Old 6th December 2023, 04:05   #2801  |  Link
Blankmedia
Originally Posted by Dogway View Post
Animation is typically telecined unless this is a TV capture or something, this is not ideal.
QTGMC+ is mainly designed after live recorded video with more temporal coherence.
Try to add back the old bobber with:
UseEdiExt=1 (or 2 for vinverse filtered), EdiExt=ex_bob(src, 0,0.5,props=1)
Thanks it seems to do it
Blankmedia is offline   Reply With Quote
Old 6th December 2023, 07:13   #2802  |  Link
kedautinh12
Originally Posted by madey83 View Post
ok. thx for that.
is there any avisynth related solution to clean this video up that i could use....
You can try with mlrt_ov, and OpenVINO runtimes (you need put all .dll in same folder), Model from here
Script:
z_ConvertFormat(pixel_type="rgbps", colorspace_op="709:709:709:l=>rgb:709:709:f")
mlrt_ov(network_path="C:/Program Files (x86)/AviSynth+/plugins64+/models/RealESRGAN/RealESRGAN_x2plus_op18.onnx", builtin=false, fp16=true, tilesize_w=width/4, tilesize_h=height/4)
propSet("_FieldBased",0)
deep_resize(1280,720,edge="SSIM2")
z_ConvertFormat(pixel_type="yuv420p8", colorspace_op="rgb:709:709:f=>709:709:709:l")
Old 6th December 2023, 11:24   #2803  |  Link
madey83
Posts: n/a
Script:
thank you for that, but is is still very slow. I will try other thinks...
Old 6th December 2023, 11:31   #2804  |  Link
kedautinh12
I think it's faster than yesterday script
Old 6th December 2023, 11:40   #2805  |  Link
kedautinh12
Everything will easy if you upgrade your GPU to high end
Old 6th December 2023, 11:52   #2806  |  Link
madey83
Posts: n/a
yes it is ~1 fps.
many thanks for your all advices..
Old 7th December 2023, 03:54   #2807  |  Link
kedautinh12
If you find other thing good can share to me? More learing more development
Old 7th December 2023, 07:52   #2808  |  Link
madey83
Posts: n/a
this is how my last call looks like, and it is quite fast on my hardware (arround 10 fps)
ConvertBits(16)
dfttest(sigma=64, tbsize=1, dither=1)
pr=ex_Median(mode="IQMST",thres=255)
pre=ex_blend(pr,"blend",opacity=0.2).ex_sbr(1,UV=3)
SMDegrain(tr=3, thSAD=600, thSCD2 = 100, mode="TemporalSoften", truemotion=false, prefilter=pre, contrasharp=false)
deep_resize(1440,1080,edge="nnedi3",flat="nnedi3",grain=0,qual=2,sspace="sigmoid")
ex_unsharp(0.3,Fc=width()/1.5,safe=true) # Remove some of the dreamy look
ex_unsharp(1.0,Fc=width()*2.0,safe=true) # Extra fine sharpness
neo_f3kdb(range=15, y=65, cb=40, cr=40, grainy=0, grainc=0, sample_mode=4, blur_first=True, dynamic_grain=true, mt=False, keep_tv_range=True,output_depth=16)
ConvertBits(10,dither=1)
but i have still problems with removing some dirt/dots....
Old 7th December 2023, 08:04   #2809  |  Link
kedautinh12
You can try spotless for dedots
Old 7th December 2023, 08:07   #2810  |  Link
madey83
Posts: n/a
i have tried this call, but do not see any different:
SpotLess(ThSAD2=1000,RadT=1,Chroma=true,BlkSz=8,OLap=4,Tm=false)
edit: i do not have any expirance with it... i found it yesterday... maybe i'm using it wrongly
Old 7th December 2023, 08:25   #2811  |  Link
kedautinh12
Increase RadT, delete Tm parameter
Old 7th December 2023, 08:35   #2812  |  Link
madey83
Posts: n/a
thx.. looks better. i think this is my final call:
pr=ex_Median(mode="IQMST",thres=255) pre=ex_blend(pr,"blend",opacity=0.2).ex_sbr(1,UV=3)
SpotLess(ThSAD2=1000,RadT=2,Chroma=true,BlkSz=8,OLap=4) # i think it is a good place to call it....
deep_resize(1440,1080,edge="nnedi3",flat="nnedi3",grain=0,qual=2,sspace="sigmoid",gpuid=0)
ex_unsharp(0.15).ex_unsharp(0.15, Fc=width()/1.5)
Old 7th December 2023, 08:50   #2813  |  Link
kedautinh12
try replace neo_f3kdb with
convertbits(16)
GradFun3plus(thr=0.25, radius=10, mask=2, smode=0,UV=3)
Or
convertbits(16)
GradFun3plus(thr=0.5, radius=20, mask=2, smode=0,UV=3)
Old 7th December 2023, 09:16   #2814  |  Link
madey83
Posts: n/a
convertbits(16)
Or
convertbits(16)
to my eyes i do not really see any differents between GradFun3plus and neo_f3kdb
Do you see any other improvments for script?
Old 7th December 2023, 09:24   #2815  |  Link
kedautinh12
Just short clip, i don't see different very much, maybe good for full clip of your where the part i don't have. For my test with other clip, gradfun3plus is better
Old 7th December 2023, 12:01   #2816  |  Link
madey83
Posts: n/a
i have sent you PM with the link
Old 13th December 2023, 18:01   #2817  |  Link
flossy_cake
hello,
can i ask for help with clearing out this clip:
https://mega.nz/file/sZZh2bpI#zK7jGm...pqB6eIUaHFhupk
thank you in advance for any help
Can you please reupload the clip as the link is broken
Old 13th December 2023, 18:39   #2818  |  Link
flossy_cake
yes it is ~1 fps.
If you want like 70fps this is what I'm using for realtime playback of 480p animation on HTPC
# Assuming 480p input clip #
# temporal antialiasing, denoising & stabilisation (without NNEDI3 interpolation)
QTGMC(InputType=1, TR2=3, preset="slow", EdiThreads=4, Sharpness=0.0, Rep0=13).Prefetch(6)
# line thinning - increase first param by 5.0 at a time for thinner lines
aWarpSharp(15.0, blurlevel=1).Prefetch(1)
# sharpening
CAS(sharpness=0.75, y=3, u=2, v=2, opt=-1).Prefetch(1)
# upscale 480p -> 1080p
Spline36Resize(1440, 1080).Prefetch(1)
Animated png:
Individual images: 1, 2
Old 14th December 2023, 02:24   #2819  |  Link
kedautinh12
here:
https://drive.google.com/file/d/1AFD...usp=drive_link
Old 14th December 2023, 14:15   #2820  |  Link
flossy_cake
Cheers.
Well, I don't know how much smoothing madey83 wants...
# Temporal smoothing + sharpening (increase EZDenoise to eg. 4.0 if you want more denoising)
QTGMC(InputType=1, TR2=3, EZDenoise=0.0, Sharpness=2.0, preset="slow", EdiThreads=4, Rep0=13).Prefetch(6)
# Line thinning
# Upscale to 1080p
Spline36Resize(1920, 1080).Prefetch(1)
Getting 30fps @ 3.2Ghz x 4 cores.
Animated PNG's:
With EZDenoise=4.0:
avisynth, dogway, filters, hbd, packs
