Old 30th October 2024, 15:40   #1481  |  Link
nji
... and how is the logic in orig 44282 release?
nji is offline   Reply With Quote
Old 7th November 2024, 12:20   #1482  |  Link
Leo 69
Just want to thank the author for continuously updating this important tool.
Current builds support even JPEGXL, WEBP and AVIF image sequences as input, which is unheard of in "professional-grade" software (Adobe Premiere, DaVinci Resolve, etc.). Extremely important for my workflow. Thank you!
Leo 69 is offline   Reply With Quote
Old 10th November 2024, 19:11   #1483  |  Link
v0lt
VirtualDub2 v2.1.2.663 released.
Fixed "Internal DV decoder".
Fixed a crash when capturing video and saving to ProRes and other similar formats.
Updated avlib-1.vdplugin 0.7.1.170.
* FFmpeg 7.1 is now supported.
* Fixed freezing after early interruption of writing to a file when using some codecs.
Updated scripted.vdplugin 0.2.0.60.
* Fixed a crash when trying to save a read-only file.
* Implemented Unicode support. Now script files are read and saved in UTF-8 format.
* The list of keywords, internal functions and internal filters for AviSynth+ has been updated.
Also available is old VirtualDub2_44282+avlib_vdplugin_0.7.1.170.
PS: new releases are compiled in Visual Studio 2019 v16.11.41.
v0lt is offline   Reply With Quote
Old 20th November 2024, 00:16   #1484  |  Link
GAP
@v0lt
I had no idea that a new version was out already. Can you tell me the major improvements of the new Virtualdub2? I am currently on Windows 10 on a mini PC/
GAP is offline   Reply With Quote
Old 20th November 2024, 00:56   #1485  |  Link
LigH
LigH's Avatar
Most important improvement: Supports ffmpeg Version 7.x and new codecs available since then (e.g. AV1, VVC decoders).
New German Gleitz board
Old 20th November 2024, 14:54   #1486  |  Link
v0lt
https://github.com/v0lt/VirtualDub2/...cs/Changes.txt
Old 1st December 2024, 20:34   #1487  |  Link
jay123210599
Can VirtualDub2 handle and show HDR colors? If so, how?
jay123210599 is offline   Reply With Quote
Old 2nd December 2024, 03:51   #1488  |  Link
v0lt
No. VirtualDub only supports Bt.601 and Bt.709.
Old 2nd December 2024, 14:27   #1489  |  Link
jay123210599
What about your newer version of it?
Old 2nd December 2024, 14:50   #1490  |  Link
v0lt
VirtualDub2 only supports Bt.601 and Bt.709.
Old 4th December 2024, 04:43   #1491  |  Link
v0lt
VirtualDub2 v2.1.3.667 released.
Fixed recording of VirtualDub2 version into AVI files.
Updated avlib-1.vdplugin 0.7.1.200.
* Trying to get around incorrect keyframe seek for MP4 files.
* Fixed the operation of x264 and x265 encoders.
* Fixed the operation of Vorbis encoder.
* Cosmetic changes to codec dialogs.
Also available is old VirtualDub2_44282+avlib_vdplugin_0.7.1.200.
Old 6th December 2024, 19:38   #1492  |  Link
GAP
I'm trying to make a direct stream copy as opposed to a stream copy. My goal is to trim the video before a certain time. I can do this using Stream Copy, but Direct Stream Copy requires a different input driver. I'm trying to avoid an error where the audio and video do not match each other. What is the best way to accomplish this? Do I disable the caching input driver when it comes to Direct Stream copy? Or do I use something else?
Old Yesterday, 07:39   #1493  |  Link
v0lt
Yes, in this case you get the usual VirtualDub work, but it will work for AVI and you will need the VFW and ACM codecs.
The Caching input driver seems to be able to copy I-frame only video streams. I haven't checked.
Try Avidemux.
Old Yesterday, 16:33   #1494  |  Link
GAP
I ended up using AVIDemux as even the exported "Stream Copy" version was off by a few seconds. Virtualdub2 (or the 44282 version that I was using) will not Direct Stream Copy the video I was using. For context, I used a file that I dumped with FFMPEG although I think I should have used a simpler script. It looks like it works now
