24th February 2007, 14:21 | #161 | Link |
You can specify a path. Just can't contain a ":". So basically you need to use something like msys or use "%n%string_of_length_n" to escape it. Don't think it works for all options where you can specify paths. Definitely should work for -ao pcm though.
25th February 2007, 03:30 | #163 | Link |
retired developer
@CD
Could you give me an exemple please? @Eretria-chan Like all my GUI Should be better in yours I assume.
Detritus Software Last edited by Sirber; 25th February 2007 at 03:40. |
26th February 2007, 15:15 | #165 | Link |
Hey, this thing can even encode files streamed through Network! Awesome!
Is that supposed to happen? Mencoder suffered from a access violation, but Bencos continued as if nothing happened. I have yet to see if it was the Network streaming that caused the problem. Last edited by Eretria-chan; 26th February 2007 at 15:29. |
26th February 2007, 15:33 | #166 | Link |
retired developer
What do you mean by network streaming?
Detritus Software |
26th February 2007, 15:35 | #167 | Link |
HDConvertToX author
i think capture the internet/network (mms/rtps...) video stream and encode on the fly
BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
26th February 2007, 16:12 | #168 | Link |
I encode files by selecting them from network (ie, the file is on another computer).
Further update on the problem suggests that it's related to the Intel Core Duo processor since the problem seems to appear even if the files are stored locally. Yes, the test was conducted with Vista and UAC disabled, but I'm still learning towards the processor. Tested with latest Bencos build. I'll try the P4 package, if I can... UPDATE: It seems the Debug profile doesn't crash, just as the P4 crash thread suggestion. It would appear it's the same problem. I've applied the P4 patch. Now let's see if it crashes again... UPDATE2: It works! Well, you'll be thrilled to hear that it works to encode files through Network. Hey, what revision of x264 is mencoder using? Sneaky... Bencos is saving settings somewhere I don't know... I wonder where? I'm too lazy to find out right now. Last edited by Eretria-chan; 26th February 2007 at 17:36. |
26th February 2007, 17:20 | #169 | Link |
aka XaS
"Streaming over network ...", lol this is simply via shared directories from what I understand, as in "\\192.168.1.2\mysharedanime\narutosux101.avi".
Streaming would have been mms/rtsp indeed (though that should work too btw ).
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS |
26th February 2007, 18:34 | #171 | Link |
retired developer
your file has to be "C:\blabla.avi", aka real files readable via cmdline. Why playing with fire?
Detritus Software |
26th February 2007, 21:14 | #172 | Link | |
Because it works. It works very well. Why transfer files and fill the relatively small HD with a lot of duplicate material when I don't need to?
Maybe I should experiment putting the output directory on the network drive as well! So you see, the files does not need to be "C:\blabla.avi". They don't need to be local at all. And btw, Bencos works perfectly under Vista with UAC disabled. Dunno 'bout it enabled, though. Hmm, seems that it doesn't work the other way around. OH well. Ah! Map a network drive and it works! YES! Last edited by Eretria-chan; 27th February 2007 at 12:57. |
27th February 2007, 13:19 | #173 | Link |
retired developer
just map a network drive...
Detritus Software |
27th February 2007, 19:07 | #176 | Link | |
retired developer
http://forum.doom9.org/showthread.ph...129#post959129
Detritus Software Last edited by Sirber; 27th February 2007 at 19:11. |
27th February 2007, 20:16 | #177 | Link |
Don't yell at me! :/ I fear you!
Did I miss it? Or just not remember it? Hmmm. Oh well. But... can you not simply try to extract the audio with mplayer and see if it fails? I guess not... I know I mentioned it before, but there's no progress on encoding non-44 KHz sources, is there? Last edited by Eretria-chan; 27th February 2007 at 20:20. |
1st March 2007, 18:50 | #178 | Link |
Hmm, are there any plans for "skip if exists" option in the future? I also see that Bencos writes to the user profile (eg C:\Documents and Settings\User\bencos.ini), but I would think it's better fit in %appdata%.
How is the filelist coming? I'd like to add lots of files, but since drag & drop doesn't work and add directory doesn't exist, it tends to become somewhat of a drag... The ini file doesn't support files either to my knowledge... How's work coming along? Taking a break or just busy tampering with the source? |
6th March 2007, 01:59 | #179 | Link |
retired developer
Detritus Software |
8th March 2007, 19:16 | #180 | Link | ||
First bugreport in a while...
I don't know if it's Mencoder related, but... anyway, here's the deal. The following source: Quote:
First pass: Quote:
aac, bencos, gui, webm, x264 |
