-40%) 1280x720 = 21.80(70-80%) avs+64 720x404 = 22.84(30-40%) 1280x720 = 19.17(70-80%) I've been battling with fixing avisynth plugins directory for almost an hour now and still haven't solved it. Guess a rollback is necessary. EDIT: IOBit uninstall of avs+ then clean install of avisynth fixed the plugins directory. Seems the uninstaller doesn't clean up very well.
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 Last edited by turbojet; 25th November 2013 at 00:33. |
25th November 2013, 00:19 | #304 | Link | ||||
is this the full script? What tool did you use to get those numbers and where did you get it from? Last edited by zero9999; 25th November 2013 at 00:48. |
25th November 2013, 00:54 | #305 | Link | |||
All I can get out of it is avisynth.dll and devil.dll not sure if it's x86 or x64. Avisynth installers are fully extractable with 7zip. If installer isn't extractable could a zip with the dll's also available? Quote:
Yes. The x64 speed decrease is I believe a decoder issue. That's fed through x264 same options.
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 Last edited by turbojet; 25th November 2013 at 01:01. |
25th November 2013, 01:12 | #306 | Link | |
it supposed that manual load eliminates the auto one like the normal avs did, not vice versa |
25th November 2013, 01:27 | #307 | Link | |||||
Did you try to install AviSynth+ into your previous AviSynth folder? As far as IOBit software goes, you'd have to check with them because i don't know anything about what it does. Since you seem to have restored your previous state, it's kinda hard to investigate the issues but could you please check the following registry keys and post the contents: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\AviSynth HKEY_LOCAL_MACHINE\SOFTWARE\AviSynth HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{AC78780F-BACA-4805-8D4F-AE1B52B7E7D3}_is1 Quote:
<&ultim> will do Quote:
Actually this is interesting. You said the Avs+ installer was not copying the contents of the old plugin folders to the new locations, but apparently it did so at least for 32 bit stuff. am i right to assume that only the migration of the 64-bit plugins failed? Quote:
yes, and that's exactly the way it works here. Last edited by zero9999; 25th November 2013 at 01:33. |
25th November 2013, 03:03 | #311 | Link |
DGDecode_MPEG2Source("C:\Documents and Settings\a\Desktop\New Folder\One Piece 517__cut.demuxed.d2v") LoadPlugin("C:\Documents and Settings\a\Desktop\mt_masktools-26.dll") Dither_convert_yuv_to_rgb |
25th November 2013, 03:22 | #313 | Link | |
LoadPlugin("C:\Documents and Settings\a\Desktop\mt_masktools-26.dll") DGDecode_MPEG2Source("C:\Documents and Settings\a\Desktop\New Folder\One Piece 517__cut.demuxed.d2v") Dither_convert_yuv_to_rgb |
25th November 2013, 04:33 | #314 | Link |
AFAIK, starting with some 2.6 build Avisynth is searching for additional libraries in plugins folder before system folder.
Avisynth syntax highlighting for AkelPad |
25th November 2013, 05:34 | #315 | Link |
Yes, I'm weird.
IIRC, this is only applied to SEt's Avisynth 2.6 MT builds. I don't know if those changes have been merged to upstream yet, though.
“Never argue with stupid people, they will drag you down to their level and then beat you with experience.” — Mark Twain |
25th November 2013, 05:53 | #316 | Link |
One thing I saw regarding the ISS installer was that it failed to install on an Athlon64 machine I have access to that runs 32-bit XP, complaining that it can't install x64 versions and then quits (why is it trying to install 64-bit on a 32-bit OS?).
Another, more minor thing is that under 64-bit Wine, it installed the 64-bit plugin directories under Program Files (x86) and didn't put anything in Program Files. This might be a Wine vs. real Windows issue, though (especially since it ended up hanging on the vcredist step). |
25th November 2013, 07:27 | #317 | Link | |||||||
Originally had F:\tools\avisynth\plugins and F:\tools\avisynth\plugins64, when installing avisynth+ with the top install option to F:\tools\avisynth+ it created empty directories of F:\tools\avisynth+\plugins and F:\tools\avisynth+\plugins32 and deleted F:\tools\avisynth\plugins and F:\tools\avisynth\plugins64, the rest of F:\tools\avisynth\ was untouched. The only thing in avisynth+'s default plugins directory were ones in the installer. Quote:
ICL: 720x404 40.46fps (25% cpu) 1280x720 39.97(27%) AVS+: 720x404 38.75(28%) 1280x720 38.26(29%) My whole script for x86: dss2().tfm().sorathread().tdecimate().sorathread().lanczosresize() x64: dss().tfm().tdecimate().lanczosresize()
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 Last edited by turbojet; 25th November 2013 at 07:31. |
25th November 2013, 09:18 | #318 | Link |
AVS+ Dev
Looks like there's a confirmed bug in the installer, and as per turbojet's report the DLL search path handling in the plugin loader looks to be inconsistent with classic avs. This wasn't changed though since the very first release of avs+, so that's what you get for not testing early enough Furthermore, tp7 confirmed some filter bug in the intrinsics port. Expect a bugfix release tonight (CET).
It wouldn't. That's what it's doing, so why lie about it? As already said by others, vcredist won't do anything if it is already installed. The 2012 runtime alone has multiple versions though, and the one used by avs+ is the latest that is pretty new. So you probably don't have it already. |
25th November 2013, 15:12 | #319 | Link | ||
Do you think it would be better to install x64 AviSynth+ to Program Files and x86 AviSynth+ to Program Files (x86)? IMO it only serves to confuse the users (Where are my plugin directories?) and we'd have to ask for a second Install folder. On top of that it's complicated to pull off because in InnoSetup the components selection screen comes after the select directory screen, so we'd have to do something custom instead. |
25th November 2013, 15:39 | #320 | Link | |
And I saw that c++ 2012 installed many times that very nice especially with the new feature in mp_pipeline |
