12th August 2024, 15:38 | #2983 | Link |
Posts: n/a
Surely you've heard of Google ???
https://forum.videohelp.com/threads/...2-Fork-By-v0lt https://github.com/v0lt/VirtualDub2 |
15th August 2024, 21:24 | #2985 | Link |
Acid fr0g
@dogway
This bug is true, easily reproducible. Get a UHD, Dovi or whatever, enough that it has a PQ stream. Use: SetFilterMTMode("DEFAULT_MT_MODE", 2) LoadPlugin("D:\Eseguibili\Media\DGDecNV\DGDecodeNV.dll") LoadPlugin("D:\Eseguibili\Media\DGCube\DGCube.dll") DGSource("M:\In 4k\Mad Max - Furiosa\furiosa_804p.dgi",ct=276,cb=276,cl=0,cr=0) z_ConvertFormat(width=1920, height=804, pixel_type="RGBP16", colorspace_op="2020:st2084:2020:limited=>rgb:st2084:2020:full", resample_filter_uv="Spline64", dither_type="error_diffusion", use_props=0) DGCube("D:\Programmi\Media\AviSynth+\cube\PQ_to_HLG.cube", in="full", lut="full", out="full") z_ConvertFormat(pixel_type="YUV420P10", colorspace_op="rgb:std-b67:2020:full=>2020:std-b67:2020:limited", resample_filter_uv="Spline64", dither_type="error_diffusion", use_props=0) SMDegrain (tr=3, thSAD=300, truemotion=false, contrasharp=false, PreFilter=6, plane=4, chroma=true, mode="MDegrain") Prefetch(2,6) You can find the appropriate LUT in FranceBB github page. It will give you alternating corrupted and black frames. It doesn't work for prefilter=6 but it does for 7 and 8. Perhaps a KNLMeansCL bug, not yours.
@turment on Telegram |
22nd August 2024, 16:54 | #2986 | Link |
@Dogway
Will SMDgrain work better with this release of mvtools https://github.com/DTL2020/mvtools/releases? or it can't adavange new feature? |
29th August 2024, 18:56 | #2987 | Link |
Big Bit Savings Now !
Some quickfixes on FillMissing 2.03
# FillMissing # Based on script created by Did�e # Based on script created by Did�e # Modified by John Meyer on June 29, 2011 # Further modification on June 8, 2013 # Tdecimate modifications on October 26, 2021 # v1.10 - Updated and Sanitized by Dogway on Mar 05, 2019 # v1.21 - Updated and Sanitized by Dogway on May 18, 2021 # v1.30 - Further optimized (dcycle from DeJump) by Dogway on Jul 15, 2021 # v1.31 - Optimize for HBD by Dogway on Aug 15, 2021 # v1.32 - Remove GrunT dependency by Dogway on Oct 02, 2021 # v1.40 - BWmask bugfixes by Dogway on Oct 28, 2021 # v1.41 - Rebase with latest FrameRateConverter by Dogway on Jan 10, 2022 # v2.00 - Replace with RIFEwrap and hence an EX mod by Dogway on Feb 18, 2023 # v2.01 - Add 'sc=false' to RIFEwrap to force MI by Dogway on Feb 18, 2024 # v2.02 - Fix gpuid to gpu_id for RIFEwrap uses gpuid internally by Emulgator on Aug 28, 2024 # v2.03 - Fix for bitdepths >8bpc: Downconvert BWMask input to 8 bit and expand mask output afterwards to source bitness for ex_merge by Emulgator on Aug 29, 2024 # # Dependencies: # ExTools 10.4 # ResizersPack 12.1 # TransformsPack 2.2.1 # TIVTC # # # - Create interpolated frames at 2x original frame rate using RIFE # - Detect jumps # - Create white mask at each jump point; black mask for all other frames # - Repeat each frame of original video and use mask to "choose" between original video, or motion estimated video # - Decimate exactly 50% to get back to original frame rate. # - This decimation removes the dup frames from the original video and also the dups created by repeating each frame of original video # - However, at each point where motion-estimated frame was inserted, no decimation occurs. Thus, if dups=drops, and the drop happens # within < "cycle" (TDecimate parameter) of the dup, the dup will be removed and the drop will be filled. # - If no drops or dups occur within "cycle," then no motion estimation happens, and decimation merely gets back to original, # unchanged video. function FillMissing(clip source, float "JumpThresh", bool "Fast", int "dcycle", bool "Show", int "gpu_id", bool "debug") { source fs = propNumElements("_ColorRange") > 0 ? \ propGetInt ("_ColorRange") == 0 : isRGB(source) JumpThresh = Default(JumpThresh,0.8) # Threshold for detecting jumps. Increase to catch more jumps. Should always be less than 1.0 Fast = Default(Fast, true) # true for fast mode dcycle = Default(dcycle, 20) # Decimation cycle showdot = Default(Show, false) # true for troubleshooting; otherwise, false gpu_id = Default(gpu_id, 0) # ID for the GPU to use Debug = Default(Debug, false) # true for troubleshooting; otherwise, false double = RIFEwrap(showdot ? Subtitle("***") : last, model=Fast ? 22 : 46, sc=false, gpuid=gpu_id) # Remove comment from ShowMetrics, and change "return final" to "return test" to look at metrics in order to determine proper JumpThresh src8 = ConvertBits(8, dither=-1, fulls=fs) test = ShowMetrics(src8) # Generate a white or black frame, depending on frame difference Black = BlankClip( src8, Color_yuv=$000000, channels=0 ) White = BlankClip( src8, Color_yuv=$FFFFFF, channels=0 ) # This function returns a white clip whenever a big jump is detected; otherwise a black clip is returned # Each YDiff must eliminate Ydiff=0 (duplicate) from moving average BWMask = ScriptClip(src8, function [src8,JumpThresh,Black,White] () { YDif1 = YDifferenceToNext(src8,2) YDif1 = YDif1 < 0.2 ? YDifferenceToNext(src8,3) : YDif1 YDif2 = YDifferenceToNext(src8,1) YDif2 = YDif2 < 0.2 ? YDifferenceToNext(src8,2) : YDif2 YDif3 = YDifferenceToNext(src8,-1) YDif3 = YDif3 < 0.2 ? YDifferenceToNext(src8,-2) : YDif3 YDif4 = YDifferenceToNext(src8,-2) YDif4 = YDif4 < 0.2 ? YDifferenceToNext(src8,-3) : YDif4 ((YDif1 + YDif2 + YDif3 + YDif4) * 0.25 ) / (YDifferenceToNext(src8,-1) + 0.01) <= JumpThresh ? White : Black }) # Generate the 2x framerate mask needed to choose the motion-estimated frames themask = Interleave(Black,trim(BWMask,1,0)).ConvertBits(BitsPerComponent(source)) # Merge double framerate from original with motion-esimated frames, but only where there are jumps # (i.e., original frames are used except at jump points) ex_merge(Interleave(source,source), double, themask, luma=false, UV=3) # Decimate half of all frames (set to twice the length of "normal" dup/drop cycle) RequestLinear(clim=100) dcycle = dcycle+dcycle%2 final = TDecimate(display=false, mode=1, cycleR=dcycle/2, cycle=dcycle, vfrDec=1, sdlim=0 ) return debug ? test : final } #---------------- # This function displays the YDiff value that will be used for detecting big jumps # Each YDiff must eliminate Ydiff=0 (duplicate) from moving average function ShowMetrics (clip c, float "jumpthresh") { ScriptClip(c, function [c] () { YDif1 = YDifferenceToNext(2) YDif1 = YDif1 < 0.2 ? YDifferenceToNext(3) : YDif1 YDif2 = YDifferenceToNext(1) YDif2 = YDif2 < 0.2 ? YDifferenceToNext(2) : YDif2 YDif3 = YDifferenceToNext(-1) YDif3 = YDif3 < 0.2 ? YDifferenceToNext(-2) : YDif3 YDif4 = YDifferenceToNext(-2) YDif4 = YDif4 < 0.2 ? YDifferenceToNext(-3) : YDif4 YDiff = ((YDif1 + YDif2 + YDif3 + YDif4) * 0.25 ) / (YDifferenceToNext(-1) + 0.01) Subtitle("Probability of frozen Frame= "+String(YDiff),y=26) } ) Subtitle("JumpThreshold= "+String(jumpthresh),y=12) }
4th September 2024, 20:45 | #2989 | Link |
Hi All,
i'm look help with issue i have got: Source file is HDR with DolbyVision prof 8.1 and when i do resize 2160p -> 1080p i have got strange "halo" on man's head https://imgur.com/a/AMFxDq7 this is my avisynth call: SetFilterMTMode("DEFAULT_MT_MODE", 2) SetMemoryMax() SetCacheMode(0) ConvertBits(16) deep_resize(1920) SMDegrain(mode="TemporalSoften", tr=2, thSAD=300, thSCD2 = 100, prefilter=0, contrasharp=false, limits=false, refinemotion=true, LFR=true, DCTFlicker=true, Chroma=true, Truemotion=false, Search=3, pel=1) ex_unsharp(0.3,Fc=width()/1.5,safe=true) # Remove some of the dreamy look ex_unsharp(0.8,Fc=width()*1.6,safe=true) # Extra fine sharpness GradFun3plus(thr=0.35, radius=10, mask=2, thr_det=2, elast=2, smode=0, UV=3) ConvertBits(10,dither=1) Prefetch(8,12) no idea why its happening.... edit: This call (default falues from StaxRip) give me the same result: ConvertBits(16) Spline16Resize(1920, 804) SMDegrain(tr=2, thSAD=300, prefilter=-1, contrasharp=true, refinemotion=true) LSFmod(defaults="slow", strength=100, Smode=5, Smethod=3, kernel=11, secure=true, Szrp=16, Spwr=4, SdmpLo=4, SdmpHi=48, Lmode=4, overshoot=1, undershoot=1, Overshoot2=1, Undershoot2=1, soft=-2, soothe=true, keep=20, edgemode=0, edgemaskHQ=true, ss_x=1.50, ss_y=1.50, dest_x=1920, dest_y=804, show=false, screenW=1280, screenH=1024) ConvertToStacked() GradFun3(thr=0.5, radius=12, mode=6, smode=1) ConvertFromStacked() Prefetch(8) Last edited by Lucky38; 4th September 2024 at 20:55. |
5th September 2024, 01:12 | #2990 | Link | |
Posts: n/a
It would be interesting if you could post a sample of this video, so it can be tried by others. |
5th September 2024, 08:53 | #2991 | Link | |
https://mega.nz/file/QIgm0JyZ#NJIcrq...x8ot1k9VxNLoA4 edit/update: Deep resize use only with this deep_resize(1920) gives the same issue. changing settings to default for x265 and use old version of it x265-3.5+156+14-df2e4c31e-.Mod-by-Patman.-x64-avx2-msvc1937.7z do not solve issue. Last edited by Lucky38; 5th September 2024 at 09:28. |
5th September 2024, 11:36 | #2992 | Link | |
Posts: n/a
What movie is that ?? To be clear, what is it that you're trying to achieve with this conversion ?? Some degraining & resizing down to 1080p ?? What app(s) do you prefer to use ?? (You mentioned StaxRip) |
5th September 2024, 11:53 | #2993 | Link | |
this is andor s01e01 i would like to do some degraining & resizing down to 1080p and sharpening using Staxrip. when i do degrain, sharpening for 2160p this "scribble" is little visible when you go frame by frame.... When you encode with resize only looks more visible... I use x265 medium in crf 18-20 (with custom settings) for both 2160/1080 but when i set crf 14 for 1080 it looks better.. have you downscale it during your test? edit: with LFR=false, DCTFlicker=false i see it when playing frame by frame but it is less visible compare to LFR=true, DCTFlicker=true edit 2: this setting --rskip 2 --rskip-edge-threshold 2 from x265 also highight this problem... without it is less noticable Last edited by Lucky38; 5th September 2024 at 13:00. |
5th September 2024, 13:28 | #2994 | Link | |
Posts: n/a
I will have a play with it in a few days... |
5th September 2024, 14:02 | #2995 | Link | |
Pig on the wing
5th September 2024, 17:17 | #2996 | Link | |
hi, yes i know... i used old one to see if this issue could be related to some filters.... normally i use only Dogway's filters.... this is my last call and results: SetFilterMTMode("DEFAULT_MT_MODE", 2) SetMemoryMax() SetCacheMode(0) ConvertBits(16) deep_resize(1920) SMDegrain(tr=2, thSAD=350, thSCD2 = 100, prefilter=0, contrasharp=false, rfilter=3, LFR=false, DCTFlicker=false) ex_unsharp(0.3,Fc=width()/1.5,safe=true) # Remove some of the dreamy look ex_unsharp(1.0,Fc=width()*2.0,safe=true) # Extra fine sharpness GradFun3plus(thr=0.35, radius=10, mask=2, thr_det=2, elast=2, smode=0, UV=3) ConvertBits(10,dither=1) Prefetch(8,12) https://mega.nz/file/hEYkFYKR#HVMjjn...7B7etJFtoosrxQ x265: --crf 18 --output-depth 10 --profile main10 --rd 4 --refine-mv 1 --aq-mode 3 --vbv-bufsize 17500 --vbv-maxrate 18000 --subme 5 --me star --max-merge 5 --weightb --bframes 6 --rc-lookahead 80 --ref 6 --min-keyint 23 --no-open-gop --master-display "G(8500,39850)B(6550,2300)R(35400,14600)WP(15635,16450)L(10000000,1)" --hdr10 --colorprim bt2020 --colormatrix bt2020nc --transfer smpte2084 --range limited --chromaloc 2 --dolby-vision-profile 8.1 --dolby-vision-rpu "E:\_temp\HDRDVmetadata.rpu" --repeat-headers --aud --hrd --limit-sao --selective-sao 4 --no-strong-intra-smoothing and avs+ [INFO]: AviSynth+ 3.7.3 (r4003, 3.7, x86_64) Last edited by Lucky38; 5th September 2024 at 17:37. |
5th September 2024, 18:48 | #2997 | Link |
Pig on the wing
I think you should try removing the filters one by one to see which one triggers what you see.
5th September 2024, 19:16 | #2998 | Link | |
as i stated few post above during resizing to 1080p this issue accures more ( noticable ) than in 2160p... strange think is that this issue is present only for this actor head... next actor does not have this issue closly in his head.... this is my observation in his head motion... |
5th September 2024, 19:20 | #2999 | Link |
Pig on the wing
One thing is to change the resizer. Just try a regular Spline36Resize to see if it has the same effect. It's possible that the resampling kernel selected by deep_resize is not good for your source.
5th September 2024, 19:40 | #3000 | Link | |
x265 settings are the same like i have posted above... my standard avisynth call with replaced resizer: SetFilterMTMode("DEFAULT_MT_MODE", 2) SetMemoryMax() SetCacheMode(0) ConvertBits(16) Spline36Resize(1920, 804) SMDegrain(tr=2, thSAD=350, thSCD2 = 100, prefilter=0, contrasharp=false, rfilter=3, LFR=false, DCTFlicker=false) ex_unsharp(0.3,Fc=width()/1.5,safe=true) # Remove some of the dreamy look ex_unsharp(1.0,Fc=width()*2.0,safe=true) # Extra fine sharpness GradFun3plus(thr=0.35, radius=10, mask=2, thr_det=2, elast=2, smode=0, UV=3) ConvertBits(10,dither=1) Prefetch(8,12) results: https://mega.nz/file/INIWBCSK#ptokbQ...m6SXh3bv1_1Bt4 i still see this issue.... |
avisynth, dogway, filters, hbd, packs |
